    Some help please
    26 Posts 10 Posters 4.4k Views 10 Watching
    • A
      alpro
      I need to know how to take my intertwined faces and form a perfect circle or wrap them around my circle so that I could do an intersect and erase any unwanted geometry. I also want the intertwined faces to have a thickness so I'm guessing I should use push/pull before following any other steps? Thanks.
      Mike
      • GaieusG
        Hi Mike,
        I'm not sure that I understand what exactly you want to accomplish. Could you also attach an skp file?
        • A
          alpro
          Gaieus, I hope this explains it better. I will also post the skp if needed but all it is, is exactly what you see, a shape that I want to turn into a circle. Thanks.
          Mike
          • GaieusG
            The problem is that you cannot just wrap geometry around anything in SU (like you can with images). What I'd do is to model a piece of that geometry on the face of just one segment of the cylinder (but in a way that the pieces meet) and then copy/rotate that around as many times as you created the cylinder from.
            Still not an easy task and I1m not sure about the result.
            • A
              alpro
              Thanks Gaieus, I was hoping someone had a method or trick to simplify this a little.
              Mike
                Mike, if you were to do what you want, you'd end up with a massive file. I would work out one segment of the intertwined "wires" on a portion of a cylinder of the proper radius. Then I would it a component and make a radial array of it. Hide the end line segments and it'll look pretty good.
                If you want to send me the model you have there, I'll make a demo for you.
                Dave
                • A
                  alpro
                  Thanks Dave, I really appreciate it. This is only the first stage of this, I am definitely gonna have lots more questions. I have posted the skp.
                  Debs ring.skp
                  • TIGT
                    Here's a Tutorial on doing it one way...
                    IntertwiningRing.skp
                      Thanks TIG. You beat me to it.
                      Mike, do you still want me to do that for you?
                      • G
                        GreyHead
                        Here's an example - the method is pretty much the same as Dave R's except that I intersected one link of the chain with the plain band to get curved surfaces. Looking at it the band is a perhaps a bit thick.
                        Bob
                        Debs ring 2.skp
                        • TIGT
                          In a similar vein here's my tutorial version but with a rectangular extrusion rather than a tube...
                          • soloS
                            solo
                            Made one ring and copied an array using the protractor multiple paste method.
                            http://img247.imageshack.us/img247/8848/ringggpn5.jpg
                            http://www.solos-art.com
                            • boofredlayB
                              boofredlay
                              It seems everybody wanted a piece of this one...
                              Here is my tutorial.
                              Ring.skp
                              • A
                                alpro
                                Thanks for all the input guys, I'm sure that I'm gonna have some more questions as I continue.
                                Mike
                                • jeff hammondJ
                                  jeff hammond
                                  just in case it's meant to be braid-like.... i guessed a certain reference point which was close but not totally right.. if i have to do it again, i'll be able to fix that..
                                  dotdotdot
                                  • A
                                    alpro
                                    Yes Jeff, that's exactly what I was looking for, I guess I should of said braided instead of intertwined. I really appreciate everyone's help on this.
                                    Mike
                                    • jeff hammondJ
                                      jeff hammond
                                      i don't have time for a tut right now but i can show you how i did it later.. in the mean time, it looks like a lot of people are into trying this shape so maybe someone else can do it..
                                      for now, here's the skp of my version..
                                      ring.skp
                                      dotdotdot
                                      • jeff hammondJ
                                        jeff hammond
                                        ok, so i figured out how to draw it more to my liking but doing a tutorial for this thing might be a little bit much.. it would be about 25 scenes with weird to describe curve manipulations in there.. if someone really wants to see a step-by-step, i'll do it but i'm going to hold off for now.. it will probably take ~2hrs to put together..
                                        it's sort of similar to TIG's method except i used two circles to begin with instead of one (one inside of the other).. i then alternate between the two circles which allows for the weaving..
                                        here's the fixed version skp..
                                        ring2.skp
                                        dotdotdot
                                        • TIGT
                                          With our combined IQ well in excess of 'genius' we have got some great ideas here.
                                          • Alan FraserA
                                            Alan Fraser
                                            I haven't had time to go through all of these, but it seems that you might also be able to do it by producing a ring of braid that is only skin-thick, then using Vector PP on it. Did anyone try it that way?
                                            3D Figures
                                            • 1 / 2
