    Some help please
    26 Posts 10 Posters 3.9k Views 10 Watching
      alpro
      Thanks Gaieus, I was hoping someone had a method or trick to simplify this a little.
      Mike
        Mike, if you were to do what you want, you'd end up with a massive file. I would work out one segment of the intertwined "wires" on a portion of a cylinder of the proper radius. Then I would it a component and make a radial array of it. Hide the end line segments and it'll look pretty good.
        If you want to send me the model you have there, I'll make a demo for you.
        Dave
          alpro
          Thanks Dave, I really appreciate it. This is only the first stage of this, I am definitely gonna have lots more questions. I have posted the skp.
          Debs ring.skp
            Here's a Tutorial on doing it one way...
            IntertwiningRing.skp
              Thanks TIG. You beat me to it.
              Mike, do you still want me to do that for you?
              • G
                GreyHead
                Here's an example - the method is pretty much the same as Dave R's except that I intersected one link of the chain with the plain band to get curved surfaces. Looking at it the band is a perhaps a bit thick.
                Bob
                Debs ring 2.skp
                  In a similar vein here's my tutorial version but with a rectangular extrusion rather than a tube...
                  • soloS
                    Made one ring and copied an array using the protractor multiple paste method.
                    http://img247.imageshack.us/img247/8848/ringggpn5.jpg
                    • boofredlayB
                      boofredlay
                      It seems everybody wanted a piece of this one...
                      Here is my tutorial.
                      Ring.skp
                        alpro
                        Thanks for all the input guys, I'm sure that I'm gonna have some more questions as I continue.
                        Mike
                        • jeff hammondJ
                          just in case it's meant to be braid-like.... i guessed a certain reference point which was close but not totally right.. if i have to do it again, i'll be able to fix that..
                            alpro
                            Yes Jeff, that's exactly what I was looking for, I guess I should of said braided instead of intertwined. I really appreciate everyone's help on this.
                            Mike
                            • jeff hammondJ
                              i don't have time for a tut right now but i can show you how i did it later.. in the mean time, it looks like a lot of people are into trying this shape so maybe someone else can do it..
                              for now, here's the skp of my version..
                              ring.skp
                              • jeff hammondJ
                                ok, so i figured out how to draw it more to my liking but doing a tutorial for this thing might be a little bit much.. it would be about 25 scenes with weird to describe curve manipulations in there.. if someone really wants to see a step-by-step, i'll do it but i'm going to hold off for now.. it will probably take ~2hrs to put together..
                                it's sort of similar to TIG's method except i used two circles to begin with instead of one (one inside of the other).. i then alternate between the two circles which allows for the weaving..
                                here's the fixed version skp..
                                ring2.skp
                                  With our combined IQ well in excess of 'genius' we have got some great ideas here.
                                  • Alan FraserA
                                    Alan Fraser
                                    I haven't had time to go through all of these, but it seems that you might also be able to do it by producing a ring of braid that is only skin-thick, then using Vector PP on it. Did anyone try it that way?
                                    3D Figures
                                    • EdsonE
                                      Edson
                                      eric,
                                      why step 8 (intersect with model)?
                                      http://www.mahfuz.arq.br
                                      • EdsonE
                                        Edson
                                        TIG,
                                        great tut. could you tell me what happened from step 8 to 9? the circles are smoother and the proportions are different.
                                          alpro
                                          This is why I love this forum, so many people willing to share their time and expertise, that just doesn't happen on any other forum, this is definitely a community. This is also why I love SU, so many ways to get the end result.
                                          Mike
                                            @edson said:
                                            TIG,
                                            If you read the notes on page 8 you'll see that I based the steps on 8 sides with no scaling to make ellipses. Then I just re-did one on page 9 with 16 sides and scaled a bit flatter. I didn't show the steps as it would have taken too long... It's quick to do, but slow to de-construct into a tutorial step sheet...
