    Some help please
    26 Posts 10 Posters 3.3k Views 10 Watching
      alpro
      I need to know how to take my intertwined faces and form a perfect circle or wrap them around my circle so that I could do an intersect and erase any unwanted geometry. I also want the intertwined faces to have a thickness so I'm guessing I should use push/pull before following any other steps? Thanks.
      Mike
        Hi Mike,
        I'm not sure that I understand what exactly you want to accomplish. Could you also attach an skp file?
          alpro
          Gaieus, I hope this explains it better. I will also post the skp if needed but all it is, is exactly what you see, a shape that I want to turn into a circle. Thanks.
          Mike
            The problem is that you cannot just wrap geometry around anything in SU (like you can with images). What I'd do is to model a piece of that geometry on the face of just one segment of the cylinder (but in a way that the pieces meet) and then copy/rotate that around as many times as you created the cylinder from.
            Still not an easy task and I1m not sure about the result.
              alpro
              Thanks Gaieus, I was hoping someone had a method or trick to simplify this a little.
              Mike
                Mike, if you were to do what you want, you'd end up with a massive file. I would work out one segment of the intertwined "wires" on a portion of a cylinder of the proper radius. Then I would it a component and make a radial array of it. Hide the end line segments and it'll look pretty good.
                If you want to send me the model you have there, I'll make a demo for you.
                Dave
                  alpro
                  Thanks Dave, I really appreciate it. This is only the first stage of this, I am definitely gonna have lots more questions. I have posted the skp.
                  Debs ring.skp
                    Here's a Tutorial on doing it one way...
                    IntertwiningRing.skp
                      Thanks TIG. You beat me to it.
                      Mike, do you still want me to do that for you?
                        GreyHead
                        Here's an example - the method is pretty much the same as Dave R's except that I intersected one link of the chain with the plain band to get curved surfaces. Looking at it the band is a perhaps a bit thick.
                        Bob
                        Debs ring 2.skp
                          In a similar vein here's my tutorial version but with a rectangular extrusion rather than a tube...
                          • soloS Offline
                            Made one ring and copied an array using the protractor multiple paste method.
                            http://img247.imageshack.us/img247/8848/ringggpn5.jpg
                            • boofredlayB Offline
                              boofredlay
                              It seems everybody wanted a piece of this one...
                              Here is my tutorial.
                              Ring.skp
                                alpro
                                Thanks for all the input guys, I'm sure that I'm gonna have some more questions as I continue.
                                Mike
                                • jeff hammondJ Offline
                                  just in case it's meant to be braid-like.... i guessed a certain reference point which was close but not totally right.. if i have to do it again, i'll be able to fix that..
                                    alpro
                                    Yes Jeff, that's exactly what I was looking for, I guess I should of said braided instead of intertwined. I really appreciate everyone's help on this.
                                    Mike
                                      i don't have time for a tut right now but i can show you how i did it later.. in the mean time, it looks like a lot of people are into trying this shape so maybe someone else can do it..
                                      for now, here's the skp of my version..
                                      ring.skp
                                        ok, so i figured out how to draw it more to my liking but doing a tutorial for this thing might be a little bit much.. it would be about 25 scenes with weird to describe curve manipulations in there.. if someone really wants to see a step-by-step, i'll do it but i'm going to hold off for now.. it will probably take ~2hrs to put together..
                                        it's sort of similar to TIG's method except i used two circles to begin with instead of one (one inside of the other).. i then alternate between the two circles which allows for the weaving..
                                        here's the fixed version skp..
                                        ring2.skp
                                          With our combined IQ well in excess of 'genius' we have got some great ideas here.
                                          • Alan FraserA Offline
                                            Alan Fraser
                                            I haven't had time to go through all of these, but it seems that you might also be able to do it by producing a ring of braid that is only skin-thick, then using Vector PP on it. Did anyone try it that way?
                                            3D Figures
