    SketchUp as a Front-end to CAM
    12 Posts 7 Posters 3.1k Views 7 Watching
    • Tim DanaherT Offline
      Tim Danaher
      Hmm -- anyone done this?
      I may have a job as part of a team building a physical model of the Burj-al-Arab for display in a company's lobby.
      We were discussing using SU to model the thing floor-by-floor, and using a computer-controlled lathe to machine each floor out of MDF, or suchlike, then adding detail by hand.
      Has anyone used this approach? I think we'd need .stl files to feed to a CAM lathe/router, but SU doesn't support this format. We'd have to output it to another program that does, like Cheetah.
      Anyone gone down this route, got any tips/advice, etc?
      Cheers,
      Tim
      http://vizarch.blogspot.com
        jasonh1234
        I've visited a physical model shop before and observed the process they used. They were working from paper drawings, recreating elements in AutoCAD, then feeding the file to a laser cutter which did most of the work.
        Check out my SketchUp iconpack. Available here.
          Tim Danaher
          Which is the process I've already outlined above -- sorry if I wasn't clear enough. I need to get some tips on file formats & transfer. I don't want to have to do the modelling in AutoCAD.
          Cheers,
          Tim
            Charlie__V
            Tim,
            I have looked in to 3d printing,(Zcorp) possibly an option for you depending on the size/complexity.Company software accepts .skp
            http://www.zcorp.com/Products/3D-Printers/spage.aspx
            Or There is a Ruby here by Didier Bur, I have not tried it.
            EDIT: look for.......SU2STL
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_fil_page.htm
            Charlie
              Tim Danaher
              Thanks, Charlie. Stl export ruby could be promising...
              We'd considered 3D printing...but I've tried 3D printing in the past...hmmm...
              Cheers,
              Tim
                Stephen
                Hello. I don't know if this will answer your question, but Datacad 12 ( an architectural cad program) will allow you to open skup files in datacad and export to STL format. I think v 11 will do this as well but v12 is supposed to have become more friendly with skup.
                Hope this helps
                Here's a link to the Datacad forum, I'm sure someone there can answer any questions you may have.
                http://forum.datacad.com/
                Stephen
                  Charlie__V
                  Tim.....I understand....sorry to see your results were......ummm..that's not the Burj I hope. :~)
                  Guess the 3d printing is still in it's infancy (considering cost/quality).
                  However, I'm sure it will really wow us at some time in the near future.
                  Charlie
                    bcoleman001
                    Why not just model in SU then export the model into AutoCAD. Then in AutoCAD export the .stl file?
                      Tim Danaher
                      Because I don't have AutoCAD?
                      Cheers,
                      Tim
                        alpro
                        Tim, check out this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=6603
                        solo mentions Deep Exploration, it's a bit spendy but they do offer a 30 day demo. I just downloaded it myself and it looks like you can import skp and export stl.
                        Mike
                          Tim Danaher
                          Thanks, Alpro, but if you re-read my original post, you'll see I already have a program that will do this...Cheetah3D.
                          I just wanted to know if other people have done this two-stage export process, if there are any pitfalls, or if there was a more direct method -- like didier's stl export ruby. Sorry, I should have been clearer in my OP.
                          Cheers,
                          Tim
                            alexander
                            I don't know exactly, but you mentioned cutting out MDF board.
                            why not export a dxf and import the dxf in your cnc cad program ?
                            Or maybe if the building is solid, use the ruby slicer, so you've got
                            the building in thin piece's and export these with ADO ? and import these in the cnc-programming software.
                            what kind of cnc-machine are you talking about (how many axes ?)
