    SketchUp as a Front-end to CAM
    12 Posts 7 Posters 3.4k Views 7 Watching
    • Tim DanaherT
      Tim Danaher
      Hmm -- anyone done this?
      I may have a job as part of a team building a physical model of the Burj-al-Arab for display in a company's lobby.
      We were discussing using SU to model the thing floor-by-floor, and using a computer-controlled lathe to machine each floor out of MDF, or suchlike, then adding detail by hand.
      Has anyone used this approach? I think we'd need .stl files to feed to a CAM lathe/router, but SU doesn't support this format. We'd have to output it to another program that does, like Cheetah.
      Anyone gone down this route, got any tips/advice, etc?
      Cheers,
      Tim
      http://vizarch.blogspot.com
        jasonh1234
        I've visited a physical model shop before and observed the process they used. They were working from paper drawings, recreating elements in AutoCAD, then feeding the file to a laser cutter which did most of the work.
        Check out my SketchUp iconpack. Available here.
        • Tim DanaherT
          Tim Danaher
          Which is the process I've already outlined above -- sorry if I wasn't clear enough. I need to get some tips on file formats & transfer. I don't want to have to do the modelling in AutoCAD.
          Cheers,
          Tim
          • C
            Charlie__V
            Tim,
            I have looked in to 3d printing,(Zcorp) possibly an option for you depending on the size/complexity.Company software accepts .skp
            http://www.zcorp.com/Products/3D-Printers/spage.aspx
            Or There is a Ruby here by Didier Bur, I have not tried it.
            EDIT: look for.......SU2STL
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_fil_page.htm
            Charlie
            • Tim DanaherT
              Tim Danaher
              Thanks, Charlie. Stl export ruby could be promising...
              We'd considered 3D printing...but I've tried 3D printing in the past...hmmm...
              Cheers,
              Tim
                Stephen
                Hello. I don't know if this will answer your question, but Datacad 12 ( an architectural cad program) will allow you to open skup files in datacad and export to STL format. I think v 11 will do this as well but v12 is supposed to have become more friendly with skup.
                Hope this helps
                Here's a link to the Datacad forum, I'm sure someone there can answer any questions you may have.
                http://forum.datacad.com/
                Stephen
                • C
                  Charlie__V
                  Tim.....I understand....sorry to see your results were......ummm..that's not the Burj I hope. :~)
                  Guess the 3d printing is still in it's infancy (considering cost/quality).
                  However, I'm sure it will really wow us at some time in the near future.
                  Charlie
                  • B
                    bcoleman001
                    Why not just model in SU then export the model into AutoCAD. Then in AutoCAD export the .stl file?
                    • Tim DanaherT
                      Tim Danaher
                      Because I don't have AutoCAD?
                      Cheers,
                      Tim
                        alpro
                        Tim, check out this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=6603
                        solo mentions Deep Exploration, it's a bit spendy but they do offer a 30 day demo. I just downloaded it myself and it looks like you can import skp and export stl.
                        Mike
                        • Tim DanaherT
                          Tim Danaher
                          Thanks, Alpro, but if you re-read my original post, you'll see I already have a program that will do this...Cheetah3D.
                          I just wanted to know if other people have done this two-stage export process, if there are any pitfalls, or if there was a more direct method -- like didier's stl export ruby. Sorry, I should have been clearer in my OP.
                          Cheers,
                          Tim
                            alexander
                            I don't know exactly, but you mentioned cutting out MDF board.
                            why not export a dxf and import the dxf in your cnc cad program ?
                            Or maybe if the building is solid, use the ruby slicer, so you've got
                            the building in thin piece's and export these with ADO ? and import these in the cnc-programming software.
                            what kind of cnc-machine are you talking about (how many axes ?)
