    SketchUp as a Front-end to CAM
    12 Posts 7 Posters 3.4k Views 7 Watching
      jasonh1234
      @tim danaher said:
      Anyone gone down this route, got any tips/advice, etc?
      I've visited a physical model shop before and observed the process they used. They were working from paper drawings, recreating elements in AutoCAD, then feeding the file to a laser cutter which did most of the work.
      Check out my SketchUp iconpack. Available here.
      • Tim DanaherT
        Tim Danaher
        Which is the process I've already outlined above -- sorry if I wasn't clear enough. I need to get some tips on file formats & transfer. I don't want to have to do the modelling in AutoCAD.
        Cheers,
        Tim
        http://vizarch.blogspot.com
        • C
          Charlie__V
          Tim,
          I have looked in to 3d printing,(Zcorp) possibly an option for you depending on the size/complexity.Company software accepts .skp
          http://www.zcorp.com/Products/3D-Printers/spage.aspx
          Or There is a Ruby here by Didier Bur, I have not tried it.
          EDIT: look for.......SU2STL
          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_fil_page.htm
          Charlie
          • Tim DanaherT
            Tim Danaher
            Thanks, Charlie. Stl export ruby could be promising...
            We'd considered 3D printing...but I've tried 3D printing in the past...hmmm...
            Cheers,
            Tim
              Stephen
              Hello. I don't know if this will answer your question, but Datacad 12 ( an architectural cad program) will allow you to open skup files in datacad and export to STL format. I think v 11 will do this as well but v12 is supposed to have become more friendly with skup.
              Hope this helps
              Here's a link to the Datacad forum, I'm sure someone there can answer any questions you may have.
              http://forum.datacad.com/
              Stephen
              • C
                Charlie__V
                Tim.....I understand....sorry to see your results were......ummm..that's not the Burj I hope. :~)
                Guess the 3d printing is still in it's infancy (considering cost/quality).
                However, I'm sure it will really wow us at some time in the near future.
                Charlie
                • B
                  bcoleman001
                  Why not just model in SU then export the model into AutoCAD. Then in AutoCAD export the .stl file?
                  • Tim DanaherT
                    Tim Danaher
                    Because I don't have AutoCAD?
                    Cheers,
                    Tim
                      alpro
                      Tim, check out this post http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=6603
                      solo mentions Deep Exploration, it's a bit spendy but they do offer a 30 day demo. I just downloaded it myself and it looks like you can import skp and export stl.
                      Mike
                      • Tim DanaherT
                        Tim Danaher
                        Thanks, Alpro, but if you re-read my original post, you'll see I already have a program that will do this...Cheetah3D.
                        I just wanted to know if other people have done this two-stage export process, if there are any pitfalls, or if there was a more direct method -- like didier's stl export ruby. Sorry, I should have been clearer in my OP.
                        Cheers,
                        Tim
                          alexander
                          I don't know exactly, but you mentioned cutting out MDF board.
                          why not export a dxf and import the dxf in your cnc cad program ?
                          Or maybe if the building is solid, use the ruby slicer, so you've got
                          the building in thin piece's and export these with ADO ? and import these in the cnc-programming software.
                          what kind of cnc-machine are you talking about (how many axes ?)
