    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 440.4k Views 153 Watching
      REGIS
      It works fine now.
      Thanks a lot.
      cheers
      • ToboboT Offline
        Tobobo
        Chris,
        I can't get it to work.
        I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
        I've posted the model so you can have a look and tell what i'm doing wrong.
        Thanks in advance.
        Netting.skp
        Toby
        Philippians 4:13
          REGIS
          Hi Tobobo
          It's due to the hidden geometry.
          Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
          Just create the group and choose your FFD setting.
          curtain.skp
          cheers
          Edit
          After some FFD
          curtainFFDv6.skp
          cheers
          • ToboboT Offline
            Tobobo
            Thanks REGIS
            I'll have to think of another way to deform the netting.
            Toby
            Philippians 4:13
              REGIS
              Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
              Cheers
                SKELL
                I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                Thanks,
                -Tony
                  One possibility
                  Draw a rectangle
                  Pull it with Ctrl any time you want
                  Select all (triple click)
                  Move it one time + CTRL = Copy
                  Type "10*" (or more) = Multiple
                  Group it
                  Select group Right Click / FFD
                  Edit the goup "FFD"
                  Move points
                  Et voilà 😉
                  rec.skp
                    michaelland
                    Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                    Michael Xie
                      BTM
                      Thanks,
                      -Tony
                      There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                        Yes but will be any effect on the subdivide of a simple rectangle!!!
                        Nothing will arrive when you will move a point of the FFD!
                        Seems the only easy methode is draw a rectangle with the Sandbox 😄
                          jonorman
                          Hi..
                          I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                          can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                          • G Offline
                            GJV
                            woooaaaa
                            amazing plugin
                            just what I needed
                            thanx a lot 😄 !!!!
                              Dee256
                              Works nice! But "transformations reset" needs sometimes before FFD starts.
                              • I Offline
                                ideas_arte
                                .. thanks a million!
                                really useful too 👍
                                • N Offline
                                  niarfe
                                  this looks like a wonderful ruby!!!
                                  too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
                                  would have loved to use it 😞
                                  • Chris FullmerC Offline
                                    Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU 😄
                                    Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you.
                                    Chris
                                    All my Plugins I've written
                                      sprezzaturon
                                      I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
                                      Thanks!
                                        remus
                                        The shape should update automatically, you might have to give it a bit of time, though.
                                        If that doesnt work delete the control points, explode the group, regroup and try again.
                                          sprezzaturon
                                          After waiting on a 2.4 GHz dual core XP system, nothing changed. I've just installed FFD on my computer (2.1 GHz dual core) and created a circle so I could elongate one point. Nothing. This is disappointing.
                                            remus
                                            Have you tried it on 3d geometry? i think it can work on 2d things, but ive never gotten the hang of it.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
