    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.6k Views 153 Watching
      FFD> NxN> set subdivide to true.
      Yes but will be any effect on the subdivide of a simple rectangle!!!
      Nothing will arrive when you will move a point of the FFD!
      Seems the only easy methode is draw a rectangle with the Sandbox 😄
        jonorman
        Hi..
        I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
        can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
        • G
          GJV
          woooaaaa
          amazing plugin
          just what I needed
          thanx a lot 😄 !!!!
            Dee256
            Works nice! But "transformations reset" needs sometimes before FFD starts.
            • I
              ideas_arte
              .. thanks a million!
              really useful too 👍
              • N
                niarfe
                this looks like a wonderful ruby!!!
                too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
                would have loved to use it 😞
                • Chris FullmerC
                  Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU 😄
                  Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you.
                    sprezzaturon
                    I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
                      remus
                      The shape should update automatically, you might have to give it a bit of time, though.
                      If that doesnt work delete the control points, explode the group, regroup and try again.
                        sprezzaturon
                        After waiting on a 2.4 GHz dual core XP system, nothing changed. I've just installed FFD on my computer (2.1 GHz dual core) and created a circle so I could elongate one point. Nothing. This is disappointing.
                          remus
                          Have you tried it on 3d geometry? i think it can work on 2d things, but ive never gotten the hang of it.
                          • H
                            hasan
                            @cphillips said:
                            I can't get this script to work. Nothing happens.
                            I create a sphere, group it, right-click and do 3x3 FFD, enter the new group with Construction Points, move some to another position, exit the group, right-click the sphere group and choose Update FFD. Nothing happens.
                            Can you open the ruby console and see if it is printing any errors?
                              steven-arts
                              Hi Chriss,
                              it really makes fun to work with FFD! I looked at your code and found the factorial function where you mentioned to encrease performance by adding a table for factorials. I made it dynamic and it boosts your code! Just replace the section with:
                              #used by calcBernstein. could be replaced by a table since in
                              #this application n is never more than 3 (number of control points).
                              $fTable = []
                              def factorial(n)
                                  sum = $fTable.rassoc(n)
                                  if sum
                                  	return sum[0]
                                  else
                              	sum = 1
                              	sum.upto(n) { |i| sum *= i }
                              	$fTable << [sum, n]
                              	return sum
                              Ciao, Stefan
                              • C
                                CPhillips
                                Thanks Stefan! Its a nice idea. I updated the plugin with an adaption of the code and applied it to the Bernstein Polynomial as well. It sped up the initial weighting of a big model from 75 seconds to 15 seconds.
                                I also figured out a way (in theory) to speed up the actual deformation by like 50x. The only problem is I would have to handle moving the control points without using any of Sketchups tools like select, move and rotate. Ugh!
                                  Jim
                                  Just wanted to bump this and make folks aware of the update.
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  • mitcorbM
                                    mitcorb
                                    Thank you for the update. It really is an effective modeling tool.
                                    • C
                                      CPhillips
                                      I found another way to speed the updates. A model with 11300 verts takes about 90 seconds to update in this version and about 6 seconds with the new method.
                                      But it order to get it ready for release I would almost have to rewrite it. Because it would be a significant amount of work I am thinking I might make the new one a "Pro" version.
                                      Question: How many would be willing to pay for a version with some significant updates? And what would be a fair price to charge?
                                      • EarthMoverE
                                        EarthMover
                                        Sounds like a significant speed improvement. I would pay for a Pro version with a few new features. I think in the range of $15 is fair.
                                        Content Creator at Skapeup
                                        • MALAISEM
                                          MALAISE
                                          By the way, about 10 € ( 15$) seem to be a fair sum, as far as this version is also
                                          available for SU ( not the Pro version )...
                                          MALAISE 👍
                                          • boofredlayB
                                            boofredlay
                                            I would pay for it too. $15 seems reasonable.
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
