    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 26.5k Views 32 Watching
    • jujuJ Offline
      juju
      Wow Didier, tlk about a quick turnaround time! MANY thanks, I really appreciate the trouble.
      • Didier BurD Offline
        Didier Bur
        Hi Juju,
        Thancks for the SKP. It DID help me to find why some components didn't appear in the list and why some other did.
        You know, when you take a look at the "In model" tab of your components browser, you see say, 38 components. But in fact there are much more components loaded in the model definitions list: groups, images, and internal components. In your file there are 184 of them ! Fortunately I discovered a ruby method to distinguish which component is shown or not in the browser. What's shown is what you must have in the list. I replaced my old buggy function with this method and (drumroll) all went well: 38 components in list.
        So I've some good news for you: version 1.12 has been uploaded at the top of this thread.
        I've also corrected the "zillions of comps" bug when using flat 2D components. Now the scripts supports wire components either in X,Y,orZ.
        Webdialogs to come in version 1.13 ... And maybe proxies too.
        Regards,
        DB
        • plot-parisP Offline
          plot-paris
          Didier, this is great news! thanks a lot for the uptate! πŸ‘
          • ToboboT Offline
            Tobobo
            Didier,
            You are a true legend!
            Toby
            Philippians 4:13
              Just a quick workaround idea for 2D components:
              Modify the component definition by adding a vertical line to the face on the red%green plane (to give it more than 0 depth) and use the script. Afterwards you can always delete this line (and of course it will be deleted from all instances).
                rv1974
                http://img65.imageshack.us/img65/4219/screenshot055ns0.jpg
                http://img65.imageshack.us/img65/4219/screenshot055ns0.8ee385c8ed.jpg
                  Didier Bur
                  Hi Gaieus,
                  No need to do that now. Component with a single line in it will work, either a XY line,XZ line or YZ line, or a flat surface, whatever you like.
                  DB
                  • david_hD Offline
                    david_h
                    I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
                    help please. .. .
                      plot-paris
                      did you specify a layer? everytime I left this one blank, it did'nt work for me
                        j_forrester
                        Anyone seen this warning dialoge before?
                        Cant seem to get the plugin to work.
                        Many thanks
                          rv1974
                          Didier is it complicated to add a new spray shape-
                          vertexes of selected surface ? There'll be lot of use for this mode.
                            Didier Bur
                            Not very difficult to add.
                            Dropped it on the todo list πŸ˜‰
                            @j_forester: is this happening on SU startup or when using the script ?
                            DB
                              j_forrester
                              On SU Pro startup. Running Mac 10.4.9
                              • david_hD Offline
                                david_h
                                that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                                  Didier Bur
                                  Component Spray Tool updated (v 1.3.) here:
                                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                                  New shape option and bug fixes.
                                  Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                                  DB
                                  • jujuJ Offline
                                    juju
                                    Thx Didier.
                                    • P Offline
                                      physicsguy
                                      my computer doesn't recognise the file type! please help!
                                        bellwells
                                        You need to place the script within your Plugins folder inside SketchUp. Unzip it, if necessary.
                                        Ron
                                        • W Offline
                                          warriorcat
                                          About the plugin, how do you get it in sketchup? I try opening the file but wants to upload as a model and I put it in plugins folder but doesn't appear in sketchup. Does it only work in sketchup 6?
                                          • david_hD Offline
                                            david_h
                                            IT shows up in the DRAW pull-down menu. . .at least it does for me.
                                            • 4 / 5
