    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 32.7k Views 32 Watching
    • david_hD
      david_h
      I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
      help please. .. .
      • plot-parisP
        plot-paris
        did you specify a layer? everytime I left this one blank, it did'nt work for me
          j_forrester
          Anyone seen this warning dialoge before?
          Cant seem to get the plugin to work.
          Many thanks
            rv1974
            Didier is it complicated to add a new spray shape-
            vertexes of selected surface ? There'll be lot of use for this mode.
            • Didier BurD
              Didier Bur
              Not very difficult to add.
              Dropped it on the todo list πŸ˜‰
              @j_forester: is this happening on SU startup or when using the script ?
              DB
                j_forrester
                On SU Pro startup. Running Mac 10.4.9
                • david_hD
                  david_h
                  that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                  • Didier BurD
                    Didier Bur
                    Component Spray Tool updated (v 1.3.) here:
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                    New shape option and bug fixes.
                    Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                    DB
                    • jujuJ
                      juju
                      Thx Didier.
                      • P
                        physicsguy
                        my computer doesn't recognise the file type! please help!
                        • B
                          bellwells
                          You need to place the script within your Plugins folder inside SketchUp. Unzip it, if necessary.
                          Ron
                          • W
                            warriorcat
                            About the plugin, how do you get it in sketchup? I try opening the file but wants to upload as a model and I put it in plugins folder but doesn't appear in sketchup. Does it only work in sketchup 6?
                            • david_hD
                              david_h
                              IT shows up in the DRAW pull-down menu. . .at least it does for me.
                              • W
                                warriorcat
                                Doesn't for me
                                • L
                                  l.frisken
                                  it is on one of the scf toolbars
                                  • W
                                    warriorcat
                                    checked that too
                                      Shuvotz
                                      why it is not downloading
                                        alsenhawk
                                        thank you so~so~so much!!
                                          This is an old version of the script.
                                          The new version is here: http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                                            alsenhawk
                                            thank you~ i found it,but just don't know how it work... 😒 may be later~^^
                                            • 4 / 5
