    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 29.4k Views 32 Watching
    • plot-parisP Offline
      plot-paris
      did you specify a layer? everytime I left this one blank, it did'nt work for me
        j_forrester
        Anyone seen this warning dialoge before?
        Cant seem to get the plugin to work.
        Many thanks
          rv1974
          Didier is it complicated to add a new spray shape-
          vertexes of selected surface ? There'll be lot of use for this mode.
          • Didier BurD Offline
            Didier Bur
            Not very difficult to add.
            Dropped it on the todo list πŸ˜‰
            @j_forester: is this happening on SU startup or when using the script ?
            DB
              j_forrester
              On SU Pro startup. Running Mac 10.4.9
              • david_hD Offline
                david_h
                that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                  Didier Bur
                  Component Spray Tool updated (v 1.3.) here:
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                  New shape option and bug fixes.
                  Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                  DB
                  • jujuJ Offline
                    juju
                    Thx Didier.
                      physicsguy
                      my computer doesn't recognise the file type! please help!
                        bellwells
                        You need to place the script within your Plugins folder inside SketchUp. Unzip it, if necessary.
                        Ron
                        • W Offline
                          warriorcat
                          About the plugin, how do you get it in sketchup? I try opening the file but wants to upload as a model and I put it in plugins folder but doesn't appear in sketchup. Does it only work in sketchup 6?
                          • david_hD Offline
                            david_h
                            IT shows up in the DRAW pull-down menu. . .at least it does for me.
                            • W Offline
                              warriorcat
                              Doesn't for me
                                l.frisken
                                it is on one of the scf toolbars
                                • W Offline
                                  warriorcat
                                  checked that too
                                    Shuvotz
                                    why it is not downloading
                                      alsenhawk
                                      thank you so~so~so much!!
                                        This is an old version of the script.
                                        The new version is here: http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                                          alsenhawk
                                          thank you~ i found it,but just don't know how it work... 😒 may be later~^^
                                            Didier Bur
                                            Hi all,
                                            Here is the new toy.
                                            Enjoy πŸ˜„
                                            04.11.08
                                            Hi there,
                                            Here is a release of the spray tool, including a layer mask option, and some bug fixes (very high models with sky domes, active_layer automatically put in the dialog box, etc).
                                            French version coming soon.
                                            Enjoy,
                                            DB
                                            • 4 / 5
