    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 32.7k Views 32 Watching
      rv1974
      Didier is it complicated to add a new spray shape-
      vertexes of selected surface ? There'll be lot of use for this mode.
      • Didier BurD
        Didier Bur
        Not very difficult to add.
        Dropped it on the todo list πŸ˜‰
        @j_forester: is this happening on SU startup or when using the script ?
        DB
          j_forrester
          On SU Pro startup. Running Mac 10.4.9
          • david_hD
            david_h
            @plot-paris said:
            did you specify a layer? everytime I left this one blank, it did'nt work for me
            that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
            • Didier BurD
              Didier Bur
              Component Spray Tool updated (v 1.3.) here:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
              New shape option and bug fixes.
              Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
              DB
              • jujuJ
                juju
                Thx Didier.
                • P
                  physicsguy
                  my computer doesn't recognise the file type! please help!
                  • B
                    bellwells
                    You need to place the script within your Plugins folder inside SketchUp. Unzip it, if necessary.
                    Ron
                    • W
                      warriorcat
                      About the plugin, how do you get it in sketchup? I try opening the file but wants to upload as a model and I put it in plugins folder but doesn't appear in sketchup. Does it only work in sketchup 6?
                      • david_hD
                        david_h
                        IT shows up in the DRAW pull-down menu. . .at least it does for me.
                        • W
                          warriorcat
                          Doesn't for me
                          • L
                            l.frisken
                            it is on one of the scf toolbars
                            • W
                              warriorcat
                              checked that too
                                Shuvotz
                                why it is not downloading
                                  alsenhawk
                                  thank you so~so~so much!!
                                    This is an old version of the script.
                                    The new version is here: http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                                      alsenhawk
                                      thank you~ i found it,but just don't know how it work... 😒 may be later~^^
                                      • Didier BurD
                                        Didier Bur
                                        Hi all,
                                        Here is the new toy.
                                        Enjoy πŸ˜„
                                        04.11.08
                                        Hi there,
                                        Here is a release of the spray tool, including a layer mask option, and some bug fixes (very high models with sky domes, active_layer automatically put in the dialog box, etc).
                                        French version coming soon.
                                        Enjoy,
                                        DB
                                        • 4 / 5
