    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 27.1k Views 32 Watching
    • jujuJ Offline
      juju
      The file seem to be 10MB large already. I could try to shave some stuff off to leave you with the basics... Let me have a look. I'll send you a PM.
        rv1974
        @didier bur said:
        I have 30+ components in a model, yet the plugin only recognises 5,
        What's the difference between the 2 kinds ? (imports, DXF/DWG, own library vs SU library, etc ?)
        I have luck it tries to spray 809234803924789789798 components
        Check out the surface of your components. If it's a grass sprig, you're likely to get millions of them...
        of course may be my hands simply are growing from the @ss
        Of course.
        I'd be happy if you Didier could help me straighten my hands a little )
        Here's spray.skp
        http://www.mediafire.com/?ozzdmv9cplx
        I can't spray component#2 at all.
        With component#3 I get notice about zillion iterations.
        What do I wrong?
        P.S. After posting I finally understood πŸ˜› The plug simply doesn't work with 2d stuff (no matter linework or faces)- 3d only. Could it be fixed? 2d dummy components are good for keeping the file size light in modeling stage.
        • plot-parisP Offline
          plot-paris
          it happened to me several times too, that the script only allowed you to select some of the components in the model.
          when I made the components unique, these new comps where shown in the component spray window.
          ps: didier, have you seen this? πŸ˜‰
          • Didier BurD Offline
            Didier Bur
            Sure: density is based on bounds calculations, and 2D components have a depth of zero and a height of zero. This give either a floating domain error (when dividing by zero) or zillions of instances to drop.
            This can be fixed. Next release will accept 2d components.
            I'm still searching why some components don't appear in the dropdown lists. I cannot reproduce the error for now.
            And for the "too-big-list-of-50+-components-that-goes beyond-the-screen", there's no slider options for such lists. We need to ask for sliders for version 7 ( πŸ˜• ) of the API, OR use webdialogs.
            @plot-paris: interesting, this is what Majid asked for.
            DB
            • jujuJ Offline
              juju
              Hear ya' on the sliders request Didier. How abbout if we could be able to type in the name of the component if it doesn't appear on the list. Currently that functionality isn't supported, but could be another workaround... Just trying to think a little laterally.
              • jujuJ Offline
                juju
                Wow Didier, tlk about a quick turnaround time! MANY thanks, I really appreciate the trouble.
                  Didier Bur
                  Hi Juju,
                  Thancks for the SKP. It DID help me to find why some components didn't appear in the list and why some other did.
                  You know, when you take a look at the "In model" tab of your components browser, you see say, 38 components. But in fact there are much more components loaded in the model definitions list: groups, images, and internal components. In your file there are 184 of them ! Fortunately I discovered a ruby method to distinguish which component is shown or not in the browser. What's shown is what you must have in the list. I replaced my old buggy function with this method and (drumroll) all went well: 38 components in list.
                  So I've some good news for you: version 1.12 has been uploaded at the top of this thread.
                  I've also corrected the "zillions of comps" bug when using flat 2D components. Now the scripts supports wire components either in X,Y,orZ.
                  Webdialogs to come in version 1.13 ... And maybe proxies too.
                  Regards,
                  DB
                    plot-paris
                    Didier, this is great news! thanks a lot for the uptate! πŸ‘
                    • ToboboT Offline
                      Tobobo
                      Didier,
                      You are a true legend!
                      Toby
                      Philippians 4:13
                        Just a quick workaround idea for 2D components:
                        Modify the component definition by adding a vertical line to the face on the red%green plane (to give it more than 0 depth) and use the script. Afterwards you can always delete this line (and of course it will be deleted from all instances).
                          rv1974
                          http://img65.imageshack.us/img65/4219/screenshot055ns0.jpg
                          http://img65.imageshack.us/img65/4219/screenshot055ns0.8ee385c8ed.jpg
                            Didier Bur
                            Hi Gaieus,
                            No need to do that now. Component with a single line in it will work, either a XY line,XZ line or YZ line, or a flat surface, whatever you like.
                            DB
                            • david_hD Offline
                              david_h
                              I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
                              help please. .. .
                                plot-paris
                                did you specify a layer? everytime I left this one blank, it did'nt work for me
                                  j_forrester
                                  Anyone seen this warning dialoge before?
                                  Cant seem to get the plugin to work.
                                  Many thanks
                                    rv1974
                                    Didier is it complicated to add a new spray shape-
                                    vertexes of selected surface ? There'll be lot of use for this mode.
                                      Didier Bur
                                      Not very difficult to add.
                                      Dropped it on the todo list πŸ˜‰
                                      @j_forester: is this happening on SU startup or when using the script ?
                                      DB
                                        j_forrester
                                        On SU Pro startup. Running Mac 10.4.9
                                        • david_hD Offline
                                          david_h
                                          that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                                            Didier Bur
                                            Component Spray Tool updated (v 1.3.) here:
                                            http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                                            New shape option and bug fixes.
                                            Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                                            DB
                                            • 4 / 5
