    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 28.4k Views 32 Watching
      rv1974
      http://img65.imageshack.us/img65/4219/screenshot055ns0.jpg
      http://img65.imageshack.us/img65/4219/screenshot055ns0.8ee385c8ed.jpg
      • Didier BurD Offline
        Didier Bur
        Hi Gaieus,
        No need to do that now. Component with a single line in it will work, either a XY line,XZ line or YZ line, or a flat surface, whatever you like.
        DB
        • david_hD Offline
          david_h
          I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
          help please. .. .
          • plot-parisP Offline
            plot-paris
            did you specify a layer? everytime I left this one blank, it did'nt work for me
              j_forrester
              Anyone seen this warning dialoge before?
              Cant seem to get the plugin to work.
              Many thanks
                rv1974
                Didier is it complicated to add a new spray shape-
                vertexes of selected surface ? There'll be lot of use for this mode.
                  Didier Bur
                  Not very difficult to add.
                  Dropped it on the todo list πŸ˜‰
                  @j_forester: is this happening on SU startup or when using the script ?
                  DB
                    j_forrester
                    On SU Pro startup. Running Mac 10.4.9
                    • david_hD Offline
                      david_h
                      that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                        Didier Bur
                        Component Spray Tool updated (v 1.3.) here:
                        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                        New shape option and bug fixes.
                        Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                        DB
                        • jujuJ Offline
                          juju
                          Thx Didier.
                            physicsguy
                            my computer doesn't recognise the file type! please help!
                              bellwells
                              You need to place the script within your Plugins folder inside SketchUp. Unzip it, if necessary.
                              Ron
                              • W Offline
                                warriorcat
                                About the plugin, how do you get it in sketchup? I try opening the file but wants to upload as a model and I put it in plugins folder but doesn't appear in sketchup. Does it only work in sketchup 6?
                                • david_hD Offline
                                  david_h
                                  IT shows up in the DRAW pull-down menu. . .at least it does for me.
                                  • W Offline
                                    warriorcat
                                    Doesn't for me
                                      l.frisken
                                      it is on one of the scf toolbars
                                      • W Offline
                                        warriorcat
                                        checked that too
                                          Shuvotz
                                          why it is not downloading
                                            alsenhawk
                                            thank you so~so~so much!!
                                            • 4 / 5
