    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 32.7k Views 32 Watching
      rv1974
      @didier bur said:
      I have 30+ components in a model, yet the plugin only recognises 5,
      What's the difference between the 2 kinds ? (imports, DXF/DWG, own library vs SU library, etc ?)
      I have luck it tries to spray 809234803924789789798 components
      Check out the surface of your components. If it's a grass sprig, you're likely to get millions of them...
      of course may be my hands simply are growing from the @ss
      Of course.
      I'd be happy if you Didier could help me straighten my hands a little )
      Here's spray.skp
      http://www.mediafire.com/?ozzdmv9cplx
      I can't spray component#2 at all.
      With component#3 I get notice about zillion iterations.
      What do I wrong?
      P.S. After posting I finally understood πŸ˜› The plug simply doesn't work with 2d stuff (no matter linework or faces)- 3d only. Could it be fixed? 2d dummy components are good for keeping the file size light in modeling stage.
      • plot-parisP
        plot-paris
        it happened to me several times too, that the script only allowed you to select some of the components in the model.
        when I made the components unique, these new comps where shown in the component spray window.
        ps: didier, have you seen this? πŸ˜‰
        • Didier BurD
          Didier Bur
          Sure: density is based on bounds calculations, and 2D components have a depth of zero and a height of zero. This give either a floating domain error (when dividing by zero) or zillions of instances to drop.
          This can be fixed. Next release will accept 2d components.
          I'm still searching why some components don't appear in the dropdown lists. I cannot reproduce the error for now.
          And for the "too-big-list-of-50+-components-that-goes beyond-the-screen", there's no slider options for such lists. We need to ask for sliders for version 7 ( πŸ˜• ) of the API, OR use webdialogs.
          @plot-paris: interesting, this is what Majid asked for.
          DB
          • jujuJ
            juju
            Hear ya' on the sliders request Didier. How abbout if we could be able to type in the name of the component if it doesn't appear on the list. Currently that functionality isn't supported, but could be another workaround... Just trying to think a little laterally.
            • jujuJ
              juju
              Wow Didier, tlk about a quick turnaround time! MANY thanks, I really appreciate the trouble.
              • Didier BurD
                Didier Bur
                Hi Juju,
                Thancks for the SKP. It DID help me to find why some components didn't appear in the list and why some other did.
                You know, when you take a look at the "In model" tab of your components browser, you see say, 38 components. But in fact there are much more components loaded in the model definitions list: groups, images, and internal components. In your file there are 184 of them ! Fortunately I discovered a ruby method to distinguish which component is shown or not in the browser. What's shown is what you must have in the list. I replaced my old buggy function with this method and (drumroll) all went well: 38 components in list.
                So I've some good news for you: version 1.12 has been uploaded at the top of this thread.
                I've also corrected the "zillions of comps" bug when using flat 2D components. Now the scripts supports wire components either in X,Y,orZ.
                Webdialogs to come in version 1.13 ... And maybe proxies too.
                Regards,
                DB
                • plot-parisP
                  plot-paris
                  Didier, this is great news! thanks a lot for the uptate! πŸ‘
                  • ToboboT
                    Tobobo
                    Didier,
                    You are a true legend!
                    Toby
                    Philippians 4:13
                    • GaieusG
                      Just a quick workaround idea for 2D components:
                      Modify the component definition by adding a vertical line to the face on the red%green plane (to give it more than 0 depth) and use the script. Afterwards you can always delete this line (and of course it will be deleted from all instances).
                        rv1974
                        http://img65.imageshack.us/img65/4219/screenshot055ns0.jpg
                        http://img65.imageshack.us/img65/4219/screenshot055ns0.8ee385c8ed.jpg
                        • Didier BurD
                          Didier Bur
                          Hi Gaieus,
                          No need to do that now. Component with a single line in it will work, either a XY line,XZ line or YZ line, or a flat surface, whatever you like.
                          DB
                          • david_hD
                            david_h
                            I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
                            help please. .. .
                            • plot-parisP
                              plot-paris
                              did you specify a layer? everytime I left this one blank, it did'nt work for me
                                j_forrester
                                Anyone seen this warning dialoge before?
                                Cant seem to get the plugin to work.
                                Many thanks
                                  rv1974
                                  Didier is it complicated to add a new spray shape-
                                  vertexes of selected surface ? There'll be lot of use for this mode.
                                  • Didier BurD
                                    Didier Bur
                                    Not very difficult to add.
                                    Dropped it on the todo list πŸ˜‰
                                    @j_forester: is this happening on SU startup or when using the script ?
                                    DB
                                      j_forrester
                                      On SU Pro startup. Running Mac 10.4.9
                                      • david_hD
                                        david_h
                                        that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                                        • Didier BurD
                                          Didier Bur
                                          Component Spray Tool updated (v 1.3.) here:
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                                          New shape option and bug fixes.
                                          Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                                          DB
                                          • jujuJ
                                            juju
                                            Thx Didier.
                                            • 4 / 5
