    [Obsolete] Component Spray Tool
    88 Posts 32 Posters 31.5k Views 32 Watching
    • Didier BurD Offline
      Didier Bur
      I can't spray component#2 at all.
      Sure: density is based on bounds calculations, and 2D components have a depth of zero and a height of zero. This give either a floating domain error (when dividing by zero) or zillions of instances to drop.
      This can be fixed. Next release will accept 2d components.
      I'm still searching why some components don't appear in the dropdown lists. I cannot reproduce the error for now.
      And for the "too-big-list-of-50+-components-that-goes beyond-the-screen", there's no slider options for such lists. We need to ask for sliders for version 7 ( πŸ˜• ) of the API, OR use webdialogs.
      @plot-paris: interesting, this is what Majid asked for.
      DB
      • jujuJ Offline
        juju
        Hear ya' on the sliders request Didier. How abbout if we could be able to type in the name of the component if it doesn't appear on the list. Currently that functionality isn't supported, but could be another workaround... Just trying to think a little laterally.
        • jujuJ Offline
          juju
          Wow Didier, tlk about a quick turnaround time! MANY thanks, I really appreciate the trouble.
            Didier Bur
            Hi Juju,
            Thancks for the SKP. It DID help me to find why some components didn't appear in the list and why some other did.
            You know, when you take a look at the "In model" tab of your components browser, you see say, 38 components. But in fact there are much more components loaded in the model definitions list: groups, images, and internal components. In your file there are 184 of them ! Fortunately I discovered a ruby method to distinguish which component is shown or not in the browser. What's shown is what you must have in the list. I replaced my old buggy function with this method and (drumroll) all went well: 38 components in list.
            So I've some good news for you: version 1.12 has been uploaded at the top of this thread.
            I've also corrected the "zillions of comps" bug when using flat 2D components. Now the scripts supports wire components either in X,Y,orZ.
            Webdialogs to come in version 1.13 ... And maybe proxies too.
            Regards,
            DB
            • plot-parisP Offline
              plot-paris
              Didier, this is great news! thanks a lot for the uptate! πŸ‘
              • ToboboT Offline
                Tobobo
                Didier,
                You are a true legend!
                Toby
                Philippians 4:13
                  Just a quick workaround idea for 2D components:
                  Modify the component definition by adding a vertical line to the face on the red%green plane (to give it more than 0 depth) and use the script. Afterwards you can always delete this line (and of course it will be deleted from all instances).
                    rv1974
                    http://img65.imageshack.us/img65/4219/screenshot055ns0.jpg
                    http://img65.imageshack.us/img65/4219/screenshot055ns0.8ee385c8ed.jpg
                      Didier Bur
                      Hi Gaieus,
                      No need to do that now. Component with a single line in it will work, either a XY line,XZ line or YZ line, or a flat surface, whatever you like.
                      DB
                      • david_hD Offline
                        david_h
                        I have a 2D flower comp (Always face camera) and I can't seem to get this to do anything. It goes thru the dialogues, etc, but then after I click okay .. .nothing. . . .I even added the little line to make it a 3D comp. Nuthin'!!!
                        help please. .. .
                          plot-paris
                          did you specify a layer? everytime I left this one blank, it did'nt work for me
                            j_forrester
                            Anyone seen this warning dialoge before?
                            Cant seem to get the plugin to work.
                            Many thanks
                              rv1974
                              Didier is it complicated to add a new spray shape-
                              vertexes of selected surface ? There'll be lot of use for this mode.
                                Didier Bur
                                Not very difficult to add.
                                Dropped it on the todo list πŸ˜‰
                                @j_forester: is this happening on SU startup or when using the script ?
                                DB
                                  j_forrester
                                  On SU Pro startup. Running Mac 10.4.9
                                  • david_hD Offline
                                    david_h
                                    that did it. .. plus. . .always make sure there is a surface on which to spray. πŸŽ‰
                                      Didier Bur
                                      Component Spray Tool updated (v 1.3.) here:
                                      http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11746
                                      New shape option and bug fixes.
                                      Should interest especially plot-paris, rv1974 and j_forrester πŸ˜‰
                                      DB
                                      • jujuJ Offline
                                        juju
                                        Thx Didier.
                                          physicsguy
                                          my computer doesn't recognise the file type! please help!
                                            bellwells
                                            You need to place the script within your Plugins folder inside SketchUp. Unzip it, if necessary.
                                            Ron
                                            • 4 / 5
