    In Development: Subdivide and Smooth
    262 Posts 65 Posters 71.8k Views 65 Watching
    • W Offline
      Whaat
      @a4chitect said:
      does it mean we will be able to smooth contour generated surfaces so they will be more natural in shape? good luck with testing
      Can someone post a complicated contour generated surface? I would like to test this. Thanks.
        remus
        Is this any good whaat? might be a bit simple for your purposes, but it was good fun to make πŸ˜›
        whaat contours.skp
        • W Offline
          Whaat
          Thanks remus,
          Here are the results:
          First image is the original surface generated from contours
          Second image is the same surface after performing vertex averaging (same number of polys)
          Third image is the surface after performing two subdivision and smooth iterations
          It seems like vertex averaging will be very useful to generate more realistic landscape surfaces without increasing poly-count. The only problem is that the the resulting surface will no longer coincide with the contours, so real-world accuracy is lost. There is no easy way to change this so don't ask πŸ˜„
          original surface
          Mesh smoothing (vertex averaging without subdivision)
          after two subdivision and smooth iterations
            todd burch
            Just tell them it's an erosion feature thrown in for no charge.
            • Mike LuceyM Offline
              Mike Lucey
              πŸ˜†
                a4chitect
                brilliant whaat - exactly as expected - the surface is much more natural, as for the accuracy - I guess the the vertex-averaged surface could meet the controur lines by simply moving it along the Z axis a bit, and even if they can't touch everywhere - the result is better for its smoothness, you can't take the contours for benchmarking since their accuracy is fairly limited too πŸ˜‰
                maybe performing a test could prove my point>
                1. create a curved surface with the Smoove tool
                2. generate contours either by the dedicated script, or by intersecting with equidistant planes
                3. group contour lines and create a surface by using the sandbox tools
                4. paint this surface a different color from the original
                5. make a copy (change the color) of this new surface and apply your script
                6. compare original surface with both new surfaces
                whaat thanks for making sketchup better, can't wait for you to release.
                  GUNAWAN W
                  oh dear God, please give this guy more power to made this script available to everyone soon. β˜€
                    kwistenbiebel
                    Yummy !
                    Terrific results as far as I see.
                    This together with a 'wrap texture around object' feature could possibly make other 3d party organic model software trash can material.
                    Good stuff Whaat!
                    • W Offline
                      wikii
                      I wrote script below to simulate whaat's.It works,but not perfect
                      class Smooth_contours
                         attr_reader ;author,;date,;ver
                         def initialize
                            @author="Wikii"
                            @date="20080402"
                            @ver="0.01"
                            @mm=Sketchup.active_model
                            @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
                            do_Smooth_contours if @fs.length>0
                         def center_point point3ds
                            re=Geom;;Point3d.new(0,0,0)
                            num=0
                            0.upto( point3ds.length-1){|x|
                               if point3ds[x].class==Geom;;Point3d
                                  re.x+=point3ds[x].x
                                  re.y+=point3ds[x].y
                                  re.z+=point3ds[x].z
                                  num+=1.0
                               else #weighted
                                  re.x+=point3ds[x][0].x*point3ds[x][1]
                                  re.y+=point3ds[x][0].y*point3ds[x][1]
                                  re.z+=point3ds[x][0].z*point3ds[x][1]
                                  num+=point3ds[x][1]
                            re.x/=num
                            re.y/=num
                            re.z/=num
                            re
                         def open_vertex? v
                            v.edges.each{|x|
                               return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
                            return nil
                         def face_center fc
                            Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
                         def do_Smooth_contours
                            group_entities=@mm.active_entities.add_group.entities
                            vertices=[]
                            vertices_info={}
                            @mm.start_operation "123"
                            n=0
                            @fs.each{|x|
                               n+=1.0
                               Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
                               cen=face_center(x)
                               x.vertices.each{|y|
                                  if !vertices.include?(y) and !open_vertex?(y)
                                     vertices<<y
                                     #~ tmp0=y.position
                                     #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                                     tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                                     #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                                     #~ vertices_info[y]=center_point([tmp,tmp0]           )
                                     vertices_info[y]=tmp
                            @ee=Sketchup.active_model.active_entities
                            puts @ee
                            vertices.each{|x|
                               t=Geom;;Transformation.new(vertices_info[x]-x.position)
                               @ee.transform_entities(t, x)
                            @mm.commit_operation
                      Smooth_contours.new
                        a4chitect
                        thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
                        http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
                        wikii's smooth surface script
                        illustration comparing surface accuracy after smooth
                        • RayOchoaR Offline
                          RayOchoa
                          It would be great if you could do a script that could make high poly models low poly. It would be awsome.
                          CaR DeSiGnS bY mE
                          http://ray-ochoa.com
                          • jenujacobJ Offline
                            jenujacob
                            holy moly! this is simply terrrific!
                            how long did the sub division take coen?
                            • erikBE Offline
                              erikB
                              amazing 😲
                              Coen, would it also be possible to leave the 'knife -like features' on the claw as they where ( I mean not subdivised (and rasor scharp πŸ˜„ ) or is the whole model always subdivised ?
                              erikB
                              • sk.lionS Offline
                                sk.lion
                                wow, i cant believe my eyes, this is going to be an awsome script to use!
                                • W Offline
                                  Whaat
                                  Hi all,
                                  I am looking for one more beta tester at the moment. I need someone with a lot of free time on their hands (anyone??) I am worried that the current testers are too busy to test and post bugs. Is there anyone out there who could commit to spending a LOT of time testing over the next week? First come first serve. Please respond right here.
                                    Daniel S
                                    Here!
                                    • chippwaltersC Offline
                                      chippwalters
                                      I can help. I already sent you a private message yesterday about this. I'm currently doing a project which could benefit. Plus, I've experience in scripted solutions.
                                      http://www.vuetoolbar.com/VueToolbarCover/default.htm
                                      Currently working with Cross-Reality technologies
                                      • W Offline
                                        Whaat
                                        @daniel s said:
                                        Here!
                                        OK, you got the job! I expect a two page bug report on my desk tomorrow morning. πŸ˜›
                                        Seriously, though, please give as much feedback as you have time for. I will send you a PM later today. Thanks.
                                        • W Offline
                                          Whaat
                                          I'm sure a lot of people's projects could benefit. What I need is someone who has time to test and post bugs and feedback. If you are still interested I will send you a PM.
                                            chippwalters
                                            Yes. Still interested πŸ˜„
                                            • 13
                                            • 14
                                            • 7 / 14
