    In Development: Subdivide and Smooth
    262 Posts 65 Posters 69.8k Views 65 Watching
    • W Offline
      Whaat
      Subdivide and Smooth version 1.0 Final Features List
      • Low-poly proxy subdivision modeling
      • Automatic updating of subdivision surfaces while editing a proxy (optional)
      • Material inheritance of proxy model to subdivision surface (optional)
      • Creasing tool - allows toggling of fully creased edges or vertices
      • Up to 4 subdivision and smooth iterations
      • Unlimited proxy subdivision models can exist in the same file
      • Subdivision and smoothing of a single isolated face
      • Robust subdivision algorithm that can handle almost any geometry
      • Subdivision without smoothing (linear subdivision) - also triangulates all meshes and maintains material assignment
      • Mesh smoothing (vertex averaging) without subdivision - maintains material assignment
      • Extrude tool - useful for modeling clean geometry that subdivides well
      • Knife subdivide tool (aka 'Zorro')
      Testing begins this week! (sorry, invitation only). I will keep you all posted on the release date!
      Whaat
        remus
        Mmmmmm, exciting stuff, i look forward to it whaat, thanks again for all the hard work πŸ‘
          kwistenbiebel
          I am not sure what all the features exactly mean, but it does sound really cool πŸ˜‰.
            a4chitect
            whaat you rock! I can't wait for this release! you are one of those for whome the human cloning was meant in the first place πŸ˜„ its interesting that you mention mesh smoothing (without subdivision), does it mean we will be able to smooth contour generated surfaces so they will be more natural in shape? good luck with testing
            • FletchF Offline
              Fletch
              😲 can't wait to see it, Whaat...
              (on the 'invite' list, on the 'invite' list, on the 'invite' list)
              http://www.kerkythea.net/phpBB2/images/smiles/eusa_pray.gif
              Fletch
              • soloS Offline
                By the look and feel of it I think the name should be 'Organix' as it does give one the abllity to model organically.
                • W Offline
                  Whaat
                  Can someone post a complicated contour generated surface? I would like to test this. Thanks.
                    remus
                    Is this any good whaat? might be a bit simple for your purposes, but it was good fun to make πŸ˜›
                    whaat contours.skp
                    • W Offline
                      Whaat
                      Thanks remus,
                      Here are the results:
                      First image is the original surface generated from contours
                      Second image is the same surface after performing vertex averaging (same number of polys)
                      Third image is the surface after performing two subdivision and smooth iterations
                      It seems like vertex averaging will be very useful to generate more realistic landscape surfaces without increasing poly-count. The only problem is that the the resulting surface will no longer coincide with the contours, so real-world accuracy is lost. There is no easy way to change this so don't ask πŸ˜„
                      original surface
                      Mesh smoothing (vertex averaging without subdivision)
                      after two subdivision and smooth iterations
                        todd burch
                        Just tell them it's an erosion feature thrown in for no charge.
                        • Mike LuceyM Offline
                          Mike Lucey
                          πŸ˜†
                            a4chitect
                            brilliant whaat - exactly as expected - the surface is much more natural, as for the accuracy - I guess the the vertex-averaged surface could meet the controur lines by simply moving it along the Z axis a bit, and even if they can't touch everywhere - the result is better for its smoothness, you can't take the contours for benchmarking since their accuracy is fairly limited too πŸ˜‰
                            maybe performing a test could prove my point>
                            1. create a curved surface with the Smoove tool
                            2. generate contours either by the dedicated script, or by intersecting with equidistant planes
                            3. group contour lines and create a surface by using the sandbox tools
                            4. paint this surface a different color from the original
                            5. make a copy (change the color) of this new surface and apply your script
                            6. compare original surface with both new surfaces
                            whaat thanks for making sketchup better, can't wait for you to release.
                              GUNAWAN W
                              oh dear God, please give this guy more power to made this script available to everyone soon. β˜€
                                kwistenbiebel
                                Yummy !
                                Terrific results as far as I see.
                                This together with a 'wrap texture around object' feature could possibly make other 3d party organic model software trash can material.
                                Good stuff Whaat!
                                • W Offline
                                  wikii
                                  I wrote script below to simulate whaat's.It works,but not perfect
                                  class Smooth_contours
                                     attr_reader ;author,;date,;ver
                                     def initialize
                                        @author="Wikii"
                                        @date="20080402"
                                        @ver="0.01"
                                        @mm=Sketchup.active_model
                                        @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
                                        do_Smooth_contours if @fs.length>0
                                     def center_point point3ds
                                        re=Geom;;Point3d.new(0,0,0)
                                        num=0
                                        0.upto( point3ds.length-1){|x|
                                           if point3ds[x].class==Geom;;Point3d
                                              re.x+=point3ds[x].x
                                              re.y+=point3ds[x].y
                                              re.z+=point3ds[x].z
                                              num+=1.0
                                           else #weighted
                                              re.x+=point3ds[x][0].x*point3ds[x][1]
                                              re.y+=point3ds[x][0].y*point3ds[x][1]
                                              re.z+=point3ds[x][0].z*point3ds[x][1]
                                              num+=point3ds[x][1]
                                        re.x/=num
                                        re.y/=num
                                        re.z/=num
                                        re
                                     def open_vertex? v
                                        v.edges.each{|x|
                                           return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
                                        return nil
                                     def face_center fc
                                        Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
                                     def do_Smooth_contours
                                        group_entities=@mm.active_entities.add_group.entities
                                        vertices=[]
                                        vertices_info={}
                                        @mm.start_operation "123"
                                        n=0
                                        @fs.each{|x|
                                           n+=1.0
                                           Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
                                           cen=face_center(x)
                                           x.vertices.each{|y|
                                              if !vertices.include?(y) and !open_vertex?(y)
                                                 vertices<<y
                                                 #~ tmp0=y.position
                                                 #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                                                 tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                                                 #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                                                 #~ vertices_info[y]=center_point([tmp,tmp0]           )
                                                 vertices_info[y]=tmp
                                        @ee=Sketchup.active_model.active_entities
                                        puts @ee
                                        vertices.each{|x|
                                           t=Geom;;Transformation.new(vertices_info[x]-x.position)
                                           @ee.transform_entities(t, x)
                                        @mm.commit_operation
                                  Smooth_contours.new
                                    a4chitect
                                    thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
                                    http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
                                    wikii's smooth surface script
                                    illustration comparing surface accuracy after smooth
                                    • RayOchoaR Offline
                                      RayOchoa
                                      It would be great if you could do a script that could make high poly models low poly. It would be awsome.
                                      CaR DeSiGnS bY mE
                                      http://ray-ochoa.com
                                      • jenujacobJ Offline
                                        jenujacob
                                        holy moly! this is simply terrrific!
                                        how long did the sub division take coen?
                                        • erikBE Offline
                                          erikB
                                          amazing 😲
                                          Coen, would it also be possible to leave the 'knife -like features' on the claw as they where ( I mean not subdivised (and rasor scharp πŸ˜„ ) or is the whole model always subdivised ?
                                          erikB
                                          • sk.lionS Offline
                                            sk.lion
                                            wow, i cant believe my eyes, this is going to be an awsome script to use!
                                            • 13
                                            • 14
                                            • 7 / 14
