    In Development: Subdivide and Smooth
    262 Posts 65 Posters 55.2k Views 65 Watching
      justry
      Yeah I know a second iteration wasn't necessary, I just wanted to test the performance of the script on a high-poly model.
      The first one took you 15 seconds though??! My machine's gotta be real slow ๐Ÿ˜ž . Gotta get me a new one!
      Thanks for the quick reply Rick, and your script's great too man. All of them actually ๐Ÿ‘ .
      And waiting for that amazing script of yours whaat!
        RickW
        I think our machines are comparable processor speed, so maybe it's a memory issue (running 4GB RAM here). Regardless, my script is slow compared to Whaat's, since I didn't really get past the proof-of-concept stage into optimizing.
        RickW
        www.smustard.com
        • W Offline
          Whaat
          Subdivide and Smooth version 1.0 Final Features List
          • Low-poly proxy subdivision modeling
          • Automatic updating of subdivision surfaces while editing a proxy (optional)
          • Material inheritance of proxy model to subdivision surface (optional)
          • Creasing tool - allows toggling of fully creased edges or vertices
          • Up to 4 subdivision and smooth iterations
          • Unlimited proxy subdivision models can exist in the same file
          • Subdivision and smoothing of a single isolated face
          • Robust subdivision algorithm that can handle almost any geometry
          • Subdivision without smoothing (linear subdivision) - also triangulates all meshes and maintains material assignment
          • Mesh smoothing (vertex averaging) without subdivision - maintains material assignment
          • Extrude tool - useful for modeling clean geometry that subdivides well
          • Knife subdivide tool (aka 'Zorro')
          Testing begins this week! (sorry, invitation only). I will keep you all posted on the release date!
          Whaat
            remus
            Mmmmmm, exciting stuff, i look forward to it whaat, thanks again for all the hard work ๐Ÿ‘
              kwistenbiebel
              I am not sure what all the features exactly mean, but it does sound really cool ๐Ÿ˜‰.
                a4chitect
                whaat you rock! I can't wait for this release! you are one of those for whome the human cloning was meant in the first place ๐Ÿ˜„ its interesting that you mention mesh smoothing (without subdivision), does it mean we will be able to smooth contour generated surfaces so they will be more natural in shape? good luck with testing
                • F Offline
                  Fletch
                  ๐Ÿ˜ฒ can't wait to see it, Whaat...
                  (on the 'invite' list, on the 'invite' list, on the 'invite' list)
                  http://www.kerkythea.net/phpBB2/images/smiles/eusa_pray.gif
                  Fletch
                  Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                  • soloS Offline
                    By the look and feel of it I think the name should be 'Organix' as it does give one the abllity to model organically.
                    • W Offline
                      Whaat
                      Can someone post a complicated contour generated surface? I would like to test this. Thanks.
                        remus
                        Is this any good whaat? might be a bit simple for your purposes, but it was good fun to make ๐Ÿ˜›
                        whaat contours.skp
                        • W Offline
                          Whaat
                          Thanks remus,
                          Here are the results:
                          First image is the original surface generated from contours
                          Second image is the same surface after performing vertex averaging (same number of polys)
                          Third image is the surface after performing two subdivision and smooth iterations
                          It seems like vertex averaging will be very useful to generate more realistic landscape surfaces without increasing poly-count. The only problem is that the the resulting surface will no longer coincide with the contours, so real-world accuracy is lost. There is no easy way to change this so don't ask ๐Ÿ˜„
                          original surface
                          Mesh smoothing (vertex averaging without subdivision)
                          after two subdivision and smooth iterations
                            todd burch
                            Just tell them it's an erosion feature thrown in for no charge.
                            • Mike LuceyM Offline
                              Mike Lucey
                              ๐Ÿ˜†
                                a4chitect
                                brilliant whaat - exactly as expected - the surface is much more natural, as for the accuracy - I guess the the vertex-averaged surface could meet the controur lines by simply moving it along the Z axis a bit, and even if they can't touch everywhere - the result is better for its smoothness, you can't take the contours for benchmarking since their accuracy is fairly limited too ๐Ÿ˜‰
                                maybe performing a test could prove my point>
                                1. create a curved surface with the Smoove tool
                                2. generate contours either by the dedicated script, or by intersecting with equidistant planes
                                3. group contour lines and create a surface by using the sandbox tools
                                4. paint this surface a different color from the original
                                5. make a copy (change the color) of this new surface and apply your script
                                6. compare original surface with both new surfaces
                                whaat thanks for making sketchup better, can't wait for you to release.
                                  GUNAWAN W
                                  oh dear God, please give this guy more power to made this script available to everyone soon. โ˜€
                                    kwistenbiebel
                                    Yummy !
                                    Terrific results as far as I see.
                                    This together with a 'wrap texture around object' feature could possibly make other 3d party organic model software trash can material.
                                    Good stuff Whaat!
                                    • W Offline
                                      wikii
                                      I wrote script below to simulate whaat's.It works,but not perfect
                                      class Smooth_contours
                                         attr_reader ;author,;date,;ver
                                         def initialize
                                            @author="Wikii"
                                            @date="20080402"
                                            @ver="0.01"
                                            @mm=Sketchup.active_model
                                            @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
                                            do_Smooth_contours if @fs.length>0
                                         def center_point point3ds
                                            re=Geom;;Point3d.new(0,0,0)
                                            num=0
                                            0.upto( point3ds.length-1){|x|
                                               if point3ds[x].class==Geom;;Point3d
                                                  re.x+=point3ds[x].x
                                                  re.y+=point3ds[x].y
                                                  re.z+=point3ds[x].z
                                                  num+=1.0
                                               else #weighted
                                                  re.x+=point3ds[x][0].x*point3ds[x][1]
                                                  re.y+=point3ds[x][0].y*point3ds[x][1]
                                                  re.z+=point3ds[x][0].z*point3ds[x][1]
                                                  num+=point3ds[x][1]
                                            re.x/=num
                                            re.y/=num
                                            re.z/=num
                                            re
                                         def open_vertex? v
                                            v.edges.each{|x|
                                               return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
                                            return nil
                                         def face_center fc
                                            Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
                                         def do_Smooth_contours
                                            group_entities=@mm.active_entities.add_group.entities
                                            vertices=[]
                                            vertices_info={}
                                            @mm.start_operation "123"
                                            n=0
                                            @fs.each{|x|
                                               n+=1.0
                                               Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
                                               cen=face_center(x)
                                               x.vertices.each{|y|
                                                  if !vertices.include?(y) and !open_vertex?(y)
                                                     vertices<<y
                                                     #~ tmp0=y.position
                                                     #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                                                     tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                                                     #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                                                     #~ vertices_info[y]=center_point([tmp,tmp0]           )
                                                     vertices_info[y]=tmp
                                            @ee=Sketchup.active_model.active_entities
                                            puts @ee
                                            vertices.each{|x|
                                               t=Geom;;Transformation.new(vertices_info[x]-x.position)
                                               @ee.transform_entities(t, x)
                                            @mm.commit_operation
                                      Smooth_contours.new
                                        a4chitect
                                        thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
                                        http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
                                        wikii's smooth surface script
                                        illustration comparing surface accuracy after smooth
                                        • RayOchoaR Offline
                                          RayOchoa
                                          It would be great if you could do a script that could make high poly models low poly. It would be awsome.
                                          CaR DeSiGnS bY mE
                                          http://ray-ochoa.com
                                          • jenujacobJ Offline
                                            jenujacob
                                            holy moly! this is simply terrrific!
                                            how long did the sub division take coen?
                                            • 13
                                            • 14
                                            • 7 / 14
