    In Development: Subdivide and Smooth
    262 Posts 65 Posters 101.5k Views 65 Watching
    • FletchF
      Fletch
      😲 can't wait to see it, Whaat...
      (on the 'invite' list, on the 'invite' list, on the 'invite' list)
      http://www.kerkythea.net/phpBB2/images/smiles/eusa_pray.gif
      Fletch
      • soloS
        By the look and feel of it I think the name should be 'Organix' as it does give one the abllity to model organically.
        • W
          Whaat
          @a4chitect said:
          does it mean we will be able to smooth contour generated surfaces so they will be more natural in shape? good luck with testing
          Can someone post a complicated contour generated surface? I would like to test this. Thanks.
            remus
            Is this any good whaat? might be a bit simple for your purposes, but it was good fun to make πŸ˜›
            whaat contours.skp
            • W
              Whaat
              Thanks remus,
              Here are the results:
              First image is the original surface generated from contours
              Second image is the same surface after performing vertex averaging (same number of polys)
              Third image is the surface after performing two subdivision and smooth iterations
              It seems like vertex averaging will be very useful to generate more realistic landscape surfaces without increasing poly-count. The only problem is that the the resulting surface will no longer coincide with the contours, so real-world accuracy is lost. There is no easy way to change this so don't ask πŸ˜„
              original surface
              Mesh smoothing (vertex averaging without subdivision)
              after two subdivision and smooth iterations
              • T
                todd burch
                Just tell them it's an erosion feature thrown in for no charge.
                • Mike LuceyM
                  Mike Lucey
                  πŸ˜†
                    a4chitect
                    brilliant whaat - exactly as expected - the surface is much more natural, as for the accuracy - I guess the the vertex-averaged surface could meet the controur lines by simply moving it along the Z axis a bit, and even if they can't touch everywhere - the result is better for its smoothness, you can't take the contours for benchmarking since their accuracy is fairly limited too πŸ˜‰
                    maybe performing a test could prove my point>
                    1. create a curved surface with the Smoove tool
                    2. generate contours either by the dedicated script, or by intersecting with equidistant planes
                    3. group contour lines and create a surface by using the sandbox tools
                    4. paint this surface a different color from the original
                    5. make a copy (change the color) of this new surface and apply your script
                    6. compare original surface with both new surfaces
                    whaat thanks for making sketchup better, can't wait for you to release.
                    • G
                      GUNAWAN W
                      oh dear God, please give this guy more power to made this script available to everyone soon. β˜€
                      • K
                        kwistenbiebel
                        Yummy !
                        Terrific results as far as I see.
                        This together with a 'wrap texture around object' feature could possibly make other 3d party organic model software trash can material.
                        Good stuff Whaat!
                        • W
                          wikii
                          I wrote script below to simulate whaat's.It works,but not perfect
                          class Smooth_contours
                             attr_reader ;author,;date,;ver
                             def initialize
                                @author="Wikii"
                                @date="20080402"
                                @ver="0.01"
                                @mm=Sketchup.active_model
                                @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
                                do_Smooth_contours if @fs.length>0
                             def center_point point3ds
                                re=Geom;;Point3d.new(0,0,0)
                                num=0
                                0.upto( point3ds.length-1){|x|
                                   if point3ds[x].class==Geom;;Point3d
                                      re.x+=point3ds[x].x
                                      re.y+=point3ds[x].y
                                      re.z+=point3ds[x].z
                                      num+=1.0
                                   else #weighted
                                      re.x+=point3ds[x][0].x*point3ds[x][1]
                                      re.y+=point3ds[x][0].y*point3ds[x][1]
                                      re.z+=point3ds[x][0].z*point3ds[x][1]
                                      num+=point3ds[x][1]
                                re.x/=num
                                re.y/=num
                                re.z/=num
                                re
                             def open_vertex? v
                                v.edges.each{|x|
                                   return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
                                return nil
                             def face_center fc
                                Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
                             def do_Smooth_contours
                                group_entities=@mm.active_entities.add_group.entities
                                vertices=[]
                                vertices_info={}
                                @mm.start_operation "123"
                                n=0
                                @fs.each{|x|
                                   n+=1.0
                                   Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
                                   cen=face_center(x)
                                   x.vertices.each{|y|
                                      if !vertices.include?(y) and !open_vertex?(y)
                                         vertices<<y
                                         #~ tmp0=y.position
                                         #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                                         tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                                         #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                                         #~ vertices_info[y]=center_point([tmp,tmp0]           )
                                         vertices_info[y]=tmp
                                @ee=Sketchup.active_model.active_entities
                                puts @ee
                                vertices.each{|x|
                                   t=Geom;;Transformation.new(vertices_info[x]-x.position)
                                   @ee.transform_entities(t, x)
                                @mm.commit_operation
                          Smooth_contours.new
                            a4chitect
                            thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
                            http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
                            wikii's smooth surface script
                            illustration comparing surface accuracy after smooth
                            • RayOchoaR
                              RayOchoa
                              It would be great if you could do a script that could make high poly models low poly. It would be awsome.
                              CaR DeSiGnS bY mE
                              http://ray-ochoa.com
                              • jenujacobJ
                                jenujacob
                                holy moly! this is simply terrrific!
                                how long did the sub division take coen?
                                • erikBE
                                  erikB
                                  amazing 😲
                                  Coen, would it also be possible to leave the 'knife -like features' on the claw as they where ( I mean not subdivised (and rasor scharp πŸ˜„ ) or is the whole model always subdivised ?
                                  erikB
                                  • sk.lionS
                                    sk.lion
                                    wow, i cant believe my eyes, this is going to be an awsome script to use!
                                    • W
                                      Whaat
                                      Hi all,
                                      I am looking for one more beta tester at the moment. I need someone with a lot of free time on their hands (anyone??) I am worried that the current testers are too busy to test and post bugs. Is there anyone out there who could commit to spending a LOT of time testing over the next week? First come first serve. Please respond right here.
                                        Daniel S
                                        Here!
                                        • chippwaltersC
                                          chippwalters
                                          I can help. I already sent you a private message yesterday about this. I'm currently doing a project which could benefit. Plus, I've experience in scripted solutions.
                                          http://www.vuetoolbar.com/VueToolbarCover/default.htm
                                          Currently working with Cross-Reality technologies
                                          • W
                                            Whaat
                                            @daniel s said:
                                            Here!
                                            OK, you got the job! I expect a two page bug report on my desk tomorrow morning. πŸ˜›
                                            Seriously, though, please give as much feedback as you have time for. I will send you a PM later today. Thanks.
                                            • 13
                                            • 14
                                            • 7 / 14
