    In Development: Subdivide and Smooth
    262 Posts 65 Posters 64.0k Views 65 Watching
      GUNAWAN W
      oh dear God, please give this guy more power to made this script available to everyone soon. ☀
        kwistenbiebel
        Yummy !
        Terrific results as far as I see.
        This together with a 'wrap texture around object' feature could possibly make other 3d party organic model software trash can material.
        Good stuff Whaat!
        • W Offline
          wikii
          I wrote script below to simulate whaat's.It works,but not perfect
          class Smooth_contours
             attr_reader ;author,;date,;ver
             def initialize
                @author="Wikii"
                @date="20080402"
                @ver="0.01"
                @mm=Sketchup.active_model
                @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
                do_Smooth_contours if @fs.length>0
             def center_point point3ds
                re=Geom;;Point3d.new(0,0,0)
                num=0
                0.upto( point3ds.length-1){|x|
                   if point3ds[x].class==Geom;;Point3d
                      re.x+=point3ds[x].x
                      re.y+=point3ds[x].y
                      re.z+=point3ds[x].z
                      num+=1.0
                   else #weighted
                      re.x+=point3ds[x][0].x*point3ds[x][1]
                      re.y+=point3ds[x][0].y*point3ds[x][1]
                      re.z+=point3ds[x][0].z*point3ds[x][1]
                      num+=point3ds[x][1]
                re.x/=num
                re.y/=num
                re.z/=num
                re
             def open_vertex? v
                v.edges.each{|x|
                   return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
                return nil
             def face_center fc
                Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
             def do_Smooth_contours
                group_entities=@mm.active_entities.add_group.entities
                vertices=[]
                vertices_info={}
                @mm.start_operation "123"
                n=0
                @fs.each{|x|
                   n+=1.0
                   Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
                   cen=face_center(x)
                   x.vertices.each{|y|
                      if !vertices.include?(y) and !open_vertex?(y)
                         vertices<<y
                         #~ tmp0=y.position
                         #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                         tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                         #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                         #~ vertices_info[y]=center_point([tmp,tmp0]           )
                         vertices_info[y]=tmp
                @ee=Sketchup.active_model.active_entities
                puts @ee
                vertices.each{|x|
                   t=Geom;;Transformation.new(vertices_info[x]-x.position)
                   @ee.transform_entities(t, x)
                @mm.commit_operation
          Smooth_contours.new
            a4chitect
            thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
            http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
            wikii's smooth surface script
            illustration comparing surface accuracy after smooth
            • RayOchoaR Offline
              RayOchoa
              It would be great if you could do a script that could make high poly models low poly. It would be awsome.
              CaR DeSiGnS bY mE
              http://ray-ochoa.com
              • jenujacobJ Offline
                jenujacob
                holy moly! this is simply terrrific!
                how long did the sub division take coen?
                • erikBE Offline
                  erikB
                  amazing 😲
                  Coen, would it also be possible to leave the 'knife -like features' on the claw as they where ( I mean not subdivised (and rasor scharp 😄 ) or is the whole model always subdivised ?
                  erikB
                  • sk.lionS Offline
                    sk.lion
                    wow, i cant believe my eyes, this is going to be an awsome script to use!
                    • W Offline
                      Whaat
                      Hi all,
                      I am looking for one more beta tester at the moment. I need someone with a lot of free time on their hands (anyone??) I am worried that the current testers are too busy to test and post bugs. Is there anyone out there who could commit to spending a LOT of time testing over the next week? First come first serve. Please respond right here.
                        Daniel S
                        Here!
                        • chippwaltersC Offline
                          chippwalters
                          I can help. I already sent you a private message yesterday about this. I'm currently doing a project which could benefit. Plus, I've experience in scripted solutions.
                          http://www.vuetoolbar.com/VueToolbarCover/default.htm
                          Currently working with Cross-Reality technologies
                          • W Offline
                            Whaat
                            @daniel s said:
                            Here!
                            OK, you got the job! I expect a two page bug report on my desk tomorrow morning. 😛
                            Seriously, though, please give as much feedback as you have time for. I will send you a PM later today. Thanks.
                            • W Offline
                              Whaat
                              I'm sure a lot of people's projects could benefit. What I need is someone who has time to test and post bugs and feedback. If you are still interested I will send you a PM.
                                chippwalters
                                Yes. Still interested 😄
                                • W Offline
                                  Whaat
                                  OK thanks! I'll PM you later today.
                                    GUNAWAN W
                                    @whaat said:
                                    Hi all,
                                    I'm in, i have free time.
                                      dylan
                                      That is amazing to see what Coen has posted. This script is something special!
                                      http://dmdarchitecture.co.uk/
                                        chippwalters
                                        A preview using the latest SubD Beta. This is my first 'playing around' model. Couple of interesting workflow techniques. You can set up SubD so you only work on half of a model, and the proxy components are updated as fast as possible. You can update them with a fast and low SubD setting, then when you're finished, you can update the proxies with a higher SubD setting, as this picture shows.
                                        Also, you can 'crease' edges and vertices, so you have more control over how tight the SubD patching is fitted. A very, very cool plugin which, after taking a bit of time to learn, will be most valuable in everyone's toolset!
                                        The rendering is Podium overlayed with a line render from SU.
                                        http://www.gadgetplugins.com/chippstuff/planesketch3.jpg
                                        • jujuJ Offline
                                          juju
                                          😲 All together now, SWEET! 😍
                                            kwistenbiebel
                                            That's cool stuff...So if I understand well, you can keep on modeling the low poly proxy and it will automatically update the rounded object right?
                                            What would happen if the low poly object has textures applied?
                                            Do they hold ?
                                            @Whaat,
                                            Great job man !
                                            • 13
                                            • 14
                                            • 8 / 14
