    In Development: Subdivide and Smooth
    262 Posts 65 Posters 71.8k Views 65 Watching
    • W Offline
      wikii
      I wrote script below to simulate whaat's.It works,but not perfect
      class Smooth_contours
         attr_reader ;author,;date,;ver
         def initialize
            @author="Wikii"
            @date="20080402"
            @ver="0.01"
            @mm=Sketchup.active_model
            @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
            do_Smooth_contours if @fs.length>0
         def center_point point3ds
            re=Geom;;Point3d.new(0,0,0)
            num=0
            0.upto( point3ds.length-1){|x|
               if point3ds[x].class==Geom;;Point3d
                  re.x+=point3ds[x].x
                  re.y+=point3ds[x].y
                  re.z+=point3ds[x].z
                  num+=1.0
               else #weighted
                  re.x+=point3ds[x][0].x*point3ds[x][1]
                  re.y+=point3ds[x][0].y*point3ds[x][1]
                  re.z+=point3ds[x][0].z*point3ds[x][1]
                  num+=point3ds[x][1]
            re.x/=num
            re.y/=num
            re.z/=num
            re
         def open_vertex? v
            v.edges.each{|x|
               return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
            return nil
         def face_center fc
            Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
         def do_Smooth_contours
            group_entities=@mm.active_entities.add_group.entities
            vertices=[]
            vertices_info={}
            @mm.start_operation "123"
            n=0
            @fs.each{|x|
               n+=1.0
               Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
               cen=face_center(x)
               x.vertices.each{|y|
                  if !vertices.include?(y) and !open_vertex?(y)
                     vertices<<y
                     #~ tmp0=y.position
                     #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                     tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                     #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                     #~ vertices_info[y]=center_point([tmp,tmp0]           )
                     vertices_info[y]=tmp
            @ee=Sketchup.active_model.active_entities
            puts @ee
            vertices.each{|x|
               t=Geom;;Transformation.new(vertices_info[x]-x.position)
               @ee.transform_entities(t, x)
            @mm.commit_operation
      Smooth_contours.new
        a4chitect
        thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
        http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
        wikii's smooth surface script
        illustration comparing surface accuracy after smooth
        • RayOchoaR Offline
          RayOchoa
          It would be great if you could do a script that could make high poly models low poly. It would be awsome.
          CaR DeSiGnS bY mE
          http://ray-ochoa.com
          • jenujacobJ Offline
            jenujacob
            holy moly! this is simply terrrific!
            how long did the sub division take coen?
            • erikBE Offline
              erikB
              amazing ๐Ÿ˜ฒ
              Coen, would it also be possible to leave the 'knife -like features' on the claw as they where ( I mean not subdivised (and rasor scharp ๐Ÿ˜„ ) or is the whole model always subdivised ?
              erikB
              • sk.lionS Offline
                sk.lion
                wow, i cant believe my eyes, this is going to be an awsome script to use!
                • W Offline
                  Whaat
                  Hi all,
                  I am looking for one more beta tester at the moment. I need someone with a lot of free time on their hands (anyone??) I am worried that the current testers are too busy to test and post bugs. Is there anyone out there who could commit to spending a LOT of time testing over the next week? First come first serve. Please respond right here.
                    Daniel S
                    Here!
                    • chippwaltersC Offline
                      chippwalters
                      I can help. I already sent you a private message yesterday about this. I'm currently doing a project which could benefit. Plus, I've experience in scripted solutions.
                      http://www.vuetoolbar.com/VueToolbarCover/default.htm
                      Currently working with Cross-Reality technologies
                      • W Offline
                        Whaat
                        @daniel s said:
                        Here!
                        OK, you got the job! I expect a two page bug report on my desk tomorrow morning. ๐Ÿ˜›
                        Seriously, though, please give as much feedback as you have time for. I will send you a PM later today. Thanks.
                        • W Offline
                          Whaat
                          I'm sure a lot of people's projects could benefit. What I need is someone who has time to test and post bugs and feedback. If you are still interested I will send you a PM.
                            chippwalters
                            Yes. Still interested ๐Ÿ˜„
                            • W Offline
                              Whaat
                              OK thanks! I'll PM you later today.
                                GUNAWAN W
                                @whaat said:
                                Hi all,
                                I'm in, i have free time.
                                  dylan
                                  That is amazing to see what Coen has posted. This script is something special!
                                  http://dmdarchitecture.co.uk/
                                    chippwalters
                                    A preview using the latest SubD Beta. This is my first 'playing around' model. Couple of interesting workflow techniques. You can set up SubD so you only work on half of a model, and the proxy components are updated as fast as possible. You can update them with a fast and low SubD setting, then when you're finished, you can update the proxies with a higher SubD setting, as this picture shows.
                                    Also, you can 'crease' edges and vertices, so you have more control over how tight the SubD patching is fitted. A very, very cool plugin which, after taking a bit of time to learn, will be most valuable in everyone's toolset!
                                    The rendering is Podium overlayed with a line render from SU.
                                    http://www.gadgetplugins.com/chippstuff/planesketch3.jpg
                                    • jujuJ Offline
                                      juju
                                      ๐Ÿ˜ฒ All together now, SWEET! ๐Ÿ˜
                                        kwistenbiebel
                                        That's cool stuff...So if I understand well, you can keep on modeling the low poly proxy and it will automatically update the rounded object right?
                                        What would happen if the low poly object has textures applied?
                                        Do they hold ?
                                        @Whaat,
                                        Great job man !
                                          chippwalters
                                          Yup...that's the idea. IMO, Dale has done a darn good job with workflow. While you can auto apply textures, it does take longer. But, you can apply them at the end when you upscale your Sub-Divisions for your final model. For me, it's a pretty intuitive interface and workflow.
                                          • erikBE Offline
                                            erikB
                                            Keeps looking fantastic !! ๐Ÿ˜
                                            Come on Beta testers find those bugs (if there are any ?? ๐Ÿ˜„ )so we all can appriciate this amazing ruby !!
                                            Whaat, fantastic scripting,
                                            erikB
                                            • 13
                                            • 14
                                            • 8 / 14
