    In Development: Subdivide and Smooth
    262 Posts 65 Posters 60.5k Views 65 Watching
      a4chitect
      whaat you rock! I can't wait for this release! you are one of those for whome the human cloning was meant in the first place πŸ˜„ its interesting that you mention mesh smoothing (without subdivision), does it mean we will be able to smooth contour generated surfaces so they will be more natural in shape? good luck with testing
      • F Offline
        Fletch
        😲 can't wait to see it, Whaat...
        (on the 'invite' list, on the 'invite' list, on the 'invite' list)
        http://www.kerkythea.net/phpBB2/images/smiles/eusa_pray.gif
        Fletch
        Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
        • soloS Offline
          By the look and feel of it I think the name should be 'Organix' as it does give one the abllity to model organically.
          • W Offline
            Whaat
            Can someone post a complicated contour generated surface? I would like to test this. Thanks.
              remus
              Is this any good whaat? might be a bit simple for your purposes, but it was good fun to make πŸ˜›
              whaat contours.skp
              • W Offline
                Whaat
                Thanks remus,
                Here are the results:
                First image is the original surface generated from contours
                Second image is the same surface after performing vertex averaging (same number of polys)
                Third image is the surface after performing two subdivision and smooth iterations
                It seems like vertex averaging will be very useful to generate more realistic landscape surfaces without increasing poly-count. The only problem is that the the resulting surface will no longer coincide with the contours, so real-world accuracy is lost. There is no easy way to change this so don't ask πŸ˜„
                original surface
                Mesh smoothing (vertex averaging without subdivision)
                after two subdivision and smooth iterations
                  todd burch
                  Just tell them it's an erosion feature thrown in for no charge.
                  • Mike LuceyM Offline
                    Mike Lucey
                    πŸ˜†
                      a4chitect
                      brilliant whaat - exactly as expected - the surface is much more natural, as for the accuracy - I guess the the vertex-averaged surface could meet the controur lines by simply moving it along the Z axis a bit, and even if they can't touch everywhere - the result is better for its smoothness, you can't take the contours for benchmarking since their accuracy is fairly limited too πŸ˜‰
                      maybe performing a test could prove my point>
                      1. create a curved surface with the Smoove tool
                      2. generate contours either by the dedicated script, or by intersecting with equidistant planes
                      3. group contour lines and create a surface by using the sandbox tools
                      4. paint this surface a different color from the original
                      5. make a copy (change the color) of this new surface and apply your script
                      6. compare original surface with both new surfaces
                      whaat thanks for making sketchup better, can't wait for you to release.
                        GUNAWAN W
                        oh dear God, please give this guy more power to made this script available to everyone soon. β˜€
                          kwistenbiebel
                          Yummy !
                          Terrific results as far as I see.
                          This together with a 'wrap texture around object' feature could possibly make other 3d party organic model software trash can material.
                          Good stuff Whaat!
                          • W Offline
                            wikii
                            I wrote script below to simulate whaat's.It works,but not perfect
                            class Smooth_contours
                               attr_reader ;author,;date,;ver
                               def initialize
                                  @author="Wikii"
                                  @date="20080402"
                                  @ver="0.01"
                                  @mm=Sketchup.active_model
                                  @fs=@mm.selection.to_a.delete_if{|x| x.class!=Sketchup;;Face}
                                  do_Smooth_contours if @fs.length>0
                               def center_point point3ds
                                  re=Geom;;Point3d.new(0,0,0)
                                  num=0
                                  0.upto( point3ds.length-1){|x|
                                     if point3ds[x].class==Geom;;Point3d
                                        re.x+=point3ds[x].x
                                        re.y+=point3ds[x].y
                                        re.z+=point3ds[x].z
                                        num+=1.0
                                     else #weighted
                                        re.x+=point3ds[x][0].x*point3ds[x][1]
                                        re.y+=point3ds[x][0].y*point3ds[x][1]
                                        re.z+=point3ds[x][0].z*point3ds[x][1]
                                        num+=point3ds[x][1]
                                  re.x/=num
                                  re.y/=num
                                  re.z/=num
                                  re
                               def open_vertex? v
                                  v.edges.each{|x|
                                     return true if x.faces.to_a.delete_if{|y| !@fs.include?(y)}.length<2
                                  return nil
                               def face_center fc
                                  Geom;;Point3d.new center_point(fc.vertices.to_a.collect{|xx| xx.position})
                               def do_Smooth_contours
                                  group_entities=@mm.active_entities.add_group.entities
                                  vertices=[]
                                  vertices_info={}
                                  @mm.start_operation "123"
                                  n=0
                                  @fs.each{|x|
                                     n+=1.0
                                     Sketchup;;set_status_text "Finished #{(n/@fs.length*1000).to_i/10.0}%"
                                     cen=face_center(x)
                                     x.vertices.each{|y|
                                        if !vertices.include?(y) and !open_vertex?(y)
                                           vertices<<y
                                           #~ tmp0=y.position
                                           #~ tmp=center_point(y.faces.to_a.collect{|z| [face_center(z),z.area]})
                                           tmp=center_point(y.faces.to_a.collect{|z| face_center(z)})
                                           #~ tmp0.z=(tmp0.z+tmp.z)/2.0
                                           #~ vertices_info[y]=center_point([tmp,tmp0]           )
                                           vertices_info[y]=tmp
                                  @ee=Sketchup.active_model.active_entities
                                  puts @ee
                                  vertices.each{|x|
                                     t=Geom;;Transformation.new(vertices_info[x]-x.position)
                                     @ee.transform_entities(t, x)
                                  @mm.commit_operation
                            Smooth_contours.new
                              a4chitect
                              thanks wikii, nice script you've put together so quickly! here is a resulting surface for illustration. and your script with a plugins menu entry added to just place in the plugins folder
                              http://img255.imageshack.us/img255/8932/smoothscripteo5.th.jpg
                              wikii's smooth surface script
                              illustration comparing surface accuracy after smooth
                              • RayOchoaR Offline
                                RayOchoa
                                It would be great if you could do a script that could make high poly models low poly. It would be awsome.
                                CaR DeSiGnS bY mE
                                http://ray-ochoa.com
                                • jenujacobJ Offline
                                  jenujacob
                                  holy moly! this is simply terrrific!
                                  how long did the sub division take coen?
                                  • erikBE Offline
                                    erikB
                                    amazing 😲
                                    Coen, would it also be possible to leave the 'knife -like features' on the claw as they where ( I mean not subdivised (and rasor scharp πŸ˜„ ) or is the whole model always subdivised ?
                                    erikB
                                    • sk.lionS Offline
                                      sk.lion
                                      wow, i cant believe my eyes, this is going to be an awsome script to use!
                                      • W Offline
                                        Whaat
                                        Hi all,
                                        I am looking for one more beta tester at the moment. I need someone with a lot of free time on their hands (anyone??) I am worried that the current testers are too busy to test and post bugs. Is there anyone out there who could commit to spending a LOT of time testing over the next week? First come first serve. Please respond right here.
                                          Daniel S
                                          Here!
                                          • chippwaltersC Offline
                                            chippwalters
                                            I can help. I already sent you a private message yesterday about this. I'm currently doing a project which could benefit. Plus, I've experience in scripted solutions.
                                            http://www.vuetoolbar.com/VueToolbarCover/default.htm
                                            Currently working with Cross-Reality technologies
                                            • 13
                                            • 14
                                            • 7 / 14
