    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • urgenU Offline
      urgen
      M-m-m-many thanks to Fredo6 ! very conveniently! 😍 ...
      ...and let's write it in the end in "jointpushpull.rb" :
      UI.add_context_menu_handler do |menu|
      menu.add_separator
      menu.add_item("Joint Push Pull ") { JointPushPull.execute 'J' }
      menu.add_item("Vector Push Pull ") { JointPushPull.execute 'V' }
      menu.add_item("Normal Push Pull ") { JointPushPull.execute 'N' }
      menu.add_item("Undo") { JointPushPull.undo }
      menu.add_item("Redo") { JointPushPull.redo }
       ....right click mouse we select the  face and activate skript board Simultaneously :stuck_out_tongue: ...Process of drawing will be faster! :tada:
      --pupil forever...------
      • fredo6F Offline
        Urgen,
        Very good idea and quite natural in Sketchup.
        I updated the files in the script repository (also with non blurry icons).
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708&p=42783#p42783
        • PixeroP Offline
          Pixero
          There is a bug in the latest version there should be a ] in this line:
          menu.add_item(Traductor[DLG_MnuRedo]) { JointPushPull.redo }
          • fredo6F Offline
            Oops...!!
            Updated with correct code in Ruby repository
            • boofredlayB Offline
              boofredlay
              Is it possible for this script to explode the curve after it is run? Or at least segment it into parts. It would cut down on a step if you are trying to erase lines for a cleaner face. See image.
              I put precisely some code to keep curves on the original surface (to be as less destructive as possible). Note however that the generated corresponding contour is not welded as a curve. Is it the situation you have?
              The generated contour is not welded correct.
              The original is however. I did another test after installing the latest and I get conflicting results. The top ellipse is broken into 2 welded curves that do not correspond the the new JPP created. The bottom ellipse stays completely intact.
              See images.
              Again, thanks for this script.
              • fredo6F Offline
                Coen
                If you scale uniformly a surface, it will never match the original (think of a sphere for instance). However, this is somehow an approximate way to offset its contour, while preserving the overall shape of the surface.
                With the first method (only offset the borders), you just use the shape of the outer borders and ignore the ones which are inside. So if you offset by a large distance, you will certainly 'dilute' the shape of the surface.
                Both methods have their own benefits and drawbacks, and both can be implemented via a script.
                That's what I meant.
                • X Offline
                  xrok1
                  where is this offset tool?????
                  • FletchF Offline
                    Fletch
                    beautiful, Fredo... simply fantastic. Thank you so much for your generosity in sharing!
                    Fletch
                      mateo soletic
                      Thanks for a great script.
                      [Concept Illustrations](http://concept-illustrations.com/)
                      • urgenU Offline
                        urgen
                        ...Here I have applied this script, very pleasant in work.... Thanks once again! πŸ‘
                        • erikBE Offline
                          erikB
                          Thanks fredo for this wonderfull new tool. Works like a charme 😍 and with the use of the icons it seems like if they have always been part of the original program. GREAT scripting !!!
                          erikB
                          • ToboboT Offline
                            Tobobo
                            WOW!!
                            All my SU life i've been waiting for this!
                            Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You
                            Toby
                            Philippians 4:13
                            • jim smithJ Offline
                              jim smith
                              I must add by belated THANKS!!! Fredo for this super, great, etc. tool. As usual, I am a bit late finding such gems, but glad I found it now since next week I will be working on a curvy building project that will now be much easier to model.
                              Glad to "bump" this file up to the top of the list so maybe more late comers can find it.
                              Spectacular job - again - many thanks
                              "Out of clutter find simplicity,
                              from discord find harmony,
                              In the middle of difficulty lies opportunity"
                              Albert Einstein
                              • sk.lionS Offline
                                sk.lion
                                Awsome, yet another great tool for creating things like stairs. And the ofset tool for the curved surfaces would be great too.
                                  Bryden
                                  Great tool πŸ‘ πŸ‘ the normal push pull reminds me of the extrude tool in Wings 3d which i've always liked.
                                  • ToboboT Offline
                                    Tobobo
                                    I have just used this Ruby to create a lavender hedge on to of contour grass mounds.
                                    It has saved me days (well maybe hours) in time.
                                    Thanks Mate
                                    Toby
                                    Toby
                                    Philippians 4:13
                                    • ely862meE Offline
                                      ely862me
                                      wooooow, i want that offset tool :-O,it s a very usefull tool,until this i have to do the contour by hand on curved surfaces. U*re the man!!!
                                      UPDATE After searching i realised that isn t done yet,but i ll wait for it πŸ˜’ πŸ˜„ πŸ˜†
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                        thinkbuild
                                        Cher M. Fred,
                                        Your script is awesome. But, I've installed it but it seems to be crashing everytime on my mac. Not sure what I am doing wrong. I got the old version to work fine. This new one - 20 Feb 2008 - loads, icons are crisp and beautiful. I select a face, pull it out - even just one face - and then, progress bar pops, looks nice ... freeze ... pause - su disappears. ;(
                                        Has anyone else seen this? I am running su pro 6/ mac leopard/ intel 2.4mhz/ 3GB ram .... ? What to do?
                                        Perhaps it is my installation ... ?
                                        Happy for any advice.
                                        Merci bien en avance et best from Berlin,
                                        Jason
                                        • fredo6F Offline
                                          Thinkbuild,
                                          I did not test the version on Mac as I have no Mac myself, but I guess there are other users on this platform.
                                          I did not have reports on crash either since I published the script, but that does not mean nobody had any.
                                          The best at this stage is to post the model so that we can have a look
                                          • FletchF Offline
                                            Fletch
                                            ely862me,
                                            what are you talking about? it's out... avail. and works quite well! download it from the ruby repository πŸ˜‰
                                            Fletch
                                            • 18
                                            • 19
                                            • 2 / 19
