    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      Daniel S
      About the icons.. i made the two that are blurry on mac on a different day.. so perhaps i export the icons with different settings...
      Jeff here i attach the two icons again... tell me if this fixes the problem (i don´t have a Mac for testing).
      And about the offset the best method for me will be option nº 1: Only offsets the external border edges of the surface.
      Daniel S
      Icons for Mac.zip
      offset.skp
      • U Offline
        urs0815
        hallo Daniel,
        I´ve tested the 2 icons on my mac -> same problem as before 😕
        but the icon of the very first edition of jpp were OK, so we can use them 😉
        urs
          Daniel S
          Here i made them with other settings... try this ones please
          Icons for Mac2.zip
          • jeff hammondJ Offline
            [EDIT] daniel posted the latest update while i was typing this reply.. iconsformac2 are correct..
            i switched to the first icons and they worked ok..
            the new pngs display as sharp in all other apps except sketchup.. i compared the blurry ones against the sharp ones in PS and found the image sizes are different.. i changed the blurry J & V files to the following size..
            ..and now the new icons look ok..
            it's a strange thing to me because the new icons are all 24x24 px.. it's just the resolution and wxh are set different but i would have thought they would display on a monitor according to the pixel size alone..
            fwiw - the blurry icons are set to 24 x 24 px... .08 x .08 inches .... resolution 299.974..
            • urgenU Offline
              urgen
              M-m-m-many thanks to Fredo6 ! very conveniently! 😍 ...
              ...and let's write it in the end in "jointpushpull.rb" :
              UI.add_context_menu_handler do |menu|
              menu.add_separator
              menu.add_item("Joint Push Pull ") { JointPushPull.execute 'J' }
              menu.add_item("Vector Push Pull ") { JointPushPull.execute 'V' }
              menu.add_item("Normal Push Pull ") { JointPushPull.execute 'N' }
              menu.add_item("Undo") { JointPushPull.undo }
              menu.add_item("Redo") { JointPushPull.redo }
               ....right click mouse we select the  face and activate skript board Simultaneously :stuck_out_tongue: ...Process of drawing will be faster! :tada:
              --pupil forever...------
              • fredo6F Offline
                Urgen,
                Very good idea and quite natural in Sketchup.
                I updated the files in the script repository (also with non blurry icons).
                http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708&p=42783#p42783
                • PixeroP Offline
                  Pixero
                  There is a bug in the latest version there should be a ] in this line:
                  menu.add_item(Traductor[DLG_MnuRedo]) { JointPushPull.redo }
                  • fredo6F Offline
                    Oops...!!
                    Updated with correct code in Ruby repository
                    • boofredlayB Offline
                      boofredlay
                      Is it possible for this script to explode the curve after it is run? Or at least segment it into parts. It would cut down on a step if you are trying to erase lines for a cleaner face. See image.
                      I put precisely some code to keep curves on the original surface (to be as less destructive as possible). Note however that the generated corresponding contour is not welded as a curve. Is it the situation you have?
                      The generated contour is not welded correct.
                      The original is however. I did another test after installing the latest and I get conflicting results. The top ellipse is broken into 2 welded curves that do not correspond the the new JPP created. The bottom ellipse stays completely intact.
                      See images.
                      Again, thanks for this script.
                      • fredo6F Offline
                        Coen
                        If you scale uniformly a surface, it will never match the original (think of a sphere for instance). However, this is somehow an approximate way to offset its contour, while preserving the overall shape of the surface.
                        With the first method (only offset the borders), you just use the shape of the outer borders and ignore the ones which are inside. So if you offset by a large distance, you will certainly 'dilute' the shape of the surface.
                        Both methods have their own benefits and drawbacks, and both can be implemented via a script.
                        That's what I meant.
                        • X Offline
                          xrok1
                          where is this offset tool?????
                          • FletchF Offline
                            Fletch
                            beautiful, Fredo... simply fantastic. Thank you so much for your generosity in sharing!
                            Fletch
                              mateo soletic
                              Thanks for a great script.
                              Concept Illustrations
                              • urgenU Offline
                                urgen
                                ...Here I have applied this script, very pleasant in work.... Thanks once again! 👍
                                • erikBE Offline
                                  erikB
                                  Thanks fredo for this wonderfull new tool. Works like a charme 😍 and with the use of the icons it seems like if they have always been part of the original program. GREAT scripting !!!
                                  erikB
                                  • ToboboT Offline
                                    Tobobo
                                    WOW!!
                                    All my SU life i've been waiting for this!
                                    Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You Thank You
                                    Toby
                                    Philippians 4:13
                                    • jim smithJ Offline
                                      jim smith
                                      I must add by belated THANKS!!! Fredo for this super, great, etc. tool. As usual, I am a bit late finding such gems, but glad I found it now since next week I will be working on a curvy building project that will now be much easier to model.
                                      Glad to "bump" this file up to the top of the list so maybe more late comers can find it.
                                      Spectacular job - again - many thanks
                                      "Out of clutter find simplicity,
                                      from discord find harmony,
                                      In the middle of difficulty lies opportunity"
                                      Albert Einstein
                                      • sk.lionS Offline
                                        sk.lion
                                        Awsome, yet another great tool for creating things like stairs. And the ofset tool for the curved surfaces would be great too.
                                          Bryden
                                          Great tool 👍 👍 the normal push pull reminds me of the extrude tool in Wings 3d which i've always liked.
                                          http://img7.imageshack.us/img7/8487/googlesketchupuserbarzh3.jpg
                                          • ToboboT Offline
                                            Tobobo
                                            I have just used this Ruby to create a lavender hedge on to of contour grass mounds.
                                            It has saved me days (well maybe hours) in time.
                                            Thanks Mate
                                            Toby
                                            Toby
                                            Philippians 4:13
                                            • 18
                                            • 19
                                            • 2 / 19
