    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Follow Me tool not working with curve
    21 Posts 11 Posters 11.6k Views 11 Watching
    • X Offline
      xxhellfirexx
      I find the Follow Me tool, even after lots of practice, to be the most difficult tool to master. Below is an image of a case where I am trying to drag a shape around a track to form a curve for the edges of the keyboard I am modeling.
      http://img407.imageshack.us/img407/2689/followme1ip0.th.jpg
      http://img181.imageshack.us/img181/6014/followme2ng0.th.jpg
      http://img181.imageshack.us/img181/8057/followme3iz0.th.jpg
      The problem is that the Follow Me tool skipped the beveling of the corners. This may be that the corner is too sharp or the shape is too small. I am not sure what exactly is the cause of the problem. The last image is my "attempt" to do the corners although it looks quite horrible.
      I know these images are not too helpful so I decided to attach the .skp file. Thanks for your help!
      follow me help.skp
        alan wood
        I notice that you work with small measurements the same as myself. My solution to this problem was to
        1 make the model in your case the rectanglular shape including the curve required.
        2 group the model, scale up by a scale of 10 or 100.
        3 ungroup the model, then carry out the follow me operation at this incrreased size.
        This should then work. You will also have to use the same scaling up method for other shapes when working with small measurments.
        cheers
        Alan
          Alan is right, SU can "miss" faces when they get below say 1/16" (or about a millimeter). This is particularly so with the follow me and the intersect tools (both may end up with really small faces).
          • X Offline
            xxhellfirexx
            That did the trick. Thanks so much!
            • Joe WoodJ Offline
              Joe Wood
              Another tip XX is to reduce the number of segments in your arc, before you use the Follow Me.
              R click the arc, choose Entity Info, and change the number of segments. I usually only use three, and after they're Softened you can't really see the segments anyway.
              Joe Wood
              woodsshop.com/
              • AnssiA Offline
                Anssi
                Also note that the Follow Me tool is unable to turn a corner cleanly with an interior radius of 0. In these cases it always results in an odd bevel and a couple of small faces that look like the wings of a small butterfly.
                Anssi
                  Julius
                  Anssi
                  [attachment=0:1rbkp9xa]<!-- ia0 -->corner.jpg<!-- ia0 -->[/attachment:1rbkp9xa]
                  this one is very unpleasant...anyway, i had the same problem with the follow me tool and the scaling tool is definitely the solution.
                    The usual workaround for such a problem is either to do the extrusion along a curvy (not cornered) path (like in Dave's tutorial here) or to create a dome (hemisphere), quarter it and simply move the quarter hemisphere into that place in the corner.
                      Julius
                      well, in dave's tutorial there's still this littele hole:
                      http://img175.imageshack.us/img175/1007/radiusedcubeli6.png
                        Hm... ๐Ÿ˜’
                        • Wo3DanW Offline
                          Wo3Dan
                          @gaieus said:
                          Hm... ๐Ÿ˜’
                          Gaieus, maybe you should switch avatars with Julius!? ๐Ÿ˜Ž
                          Anyway, this matter was discussed by Noel Dent, Gully and .... Gaieus some (exactly) 8 months ago:
                          http://groups.google.com/group/sketchuphowto/browse_frm/thread/23b55b464cc16456/6b0c0732cc8b2bb6?lnk=gst&q=noel+gully+corner#6b0c0732cc8b2bb6
                          I think there was a follow up with file to explain further.
                          This 'bug' has been known for quite a while. You should close the gab by zooming in and do some stitching.
                            GreenToaster
                            Here's another example of what you can do with the Follow Me tool . . . it's not just for planar (flat) applications, as illustrated in this image . . .
                            If you really want something you won't ever stop pursuing it.
                              Wodan I know it does this "trick" when coming around a right angle corner but here the path was a rounded one.
                              I'd've bet that there should've been something like this result:
                              http://www.sketchucation.com/forums/scf/sas/Newbie/FollowMe.jpg
                              [Click on the image to download the skp file]
                              Well, to tell the truth it is Gaius Caesar Augustus Germanicus (Caligula) on the coin. I don't think Julius wanted my avatar... ๐Ÿ˜’
                              Edit: I see now the difference. Dave placed the face to be extruded inside the box (thus creating the glitch for the radius of the face was smaller than the radius of the rounded edge). In my example I placed it outside so the face could smoothly follow the path.
                                Surely Brad it can be used on non-planar paths, too - it will just twist and distort so if you wanted an even extrusion, it would be a very hard work to be precise.
                                  Julius
                                  no, thanks, i prefer homer... ๐Ÿ˜‰
                                  • AnssiA Offline
                                    Anssi
                                    Julius,
                                    Here's Homer for you ๐Ÿ˜„
                                    Cheers
                                    Anssi
                                      Julius
                                      ๐Ÿ˜† well, actually i didn't mean that one ๐Ÿ˜†
                                      • boofredlayB Offline
                                        boofredlay
                                        How is this one?
                                        http://www.sideshowtoy.com/mas_assets/large/8501.jpg
                                          Julius
                                          that's better ๐Ÿ˜† [/off-topic]
                                            topbobster
                                            @alan wood said:
                                            cheers
                                            Alan
                                            Thanks, Alan, you're a star. Sometimes the simplest things make the difference....
                                            Rob
                                            • 2 / 2
