    Follow Me tool not working with curve
    21 Posts 11 Posters 13.0k Views 11 Watching
      @julius said:
      well, in dave's tutorial there's still this littele hole:
      Hm... πŸ˜’
      • Wo3DanW Offline
        Wo3Dan
        @gaieus said:
        Hm... πŸ˜’
        Gaieus, maybe you should switch avatars with Julius!? 😎
        Anyway, this matter was discussed by Noel Dent, Gully and .... Gaieus some (exactly) 8 months ago:
        http://groups.google.com/group/sketchuphowto/browse_frm/thread/23b55b464cc16456/6b0c0732cc8b2bb6?lnk=gst&q=noel+gully+corner#6b0c0732cc8b2bb6
        I think there was a follow up with file to explain further.
        This 'bug' has been known for quite a while. You should close the gab by zooming in and do some stitching.
          GreenToaster
          Here's another example of what you can do with the Follow Me tool . . . it's not just for planar (flat) applications, as illustrated in this image . . .
          If you really want something you won't ever stop pursuing it.
            Wodan I know it does this "trick" when coming around a right angle corner but here the path was a rounded one.
            I'd've bet that there should've been something like this result:
            http://www.sketchucation.com/forums/scf/sas/Newbie/FollowMe.jpg
            [Click on the image to download the skp file]
            Well, to tell the truth it is Gaius Caesar Augustus Germanicus (Caligula) on the coin. I don't think Julius wanted my avatar... πŸ˜’
            Edit: I see now the difference. Dave placed the face to be extruded inside the box (thus creating the glitch for the radius of the face was smaller than the radius of the rounded edge). In my example I placed it outside so the face could smoothly follow the path.
              Surely Brad it can be used on non-planar paths, too - it will just twist and distort so if you wanted an even extrusion, it would be a very hard work to be precise.
                Julius
                no, thanks, i prefer homer... πŸ˜‰
                • AnssiA Offline
                  Anssi
                  Julius,
                  Here's Homer for you πŸ˜„
                  Cheers
                  Anssi
                    Julius
                    πŸ˜† well, actually i didn't mean that one πŸ˜†
                    • boofredlayB Offline
                      boofredlay
                      How is this one?
                      http://www.sideshowtoy.com/mas_assets/large/8501.jpg
                        Julius
                        that's better πŸ˜† [/off-topic]
                          topbobster
                          @alan wood said:
                          I notice that you work with small measurements the same as myself. My solution to this problem was to
                          1 make the model in your case the rectanglular shape including the curve required.
                          2 group the model, scale up by a scale of 10 or 100.
                          3 ungroup the model, then carry out the follow me operation at this incrreased size.
                          This should then work. You will also have to use the same scaling up method for other shapes when working with small measurments.
                          cheers
                          Alan
                          Thanks, Alan, you're a star. Sometimes the simplest things make the difference....
                          Rob
                            @Rob, making a group before scaling up only to explode it once you have is a waste of time. You can select the geometry and scale it up if you want. Scale down afterward. Here's another method that I think is easier. Start by making the profile and path for the Follow Me operation at the regular size. Make a component of the lot. Copy the component (Move/Copy) and scale the copy up by a factor of 10 or 100 or something. Open the large copy for editing, run Follow Me and do whatever else you need to do. Then close the large component to exit edit mode and delete it. Return to the original component and the work is done.
