    Modlumi - Easy 3D modelling
    414 Posts 9 Posters 74.0k Views 9 Watching
      Take your time! πŸ™‚
      Waiting the requests with confidence! πŸ™‚
      • ntxdaveN
        ntxdave @pilou
        @pilou said:
        Seems there is a little bug with the Draw Helper Line guides but
        Draw a Rectangle
        Press T
        Don't snap on a middle of a segment!
        That must works as expected! πŸ™‚
        Snap middle (or a corner) gives a Point Guide!
        @pilou I also found out that another easy was to create some guides is to just draw a line perpendicular to the way you want to create a guide and then use the measure tool to create a guide(s). I also did some fooling around and found that if you want to create a number of guides that are the same distance apart, you can select a guide and then use the move+ctrl keys to create multiple copies of the guide.
        Just thought I would pass along some additional "exploring".
        Press F1...thank me later
        • ntxdaveN
          ntxdave @pilou
          Draw a Rectangle
          Press T
          I did some testing and found that you also can create guides if you just draw a line that is perpendicular to the place you want to create the guides and then use that line to draw the guide(s).
          pilouP 1 Reply Last reply
            pilou @ntxdave
            Yes of course with a cross guide if you start from the middle of this line: πŸ˜‰
            ntxdaveN 1 Reply Last reply
            • ntxdaveN
              ntxdave @pilou
              No, you do not have to click in the middle of the line. I was able to do it from multiple locations on the line.
                I said bug but maybe not one: πŸ˜‰
                The cross guide from the mid point
                Other case works fine in any 3D space : your guide will be drawn at any snap except the extremity of your line in any 3D direction!
                Look this gif
                When you start from a middle or extremity line you will obtain a Cross guide, when you click
                a snap elsewhere on the line you will obtain a guide line! πŸ˜‰
                In fact there is no bug just impossibility to draw lines guides from the snap Middle of something or extremities !
                Maybe a solution will be to separate Cross Guide / Lines Guides! πŸ™‚
                But also a request possibility to draw GuideLines from intersections of Guide Lines! πŸ˜‰
                (but we can yet draw Lines between intersections of Guide Lines ! πŸ˜‰
                KrassK 1 Reply Last reply
                • KrassK
                  Krass @pilou
                  Hello,
                  I know, of course, that this promotional video for ModLumni won’t be selected, but it’s an exercise full of good intentions...
                  Krass
                  Reply Quote 2
                  • pixelcruncherP
                    @krass It's awesome! I can't get you nominated on film festivals though πŸ™‚
                      Marvelous animation! πŸ‘ πŸ‘ πŸ‘
                        Some fractal rotations ! πŸ™‚ render free Vizcom
                        alt text
                        • pixelcruncherP
                          Modlumi 0.29: HDR environments, powered by Poly Haven
                          Your models can now sit in a real place. The new Environment panel surrounds your model with an HDR panorama that shows behind it and lights it.
                          House in the Lilienstein forest HDRI
                          Pick one from the built-in HDRI library, powered by Poly Haven's free CC0 collection, or import your own .hdr or .exr file. Turn the panorama, set its exposure and place the sun where the panorama's sun is. Each scene can keep its own environment.
                          The Environment panel with the Poly Haven HDRI library
                          Switching the mood is one click in the library:
                          The same house at sunset with The Sky Is On Fire
                          Also in 0.29:
                          • The 3D view now sits between the docked panels instead of under them.
                          • Plugins can capture the viewport as an image.
                          • Edges imported from SketchUp keep their own layer, so hiding a layer such as a sky dome now hides its edges too.
                          • The sky's horizon stays level while you orbit.
                          Full release notes: https://modlumi.com/docs/release-notes/
                          HDRIs in these images: "Lilienstein" by Andreas Mischok and "The Sky Is On Fire" by Greg Zaal and Rico Cilliers, both from Poly Haven.
                            Cool! πŸ‘“
                            Waiting all little requests πŸ™‚
                              A very poor pop reference. "I am in awe of your coding skills", Thomas.
                              • ntxdaveN
                                ntxdave
                                Am I doing something wrong?
                                • list itemWhen I start Modlumi 0.28 and then go to Help and click on the Check for Updates, it says I am running the latest version. So, how do I update to version 0.29?
                                • list itemI also started the web version and it also said that version 0.28 is the latest version.
                                • 17
                                • 18
                                • 19
                                • 20
                                • 21
                                • 21 / 21
