    Modlumi - Easy 3D modelling
    410 Posts 9 Posters 71.4k Views 9 Watching
      Take your time! πŸ™‚
      Waiting the requests with confidence! πŸ™‚
      • ntxdaveN
        ntxdave @pilou
        @pilou said:
        Seems there is a little bug with the Draw Helper Line guides but
        Draw a Rectangle
        Press T
        Don't snap on a middle of a segment!
        That must works as expected! πŸ™‚
        Snap middle (or a corner) gives a Point Guide!
        @pilou I also found out that another easy was to create some guides is to just draw a line perpendicular to the way you want to create a guide and then use the measure tool to create a guide(s). I also did some fooling around and found that if you want to create a number of guides that are the same distance apart, you can select a guide and then use the move+ctrl keys to create multiple copies of the guide.
        Just thought I would pass along some additional "exploring".
        Press F1...thank me later
        • ntxdaveN
          ntxdave @pilou
          Draw a Rectangle
          Press T
          I did some testing and found that you also can create guides if you just draw a line that is perpendicular to the place you want to create the guides and then use that line to draw the guide(s).
          pilouP 1 Reply Last reply
            pilou @ntxdave
            Yes of course with a cross guide if you start from the middle of this line: πŸ˜‰
            ntxdaveN 1 Reply Last reply
            • ntxdaveN
              ntxdave @pilou
              No, you do not have to click in the middle of the line. I was able to do it from multiple locations on the line.
                I said bug but maybe not one: πŸ˜‰
                The cross guide from the mid point
                Other case works fine in any 3D space : your guide will be drawn at any snap except the extremity of your line in any 3D direction!
                Look this gif
                When you start from a middle or extremity line you will obtain a Cross guide, when you click
                a snap elsewhere on the line you will obtain a guide line! πŸ˜‰
                In fact there is no bug just impossibility to draw lines guides from the snap Middle of something or extremities !
                Maybe a solution will be to separate Cross Guide / Lines Guides! πŸ™‚
                But also a request possibility to draw GuideLines from intersections of Guide Lines! πŸ˜‰
                (but we can yet draw Lines between intersections of Guide Lines ! πŸ˜‰
                KrassK 1 Reply Last reply
                • KrassK
                  Krass @pilou
                  Hello,
                  I know, of course, that this promotional video for ModLumni won’t be selected, but it’s an exercise full of good intentions...
                  Krass
                  Reply Quote 2
                  • pixelcruncherP
                    @krass It's awesome! I can't get you nominated on film festivals though πŸ™‚
                      Marvelous animation! πŸ‘ πŸ‘ πŸ‘
                        Some fractal rotations ! πŸ™‚ render free Vizcom
                        alt text
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 21 / 21
