    Modlumi - Easy 3D modelling
    400 Posts 9 Posters 63.5k Views 9 Watching
      Modlumi online is 0.28 ??
      And here 0.27 ! πŸ™‚
      https://modlumi.com/app/
        About the Sweep 2 Rails : we can't Click again on the Rail 1 as Rail 2 for make a Sweep One rail ? πŸ˜‰
        alt text
        alt text
        alt text
          Sorry always bug! πŸ™‚
          Can't All Push Pull!
          bug128.zip
          But found it! It's because one or more faces slap on another one , generaly at a crossing!
          So this bug can't be solved! Just make one by one the fault faces! πŸ™‚
          • ntxdaveN
            ntxdave
            I wish I could understand/learn how you create stuff like this. Not necessarily the renders, basically the models itself (and you are doing this in Modlumi).
            Press F1...thank me later
              @ntxdave
              Make any Object : Make a Group
              Select this Group
              Copy Move it (M + CTRL)
              Type / 5 = 6 Objects (Original + 5 between original and second) or Type * 5 = 6 objects( original + behind distance original and second)
              Type 50% then Enter = Your 6 objects a decrease Size from the first Original to last
              Select All : make a Group
              etc... exactely the same with Rotate! (Q)
              It's a sort of Fractal process! πŸ™‚
              All was made with 5 as number of /, and 50% as reduce size generation !
              With training you will make that in seconds!
              For Size you must take an Handle(s) first!
              Size was not use in this Gif : Only Move Copy and Rot!
              Don't forget to make a Group or a Component after a finished command!
              The Last line for example is: Make a group, Make a Big Move with Ctrl then type /5 then type 50% Enter πŸ™‚
              alt text
                Search inside Modlumi a good view then make Snap Shot or save image inside ModLum
                you can hide the axes inside ModLumi or ask the Ai to make it! πŸ™‚
                alt text
                Ask birds in free Vizcom
                alt text
                Variations Vizcom...export image
                alt text
                then Drag & Drop inside Gemin section Image πŸ™‚ Prompt was : make a tapestry from this image
                Truely a game's boy as I said previouly! πŸ™‚
                alt text
                etc...
                Reply Quote 2
                  @pixelcruncher
                  Can you precise the Sweep process (Follow me) and limit of it ?
                  Because sometime seems nothing works as expected!
                  My personal research πŸ™‚
                  Section (profil ) must be // to the ground!
                  Section can be or not attached to the path!
                  Section must have a surface!
                  Section must be ouside the Path surface!
                  Path can be a surface or a simple segment(s) perimeter!
                  so you can select a surface or some segments!
                  Sweep is not Multiple!
                  This follow one is a bug!
                  Works when i take the entiere path (4 segments) but fails when i take less 4 segments!!!
                  Bug129.zip
                    Request : Snap of the Center of a Circle! Or a Polygon... ( I can draw a diameter but... )
                    • ntxdaveN
                      ntxdave
                      As usual, I have a silly question: Does anyone using version 0.28 (either app or browser version) have any problem trying to draw guides?
                      I think I must be doing something wrong; I cannot draw guides in either version.
                        Seems there is a little bug with the Draw Helper Line guides but
                        Draw a Rectangle
                        Press T
                        Don't snap on a middle of a segment!
                        That must works as expected! πŸ™‚
                        Snap middle (or a corner) gives a Point Guide!
                        ntxdaveN 1 Reply Last reply
                          That also happens with Sketchup as a random result.
                          • ntxdaveN
                            ntxdave @pilou
                            Draw a Rectangle
                            Press T
                            Thanks @pilou for the most part that worked. Hope this issue gets fixed in a future release.
                            • pixelcruncherP
                              Folks, I'm still alive; I've just been a bit focused on RAyscaper and other stuff. Will get back to this and address the feedback & bugs.
                                One thing at a time mate, spread too thin we achieve zero.
                                1 Reply Last reply β™₯
                                • 16
                                • 17
                                • 18
                                • 19
                                • 20
                                • 20 / 20
