    Modlumi - Easy 3D modelling
    401 Posts 9 Posters 65.1k Views 9 Watching
      Search inside Modlumi a good view then make Snap Shot or save image inside ModLum
      you can hide the axes inside ModLumi or ask the Ai to make it! πŸ™‚
      alt text
      Ask birds in free Vizcom
      alt text
      Variations Vizcom...export image
      alt text
      then Drag & Drop inside Gemin section Image πŸ™‚ Prompt was : make a tapestry from this image
      Truely a game's boy as I said previouly! πŸ™‚
      alt text
      etc...
      Reply Quote 2
        @pixelcruncher
        Can you precise the Sweep process (Follow me) and limit of it ?
        Because sometime seems nothing works as expected!
        My personal research πŸ™‚
        Section (profil ) must be // to the ground!
        Section can be or not attached to the path!
        Section must have a surface!
        Section must be ouside the Path surface!
        Path can be a surface or a simple segment(s) perimeter!
        so you can select a surface or some segments!
        Sweep is not Multiple!
        This follow one is a bug!
        Works when i take the entiere path (4 segments) but fails when i take less 4 segments!!!
        Bug129.zip
          Request : Snap of the Center of a Circle! Or a Polygon... ( I can draw a diameter but... )
          • ntxdaveN
            ntxdave
            As usual, I have a silly question: Does anyone using version 0.28 (either app or browser version) have any problem trying to draw guides?
            I think I must be doing something wrong; I cannot draw guides in either version.
            Press F1...thank me later
              Seems there is a little bug with the Draw Helper Line guides but
              Draw a Rectangle
              Press T
              Don't snap on a middle of a segment!
              That must works as expected! πŸ™‚
              Snap middle (or a corner) gives a Point Guide!
              ntxdaveN 1 Reply Last reply
                That also happens with Sketchup as a random result.
                • ntxdaveN
                  ntxdave @pilou
                  Draw a Rectangle
                  Press T
                  Thanks @pilou for the most part that worked. Hope this issue gets fixed in a future release.
                  • pixelcruncherP
                    Folks, I'm still alive; I've just been a bit focused on RAyscaper and other stuff. Will get back to this and address the feedback & bugs.
                    Reply Quote 2
                      One thing at a time mate, spread too thin we achieve zero.
                      1 Reply Last reply β™₯
                      Reply Quote 2
                        Take your time! πŸ™‚
                        Waiting the requests with cionfidence! πŸ™‚
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 21 / 21
