Rayscaper New Releases
With respect, cartoons take as much planning as any graphical media interaction, film. music video etc.
As a definite 'old git' I still love cartoons. Looking forwards to getting a look at yours mate. -
Hey, Rayscaper users!
Rayscaper 1.0.5 is available. You can get it via:
- The SketchUcation store.
- Direct download: Rayscaper_Win_1.0.5.rbz.
I recommend upgrading to the latest version, especially if you have an NVIDIA RTX 50-series graphics card.
What Changed?
- Fix a slow first render on NVIDIA RTX 50-series graphics cards (RTX 5050 to 5090, and the RTX PRO Blackwell cards). The first render could take several minutes before showing an image; Rayscaper now includes a renderer built for these cards, so it starts in seconds.
Full release notes: rayscaper.com/manual/release-notes
Help Me Build the Community
If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
and helps me showcase its capabilities to new users.Follow me on X.
Happy Rendering!
Thomas -
Hello,
thanks.
I wonder why this material becomes brown when adding fur? (even without fur)
I believe the maximum image size for the free tier should be increased. I have been actively sharing my feedback and experience with the software since its early versions, and I think all users deserve a larger limit—it would certainly encourage more people to use the tool for their work and provide input. This is especially important given that the application serves as a vital resource for those with hardware that doesn't support modern GPUs; for instance, I personally use an NVIDIA Quadro K1100M. please
indeed, GPU rendering won't work with your CG. But you can't ask a for a lower price for a pemanent licence
Hello,
An animation that makes no rhyme or reason, but a good exercise for trying to master Animator, Rayscaper, and EffectCraft—a clone of After Effects.
No AI—though perhaps I should have used it to replace the screenwriter and the cinematographer, neither of whom I have on hand. -
Jeezes, dude, this is good! Love it! Very nice work, a very good soundtrack. Do you mind if I share it on social media?
No, of course not!
I promise that I’ll also create some great architectural visualization animations that are in better taste! -
Hello,
It seems that your "animal fur" preset doesn't take the SketchUp texture into account. If I apply the "carpet" preset, it works... but... what would you recommend? It would have been great to be able to use the texture for this cat—which is actually quite good—while still being able to take advantage of the "animal fur" preset.
You have to really pull those values down, fur on most animals is 'suggested' rather than being a huge feature. Cats, unless a long hair variant look like caricatures otherwise.
Thomas,
Connecting Codex to Rayscaper is easy—and since I’m a bit lazy, I asked it to handle that part for me, too.
It works really well; I think it can be a real time-saver for exterior scenes.
Here’s an example of an interior scene.
I’m quite familiar with modeling using Codex in SketchUp, and I find it’s often best to keep the MCP SketchUp server active alongside the Rayscaper connection.
For instance, it’s highly efficient for placing spotlights—a genuine time-saver, as you can ask it to distribute the lights while simultaneously adding the necessary mounting hardware to your SketchUp geometry.
It understands commands well, though you have to wait a moment before telling it to "stop!"—it carries out the modifications in successive stages.
All of this is great, but I quickly hit my daily token limit (I’m on the entry-level ChatGPT plan), and I’ve likely already used up the available resets for this month.
The process can be quite lengthy, and when you’re already fairly proficient with Rayscaper, you sometimes realize you could have done it faster "by hand."
That said, I want to highlight how useful it is for distributing lights—it’s excellent. I also imagine that for exterior projects—I’m saving my tokens for client work—being able to place vegetation and set up the lighting must be truly impressive.
Looking forward to my next experiments!
@Krass, glad to hear that it's working well for you! I hope this feature entices the AI crowd. You can let the AI agent automate a lot of stuff and do the things you want to do by hand. The advantage is that you have 100% control over the outcome, which is not always the case with AI rendering solutions.
Yes, you can use it for exteriors too. You can let it configure scattering for you. It might also be a good starting point for people who aren't proficient with the software; let the AI agent help. My goal is still to have good documentation and to make it intuitive.
@pixelcruncher can this be made to work with a locally hosted model like Ollama?
It would certainly be great if we could use open-source models for designing in SketchUp... since it’s so expensive. I know they aren’t covering their costs yet, but still...
It should work with any model that supports MCP (Model Context Protocol). For the AI agent, Rayscapers simply offers a set of tools (e.g., adjust_material, set_camera, ...). It's just that with smarter models, the results you get will be a lot better. I don't have the hardware to run open-source models, so I'm very happy to hear what the results are. If there are setup problems, happy to help you guys debug them.
Hello,
I’m wondering how to perform a "batch" render for animations. I have everything prepared—several scenes—but for the time being, I don’t see a way to take advantage of the time when I’m away from home: I would like to set up a batch render for multiple SketchUp or Animator scenes, but currently, I can only initiate a render for a single sequence. Regarding SketchUp transitions, that’s expected given how the software works; however, Animator allows for saving and storing multiple films. It seems that with Rayscaper, it is currently only possible to render one animation at a time. -
@krass - I can add that. Instead of selecting a single clip, use a list of clips. Stay tuned; I will try to squeeze it into the next release.
