    Animator: Parametric Animation plugin - Discussion
    249 Posts 56 Posters 144.9k Views 55 Watching
    • fredo6F
      I assume you want the corner to stay along the path.
      If so, then your scaling should be done from the opposite corner handle.
      Here is the file corrected
      ClipSeq_AfterAddingScaling - right handle.skp
        moderatelyfunky
        Thanks for taking the time to answer such a dumb question! I'm starting to get comfortable with Animator and loving it. Thanks again!
        • C
          carlurcia
          I´m having a problem with Animator after not using it for months. I used to put "tracking cameras" for following objects and trying to smooth the transition between the "sketch up cameras". But everything works well except de "tracking cameras" which block the Animator and don´t allow you to continue with the video.
          Sketch up 2020
          Animator_v3.2a
          LibFredo6_v11.6a
          SketchFXEx-3.0.2
          AmbientOcclusionEx-2.8.0
          Thank you very much for any suggestions
          • fredo6F
            @carlurcia said:
            Could you post or PM me the model so that I have a look.
            Many thanks
            • KrassK
              Krass
              Hello,
              I’ve got a decent handle on Animator now (thanks again!). However, I’m not quite sure how to proceed with my current project: I’ve started this little animation, but I want to animate both VU meters in parallel. I’m wondering how best to go about this.
              For this animation, I created a small rectangle that I scale up to gradually cover the indicator lights.
              I need a way to copy and paste this animation so I can position it over the VU meter on the right. Is it possible to copy this rectangle—along with its grouped animation properties? Or, alternatively, can I create a copy and then apply the settings from the first animation to it?
              I do see an option to clone the clip...
              Thanks for your suggestions!
              SketchUp_tnY7qsbzu9.mp4
              I have just paid for my license
              I am also looking for a way to repeat this animation throughout the entire duration of the main clip, without having to copy and paste this short clip multiple times...
              Krass
              • KrassK
                Krass
                Hello,
                I found the solution by taking a closer look at the user manual.
                It’s perfect and couldn’t be simpler. Thanks again for this brilliant program!
                animation.mp4
                Simply select two objects to which the same animation will be applied when creating a new movement.
                Krass
                • KrassK
                  Krass
                  le souci est que je n'arrive pas à répéter cette série de mouvements pour les vu mètre que j'ai convertie en clip. Si j'affecte -1 à a valeur de répétition, (forever) il ne joue qu'une seule fois. Si je place d'autres copies du clip l'une après l'autre, les copies ne jouent pas.
                  Krass
                  • fredo6F
                    Difficile d'aider sans voir le fichier.
                    La repetition suppose que le clip a une duree definie
                    • KrassK
                      Krass
                      Bonsoir,
                      veux tu le fichier?
                      Krass
                      • KrassK
                        Krass
                        SwissTransfer - Send large files securely and free of charge
                        Send up to 50 GB - Free and no registration required - Keep your transfers for 30 days
                        SwissTransfer (www.swisstransfer.com)
                        un lien vers le fichier https://www.swisstransfer.com/dl/01a1bda1-f434-7164-9ea8-a97f73fa6a29
                        mais depuis j'ai installé une extension concoctée par Chat GPT pour un mode sombre sketchup qui marchait très bien et Animator a perdu toute fluidité, la petite animation des vu mètres semble inactive et la lecture dans le viewport du clip est saccadée c'est difficilement utilisable. avant l'installation de l'extension, c'était fluide, je ne comprends pas. Cette extension utilise les palettes Qt (je n'y connaîs rien) et le fait de la désinstaller n'a rien changé. mais je me suis quand même dit qu'il y avait un lien..
                        Krass
                        • KrassK
                          Krass
                          Bonjour,
                          j'ai désactivé les mouvements et le clip présent présents sur la time line, et je fais jouer le film sur un ordi puissant et c'est saccadé....
                          SketchUp_OxKxzZtMLm.mp4
                          Krass
                          • KrassK
                            Krass
                            ici sur ce pc avec une carte graphique laptop NVIDIA rtx 4090, j'ai supprimé tous les films, les clips. Je pars de zéro. Sur deux scènes SU que je destine à être les deux images clé de la prochaine animation j'ai masqué toute la végétation, tout le mobilier qui n'est pas dans le champ.
                            récré juste une animation depuis ces deux scènes et c'est vraiment pas fluide
                            SketchUp_FSiUGKS2xL.mp4
                            Krass
                            • KrassK
                              Krass
                              puis j'ai bien mis le nouveau moteur graphique, copié la chaîne hifi (juste ce qui apparaît dans le champ) et refait un film avec les deux images clé entre deux scènes et, miracle, le film redevient normal.
                              Je rouvre alors le fichier original, et et nouveau l'anime rame... je pourrais bien sûr tout refaire de A à Z, mais j'ai déjà configuré tous les matériaux et lumières, scatter, dans Rayscaper...
                              Krass
                              • KrassK
                                Krass
                                je pense que j'avais préparé l'animation avant d'ajouter tout ce mobilier très lourd... et en suite la lecture est devenue saccadée. Bizarre que par ailleurs les transitions sketchup entre les scènes quand Animator est fermé restent fluides
                                Krass
                                • KrassK
                                  Krass
                                  Hello, in this clip, I can no longer animate objects using translation... I don't understand what's going on.
                                  SketchUp_MkTZcdyNi9.mp4
                                  Krass
                                  • KrassK
                                    Krass
                                    I don’t understand why the small animations end up getting lost after a few operations that shouldn’t, in theory, affect these "movements." I’m not changing the hierarchy at all. A series of rotations converted into a clip works fine, and then suddenly stops working altogether—the same thing happens with translations.
                                    It’s becoming tiresome, and I’m wasting a lot of time. I bought the extension to use with RayScaper, but now I’ve run out of patience.
                                    Krass
                                    • KrassK
                                      Krass
                                      I have to offer a mea culpa. Rich pointed out that the "exclude this clip from the animation" option was checked. I’m embarrassed.
                                      Krass
                                        No need. Animator has many options to toggle it’s easy miss.
                                        • KrassK
                                          Krass
                                          Hello everyone,
                                          I’m having trouble—I can’t seem to continue the robot’s walking motion. The upcoming rotational movements for the left leg aren’t working correctly; as soon as the movement is confirmed, the robot gets thrown 2 meters to the left... I’ve tried everything and even started over from scratch...
                                          Thanks for your advice.
                                          Here is the file :https://www.swisstransfer.com/dl/01a1d6ac-f08b-70a1-b7fa-1fe8afd102eb
                                          Krass
                                          • KrassK
                                            Krass
                                            if I try to add a new movement, another rotation of the whole robot it goes one meter up...
                                            SketchUp_bklCUafpsI.mp4
                                            Krass
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
