Animator: Parametric Animation plugin - Discussion
Thanks for your amazing work, Fredo. I'm just trying to learn how to use Animator.
I'm confused about why the clip sequencer will reposition clips after I've placed them. It seems to have some built-in logic that wants to move a clip from one track to another and I can't figure out how to override it so that I can lay them out the way I want.
In the picture I've attached, I had all the movements in one track and the scaling in another. When I saved, Animator shuffled the Scaling and Movements.
Is there a switch I can flip, or can you explain the logic behind the automatic rearranging?
Currently the re-arrangement is automatic, that is the track on which clip elements are put. Usually, cameras are on the first tracks.
I am thinking of letting freedom to the user in a next version however. -
Thanks for the reply. I wouldn't care, but it's having an impact on the end result. With the scaling reshuffled by Animator, the second path movement starts in a slightly different location.
Normally, the re-ordering of tracks does not change the start time and duration of the clip elements.
Do you observe something different?
I created a simple scene to confirm and found that the point of contact stays put when the path remains where I placed it, but when saving rearranges the clips the point of contact is no longer connected to the corner I specified and scaling expands the corner away from the curve.
I couldn't consistently reproduce it, but with this example the tracks stayed put after closing and reopening the SketchUp file.
I've attached the file.
If you have any advice I'd appreciated it.
JoeSketchUp Pro 2020
20.0.363 64-bitAnimator 2.6a - 12 Jan 20
I assume you want the corner to stay along the path.
If so, then your scaling should be done from the opposite corner handle.
Here is the file corrected
Thanks for taking the time to answer such a dumb question! I'm starting to get comfortable with Animator and loving it. Thanks again!
I´m having a problem with Animator after not using it for months. I used to put "tracking cameras" for following objects and trying to smooth the transition between the "sketch up cameras". But everything works well except de "tracking cameras" which block the Animator and don´t allow you to continue with the video.Sketch up 2020
Animator_v3.2a
LibFredo6_v11.6a
SketchFXEx-3.0.2
AmbientOcclusionEx-2.8.0Thank you very much for any suggestions
@carlurcia said:
I´m having a problem with Animator after not using it for months. I used to put "tracking cameras" for following objects and trying to smooth the transition between the "sketch up cameras". But everything works well except de "tracking cameras" which block the Animator and don´t allow you to continue with the video.Could you post or PM me the model so that I have a look.
Many thanks
Hello,
I’ve got a decent handle on Animator now (thanks again!). However, I’m not quite sure how to proceed with my current project: I’ve started this little animation, but I want to animate both VU meters in parallel. I’m wondering how best to go about this.
For this animation, I created a small rectangle that I scale up to gradually cover the indicator lights.
I need a way to copy and paste this animation so I can position it over the VU meter on the right. Is it possible to copy this rectangle—along with its grouped animation properties? Or, alternatively, can I create a copy and then apply the settings from the first animation to it?
I do see an option to clone the clip...
Thanks for your suggestions!I have just paid for my license
I am also looking for a way to repeat this animation throughout the entire duration of the main clip, without having to copy and paste this short clip multiple times...
Hello,
I found the solution by taking a closer look at the user manual.
It’s perfect and couldn’t be simpler. Thanks again for this brilliant program!Simply select two objects to which the same animation will be applied when creating a new movement.
le souci est que je n'arrive pas à répéter cette série de mouvements pour les vu mètre que j'ai convertie en clip. Si j'affecte -1 à a valeur de répétition, (forever) il ne joue qu'une seule fois. Si je place d'autres copies du clip l'une après l'autre, les copies ne jouent pas.
Difficile d'aider sans voir le fichier.
La repetition suppose que le clip a une duree definie -
Bonsoir,
veux tu le fichier? -
SwissTransfer - Send large files securely and free of charge
Send up to 50 GB - Free and no registration required - Keep your transfers for 30 days
SwissTransfer (www.swisstransfer.com)
un lien vers le fichier https://www.swisstransfer.com/dl/01a1bda1-f434-7164-9ea8-a97f73fa6a29
mais depuis j'ai installé une extension concoctée par Chat GPT pour un mode sombre sketchup qui marchait très bien et Animator a perdu toute fluidité, la petite animation des vu mètres semble inactive et la lecture dans le viewport du clip est saccadée c'est difficilement utilisable. avant l'installation de l'extension, c'était fluide, je ne comprends pas. Cette extension utilise les palettes Qt (je n'y connaîs rien) et le fait de la désinstaller n'a rien changé. mais je me suis quand même dit qu'il y avait un lien.. -
Bonjour,
j'ai désactivé les mouvements et le clip présent présents sur la time line, et je fais jouer le film sur un ordi puissant et c'est saccadé.... -
ici sur ce pc avec une carte graphique laptop NVIDIA rtx 4090, j'ai supprimé tous les films, les clips. Je pars de zéro. Sur deux scènes SU que je destine à être les deux images clé de la prochaine animation j'ai masqué toute la végétation, tout le mobilier qui n'est pas dans le champ.
récré juste une animation depuis ces deux scènes et c'est vraiment pas fluide -
puis j'ai bien mis le nouveau moteur graphique, copié la chaîne hifi (juste ce qui apparaît dans le champ) et refait un film avec les deux images clé entre deux scènes et, miracle, le film redevient normal.
Je rouvre alors le fichier original, et et nouveau l'anime rame... je pourrais bien sûr tout refaire de A à Z, mais j'ai déjà configuré tous les matériaux et lumières, scatter, dans Rayscaper... -
je pense que j'avais préparé l'animation avant d'ajouter tout ce mobilier très lourd... et en suite la lecture est devenue saccadée. Bizarre que par ailleurs les transitions sketchup entre les scènes quand Animator est fermé restent fluides
Hello, in this clip, I can no longer animate objects using translation... I don't understand what's going on.
