    Animator: Parametric Animation plugin - Discussion
    229 Posts 56 Posters 130.7k Views 55 Watching
      moderatelyfunky
      I created a simple scene to confirm and found that the point of contact stays put when the path remains where I placed it, but when saving rearranges the clips the point of contact is no longer connected to the corner I specified and scaling expands the corner away from the curve.
      I couldn't consistently reproduce it, but with this example the tracks stayed put after closing and reopening the SketchUp file.
      I've attached the file.
      If you have any advice I'd appreciated it.
      Joe
      SketchUp Pro 2020
      20.0.363 64-bit
      Animator 2.6a - 12 Jan 20
      ClipSeq_AfterAddingScaling.skp
      • fredo6F
        I assume you want the corner to stay along the path.
        If so, then your scaling should be done from the opposite corner handle.
        Here is the file corrected
        ClipSeq_AfterAddingScaling - right handle.skp
          moderatelyfunky
          Thanks for taking the time to answer such a dumb question! I'm starting to get comfortable with Animator and loving it. Thanks again!
          • C
            carlurcia
            I´m having a problem with Animator after not using it for months. I used to put "tracking cameras" for following objects and trying to smooth the transition between the "sketch up cameras". But everything works well except de "tracking cameras" which block the Animator and don´t allow you to continue with the video.
            Sketch up 2020
            Animator_v3.2a
            LibFredo6_v11.6a
            SketchFXEx-3.0.2
            AmbientOcclusionEx-2.8.0
            Thank you very much for any suggestions
            • fredo6F
              @carlurcia said:
              Could you post or PM me the model so that I have a look.
              Many thanks
              • KrassK
                Krass
                Hello,
                I’ve got a decent handle on Animator now (thanks again!). However, I’m not quite sure how to proceed with my current project: I’ve started this little animation, but I want to animate both VU meters in parallel. I’m wondering how best to go about this.
                For this animation, I created a small rectangle that I scale up to gradually cover the indicator lights.
                I need a way to copy and paste this animation so I can position it over the VU meter on the right. Is it possible to copy this rectangle—along with its grouped animation properties? Or, alternatively, can I create a copy and then apply the settings from the first animation to it?
                I do see an option to clone the clip...
                Thanks for your suggestions!
                SketchUp_tnY7qsbzu9.mp4
                I have just paid for my license
                I am also looking for a way to repeat this animation throughout the entire duration of the main clip, without having to copy and paste this short clip multiple times...
                Krass
                • KrassK
                  Krass
                  Hello,
                  I found the solution by taking a closer look at the user manual.
                  It’s perfect and couldn’t be simpler. Thanks again for this brilliant program!
                  animation.mp4
                  Simply select two objects to which the same animation will be applied when creating a new movement.
                  Krass
                  • KrassK
                    Krass
                    le souci est que je n'arrive pas à répéter cette série de mouvements pour les vu mètre que j'ai convertie en clip. Si j'affecte -1 à a valeur de répétition, (forever) il ne joue qu'une seule fois. Si je place d'autres copies du clip l'une après l'autre, les copies ne jouent pas.
                    Krass
                    • fredo6F
                      Difficile d'aider sans voir le fichier.
                      La repetition suppose que le clip a une duree definie
                      • KrassK
                        Krass
                        Bonsoir,
                        veux tu le fichier?
                        Krass
                        • KrassK
                          Krass
                          SwissTransfer - Send large files securely and free of charge
                          Send up to 50 GB - Free and no registration required - Keep your transfers for 30 days
                          SwissTransfer (www.swisstransfer.com)
                          un lien vers le fichier https://www.swisstransfer.com/dl/01a1bda1-f434-7164-9ea8-a97f73fa6a29
                          mais depuis j'ai installé une extension concoctée par Chat GPT pour un mode sombre sketchup qui marchait très bien et Animator a perdu toute fluidité, la petite animation des vu mètres semble inactive et la lecture dans le viewport du clip est saccadée c'est difficilement utilisable. avant l'installation de l'extension, c'était fluide, je ne comprends pas. Cette extension utilise les palettes Qt (je n'y connaîs rien) et le fait de la désinstaller n'a rien changé. mais je me suis quand même dit qu'il y avait un lien..
                          Krass
                          • 11
                          • 12
                          • 12 / 12
