    Rayscaper New Releases
    rayscaperrender
    791 Posts 14 Posters 369.2k Views 15 Watching
    • pixelcruncherP
      @Krass, I figured out how to hack the grass material to make rugs too. However, that required code changes in Rayscaper, so it will be available only in the new version. Stay tuned for this. I will share the skp file as well with the new version so you can have the same results.
      Cheers,
      Thomas
        Alattab
        I believe it is necessary to add a "mask map" alongside the alpha and opacity maps; otherwise, I cannot properly render the appearance of the fountain water—indicated by the number 1 in the image—as required. Furthermore, I think it is essential to include specific fluid presets—such as those for milk, carbonated water, aerated water, etc. In the image, the element marked with the number 2 represents the aerated water produced by a bubbler nozzle.
        A 1 Reply Last reply
        • ntxdaveN
          ntxdave
          Interesting image. What software did you use to add the 1 and 2 highlights?
          Press F1...thank me later
          A 2 Replies Last reply
            Alattab
              Alattab @ntxdave
              @ntxdave it is calld" Franzis cutout profistional "
                Alattab @ntxdave
                @ntxdave if you mean number bubble tag , use softwear calld Ksnip it is freecharge , open source kind type
                • pixelcruncherP
                  @Alattab, thanks for the clear example. You can render the spray (1) already today, without a separate mask map: the Opacity of a material takes any image and can read its brightness instead of its alpha, which is exactly what your black and white image is.
                  I tried it with your two images on a single upright face in a quick test scene:
                  Select the material of the jet in the material editor and set:
                  1. Color: white, or a very light blue.
                  2. Opacity: click the image icon, choose Image as the Texture Type and load the black and white image.
                  3. Color Space: Linear.
                  4. Channel: Luminance.
                  Black is then fully transparent, white is solid and the greys in between are partly see-through, so the soft edges of the spray stay soft. You don't need the colored PNG for this.
                  The fluid presets (milk, carbonated, and aerated water) are noted as a feature request. For the bubbler jets (2), the same trick with a picture of foamy water works best for now.
                  Cheers,
                  Thomas
                    Alattab @pixelcruncher
                    @pixelcruncher
                    With all due respect, Mr. Thomas, I appreciate your valuable efforts. I will keep you updated on any insights or feedback I come across as they arise. My only suggestion is to establish a set schedule for releasing new versions; this would allow us to thoroughly explore previous versions and, in turn, provide more comprehensive feedback.
                    • pixelcruncherP
                      pixelcruncher Extension Creator @Alattab
                      @Alattab, thanks for the feedback, but for now I'm not going on a fixed release cadence.
                      Rayscaper isn't my day job, so I have to make time to work on it. Last month was very productive because I could spend most days (and nights) developing, but that's not always a given. So I try to release as early as I can to get that valuable user feedback. I'm on a fast release cadence right now, but that's not always a given. I will always try to support customers as fast as I can, but regular development might take a backseat sometimes.
                      I'm also almost at the 1.0 stopping point. After that, I will take some time to develop the 2.0 features and build a solid beta set for the 2.0 release. Also, I've been working towards a 1.0 release for 3 years now (!!!), @rich-o-brien has been testing this monster since August 2023. I need to get something out.
                      Cheers,
                      Thomas
                        Alattab
                          Alattab
                          It is a good idea to find settings that prevent elements from casting or receiving shadows.
                            @pixelcruncher This is what I mean: set a specific day for us to receive a new release, and leave us the rest of the week—or month—to gather feedback.
                            • pixelcruncherP
                              @krass jus a little teaser 😉
                              Turns out you can do a lot of cool stuff by modifying grass.
                              Of course we had to make one for the SketchUcation crowd 🙂
                              And yes, it works on dogs too.
                              Fur will be in the next release.
                              Cheers,
                              Thomas
                                Alattab @Alattab
                                Sorry, I found several materials that have the same texture but go by different names.
                                  Alattab @Alattab
                                  The problem persists, as the palm trees cast their shadow onto the surface representing the fountain's water.
                                  • pixelcruncherP
                                    Thanks for the suggestion! Fine-grained shadow settings come up occasionally. For now, I'm keeping Rayscaper's settings simple, but I've noted it.
                                    What would you use this for? If there's a common case behind it, there might be a simpler way to solve that.
                                    Cheers,
                                    Thomas
                                    • KrassK
                                      Krass
                                      It’s fantastic and makes my mouth water.
                                      Krass
                                      • pixelcruncherP
                                        Hey, Rayscaper users!
                                        Rayscaper 1.0.0 is available. You can get it via:
                                        • The SketchUcation store.
                                        • Direct download: Rayscaper_Win_1.0.0.rbz.
                                        I recommend upgrading to the latest version.
                                        Rayscaper 1.0: Out of Beta
                                        After many releases of Beta, Rayscaper is now 1.0. A big thank you to everyone who tried the betas, reported bugs and shared renders here: it shaped Rayscaper more than you think.
                                        Fur Material
                                        Paint a face with the new Fur material and Rayscaper grows real strands on it in the render: shag and short pile rugs, sheepskin, faux fur throws, plush cushions, even the coat of an animal. Start from a preset and tune the length, density and curl. An image texture colors every strand where it grows, so a patterned rug keeps its pattern. See Fur Material.
                                        Rayscaper rug in Fur
                                        Close-up of the rug
                                        SketchUcation runner in Fur
                                        Sheepskin
                                        Wind for Grass
                                        The Grass material gets Wind and Wind Direction, which lay the grass over one way, and stronger mowing stripes. The online material library now has thirty Grass materials: lawns, sports turf, meadows, wild grass and artificial turf. See Grass Material.
                                        A New Look
                                        The render window has a calmer, darker look with clearer selections.
                                        What Changed?
                                        • Add the Fur material: paint a face with it and Rayscaper grows real strands on it in the render, for shag and short pile rugs, sheepskin, faux fur throws, plush cushions, long hair and the coat of an animal. Fur hangs down under gravity on walls and over rounded shapes, and an image texture colors every strand where it grows.
                                        • Add Wind and Wind Direction to the Grass material, and lean whole clumps for stronger mowing stripes.
                                        • Add thirty Grass materials to the online material library.
                                        • Give the render window a new look: calm dark surfaces, clearer selections and a new UI font.
                                        • Take Rayscaper out of Beta.
                                        • Fix dark soft edges and fades in PNG and TGA textures with transparency, and transparent images that were saved too bright.
                                        • Fix a crash of CPU renders when the model changed while the render ran.
                                        • Wrap buttons that ran past the edge of a narrow scene editor panel, and translate the Browse button.
                                        Full release notes: rayscaper.com/manual/release-notes
                                        Help Me Build the Community 👍
                                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                                        Follow me on X.
                                        Happy Rendering!
                                        Thomas
                                          Alattab
                                          pixelcruncherP A 2 Replies Last reply
                                          • pixelcruncherP
                                            @Alattab Okay, thanks for the image. That makes it very clear 🙂
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 39
                                            • 40
                                            • 34 / 40
