    Rayscaper New Releases
    rayscaperrender
    777 Posts 14 Posters 355.5k Views 15 Watching
      Does Rayscaper support proxies?
      pixelcruncherP KrassK 2 Replies Last reply
        Reply Quote 2
        • KrassK
          Krass
          Very nice
          Krass
          ntxdaveN 1 Reply Last reply
          • ntxdaveN
            ntxdave @Krass
            @Krass said:
            Very nice
            Agree - very nice indeed. Wish I could still afford both of these products.
            Press F1...thank me later
            • pixelcruncherP
              pixelcruncher Extension Creator @Mike Amos
              @Mike-Amos Not at this time.
              • KrassK
                Krass @Mike Amos
                I'm sure it will come soon!
                Fredo6 made a plugin for proxies, but I did not use it, was it for vray? I dont remember
                Krass
                  Alattab
                  Is it possible to use the SketchUp background as a backdrop for the scene during the rendering process when using 'sky' settings?
                  KrassK 1 Reply Last reply
                    Alattab
                    Is it possible to have RayScaper automatically recognize material names and configure them accordingly? For instance, if a material’s name contains the word "glass" (in any part of the name), could it be automatically set to have glass properties, without requiring an internet connection?
                    Fog option what about it ?
                      Not the end of the world and time is Einstein, so a relative told me.
                      When there is time Thomas will consider the pro's and cons.
                      • KrassK
                        Krass
                        Hello, I’m wondering if there’s a trick for generating shadows on HDRI maps—or perhaps a "wrapper material" that could be used?
                        Krass
                          @krass Thomas would need to add support for Shadow Catcher. That would be awesome!
                          • KrassK
                            Krass
                            I know how to do it with still images by cheating in post-production—importing an ambient occlusion layer—but with an animation...
                            Krass
                            • KrassK
                              Krass @Alattab
                              You’ll get better results by adding a "material ID" render pass.
                              Then, ask the AI ​​to change the background behind the windows, and create a composite image in Photocraft or GIMP using your material ID pass.
                              Krass
                              A 1 Reply Last reply
                                Alattab @Krass
                                @Krass We want updates that provide users with features compelling enough to convince them to switch to using RayScaper.
                                scaling enviroment one of them ?
                                • pixelcruncherP
                                  Hi all,
                                  Thanks for all the questions and feedback!
                                  Quick update: I'm planning to release 1.0 very soon. Rayscaper has a good set of features for a 1.0 by now, and I know the Beta label still puts some people off from buying it. I've seen interest grow over the last couple of months, so I want a strong first product for a broader audience.
                                  @lightscape Thanks for the comparison images. The denoiser fix was easy: it now keeps fine texture detail, like distant wood grain, much sharper. It's in the next release. About testing without limits: there's already too much abuse of Rayscaper as it is, so I'm not planning to offer more than the free version for testing. A license removes the resolution limit.
                                  @Alattab
                                  • City photo behind the windows with a Sky: Rayscaper doesn't render SketchUp's watermarks, since they're a flat image drawn in the viewport, not part of the model. There are two easy workarounds:
                                    a. Put the photo on a large face outside the windows, in the model. It renders with the scene, so you also get it in reflections and animations.
                                    b. Turn on Transparent in the Environment section. The sky still lights your model, but the background behind the windows comes out transparent in the PNG. Then put the photo behind it in Photoshop or GIMP. The Material ID pass, as @Krass suggested, helps you select the glass.
                                  • Setting up materials by name: this is planned, even before 1.0. Rayscaper needs to be online for the asset library and licensing.
                                  • Fog: it's on the list, but it won't be in 1.0. Fog needs volumetrics, which is a very big change to the renderer.
                                  • Scaling the environment: can you tell me a bit more about what you mean? An HDRI is infinitely far away, so it has no scale. A bigger HDRI file gives a sharper background, but it doesn't make anything in it larger or smaller. If you want the HDRI ground to line up with your model, like the trailer standing in the snow in @Krass's images, that's a different feature.
                                  • @krass Proxies are on the list, but this is also a huge change, and won't make it to 1.0.
                                  @Krass @Rich-O-Brien I hear you on the shadow catcher, or matte material. I see why it matters for animations. I'll try to add one, though it probably won't be ready for 1.0.
                                  Thanks for the support, folks!
                                  Cheers,
                                  Thomas
                                  Rich O BrienR A 3 Replies Last reply
                                    Rich O Brien Moderator @pixelcruncher
                                    Take your time. I'm happy with you sticking to your plan. It's been solid so far.
                                    1 Reply Last reply ♥
                                    Reply Quote 2
                                      Just a thought, there is a competition at Evermotion which might be a good test, maybe make a few bob worth in prizes too. Just a thought.....
                                      Just a moment...
                                      (evermotion.org)
                                        Alattab @pixelcruncher
                                        @pixelcruncher i mean
                                        environment sphere sizing , like ball sizeing , and can you add hemispher option ,
                                        you can see some thing like in simlab composser render softwear
                                          @pixelcruncher
                                          it is usuefull to use sketchup back ground to line up sun direcrion and other propuse , and you can add fore ground and backpalet , fore ground , back ground like kyshot render softwear
                                          • KrassK
                                            Krass
                                            Heads up, friends—be very careful not to delete an Animator "film" when creating a new one. I lost all the settings for my second film, even though I had saved it. Deleting "film 1" wiped out all my material, HDRI, and other settings, leaving "film 2" completely "stripped"—though the animation itself remained intact. I have to admit, this really killed my motivation.
                                            So, I’m giving up on re-rendering the first film...
                                            Krass
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 38
                                            • 39
                                            • 31 / 39
