    AI Render Enchancer Extensions or tools
    6 Posts 5 Posters 1.3k Views 5 Watching
      miikka1978
      Lately I have been testing multiple AI Rendering solutions for my Sketchup models. Do you have any experience or recommendations for AI Rendering solutions?
      I have been testing for example the below ones but there sems to be so many of these solutions. Based on first round of testing Visoid has given the best results in my use case.
      In my case I have used direct Sketchup image export or then I have done a quick rendering in D5 Render and finetuned the D5 output with these tools.
      Many of these solutions give nice looking renders but I still find the biggest challenge to be the lack of control. For example, it would be essential to be able to edit/render only certain materials/textures/parts of the model (colors/material IDs).
      • https://www.visoid.com/
      • https://vizmaker.vizacademy.co.uk
      • https://rendair.ai/
      • https://www.myarchitectai.com/
      • https://mnml.ai/
      • https://www.lovart.ai/
        myarchitectai has edit abilities
        https://www.myarchitectai.com/render-editing
        Have you tried https://archfine.com/ ???
          miikka1978
          I have been testing MyArchtectureAI quite some. I also purchased the Pro version with unlimited credits. In my case the results are not that great even when doing editing. There are just too many random AI stuff happening.
          I just tested Archfine.com and it gave excellent results. There was editing needed because AI didn't get creative. Unfortunately it was not possible to do more test because it was possible to do only 1 test render with the free version.
          It seems that the solutions (Visoid, Archfine, Viz Maker) that use NanoBananaPro are giving the best results. https://vizmaker.vizacademy.co.uk/ has also somekind of integration with Sketchup but it seems to just export the image, no material info or anything. Viz Maker has also quite good edit possibilities.
            deroomai Newcomers
            Adding to the list β€” I've been building Deroom AI which generates AI room redesigns from a photo (not text prompts). It preserves the room's geometry and perspective so the output still matches the actual space layout, which I think matters for SketchUp users who want to test material/style ideas on a rendered scene before committing in V-Ray or Enscape.
            Free to try (5 credits/day). Curious if anyone here has tried photo-based vs text-based AI viz tools in their workflow.
              Sam2188
              I use Spacely AI extension (https://www.spacely.ai/), it works pretty great and they have free trial credits too. I would recommend realistic render tool, it has a built-in preset that you can click and choose. Also, they have point & edit tool which allow you to change some part of the render without having to change the 3D model.
                arunb24 Newcomers
                One more tool worth testing is Vibe3D: https://vibe3d.ai
                It is focused on preserving the original geometry, materials, and composition of SketchUp scenes rather than completely reimagining the design. You can also mask a specific area and describe the change you want, which is useful for changing individual materials, furniture, landscaping, or other parts without affecting the entire render.
                It can be used for generating renders from SketchUp scenes, or for enhancing and editing existing outputs from tools like D5, Enscape, V-Ray, or Lumion. There is a free trial, so it may be worth comparing it.
