AI Render Enchancer Extensions or tools
Lately I have been testing multiple AI Rendering solutions for my Sketchup models. Do you have any experience or recommendations for AI Rendering solutions?
I have been testing for example the below ones but there sems to be so many of these solutions. Based on first round of testing Visoid has given the best results in my use case.
In my case I have used direct Sketchup image export or then I have done a quick rendering in D5 Render and finetuned the D5 output with these tools.
Many of these solutions give nice looking renders but I still find the biggest challenge to be the lack of control. For example, it would be essential to be able to edit/render only certain materials/textures/parts of the model (colors/material IDs).
myarchitectai has edit abilities
AI Render Editing | Try For Free
Quickly retexture surfaces, remove objects, and selectively enhance renders without starting from scratch or opening Photoshop. Powered by AI.
(www.myarchitectai.com)
Have you tried https://archfine.com/ ???
I have been testing MyArchtectureAI quite some. I also purchased the Pro version with unlimited credits. In my case the results are not that great even when doing editing. There are just too many random AI stuff happening.
I just tested Archfine.com and it gave excellent results. There was editing needed because AI didn't get creative. Unfortunately it was not possible to do more test because it was possible to do only 1 test render with the free version.
It seems that the solutions (Visoid, Archfine, Viz Maker) that use NanoBananaPro are giving the best results. https://vizmaker.vizacademy.co.uk/ has also somekind of integration with Sketchup but it seems to just export the image, no material info or anything. Viz Maker has also quite good edit possibilities.
Adding to the list β I've been building Deroom AI which generates AI room redesigns from a photo (not text prompts). It preserves the room's geometry and perspective so the output still matches the actual space layout, which I think matters for SketchUp users who want to test material/style ideas on a rendered scene before committing in V-Ray or Enscape.
Free to try (5 credits/day). Curious if anyone here has tried photo-based vs text-based AI viz tools in their workflow.
