    AI Render Enchancer Extensions or tools
    25 Posts 10 Posters 3.8k Views 10 Watching
    • KrassK
      Krass
      For what it's worth, I’ve heard of many of the services mentioned above. I work with D5 Render or Rayscaper, but when I want to test an AI solution directly from 2D captures, the issue of maintaining consistency between viewpoints doesn't seem to have been solved yet.
      That said, I do think rendering engines will be replaced by AI fairly soon.
      As for in-depth client presentations, it’s not quite ready for use yet because the results are too unpredictable.
      However, for a single image or two, you can certainly achieve a much more photorealistic look than with standard 3D rendering.
      For now, I have to create high-quality textures with complex mapping, and then I can perform an "inventive upscale" using Magnific.ai. This allows for different, yet consistent, viewpoints of the model.
      You can always try using AI to place a character or sculpture so that it appears across multiple views—but what a massive undertaking that is!
      Krass
      • KrassK
        Krass @arunb24
        @arunb24
        about https://vibe3d.ai/
        I think it’s reminiscent of D5 Lite, which can be very faithful to the model's geometry. The issue is that this service doesn't let you test it with your own models, so I'm giving it a pass.
        Krass
        • KrassK
          Krass
          Sherpa is really just a gimmick if you can't write a prompt—especially compared to tools like GPT image inpainting or Nano B.
          These tools won't replace rendering engines until they can interpret 3D data rather than just images. I have clients asking for stone cladding from a specific region in the south of France... though, on the other hand, ChatGPT is great at generating seamless textures from poor-quality photos.
          Krass
          S 1 Reply Last reply
            sherparender Newcomers @Krass
            @Krass I actually agree with most of what you're saying.
            Consistency between multiple viewpoints is still one of the big unsolved problems with image-based AI, and if a client specifies an exact stone from a quarry in southern France, I wouldn't trust an AI render to reproduce that accurately enough for final approval either.
            Where I disagree is that “no prompt” makes it a gimmick. That was actually a deliberate choice.
            In Sherpa you can still direct the image, lighting, time of day, people, styling, and materials per element but I wanted to avoid making architects learn how to write prompts just to get a useful result. For example, instead of describing the whole scene, you can simply set floor: limestone, walls: warm plaster, change the lighting and leave the rest alone.
            It’s definitely not trying to solve the same problem as a fully controlled V-Ray/D5 workflow. I see it more as the step between a SketchUp viewport and that level of visualisation.
            And yes, longer term I think you're right that the really interesting breakthrough will come when these systems understand the actual 3D scene rather than only interpreting a 2D image.
            If you ever feel like throwing one of your own SketchUp views at Sherpa, I'd genuinely be interested in where it fails for you. That kind of test is much more useful to me than a polished demo image
              @sherparender
              The input image...
              The AI output image...
              Look like it doesn't like or understand top down views. Also the 10min wait is a tad excessive.
                sherparender Newcomers @Rich O Brien
                @Rich-O-Brien At first, Thanks for trying it out!
                I guess thats why we have added this page; https://sherpa-render.com/en/learn/common-mistakes 😊
                I think it also helps if you choose interior instead of exterior for this view
                  Not really I'm afraid
                    @Rich-O-Brien Still you choose exterior instead of interior...
                      i just gave it a try with your screenshot and choose the interior option
                      • KrassK
                        Krass
                        Rich, you're really being too hard on the AI ​​by choosing the Eicher view.
                        Krass
                        • KrassK
                          Krass
                          @sherparender
                          The issue is the sheer number of offers like this and the lack of available credits for thorough testing. As someone who does rendering almost daily and is keenly interested in AI for this purpose, I believe the service that truly offers a substantial free trial will stand out. If I want to test 3D modeling quality from photos, I go to Tencent HY 3D—20 free generations a day!
                          Where can you find an offer like that for ArchViz AI?
                          Krass
                          • KrassK
                            Krass
                            @Rich O Brien
                            My Architect Ai : same as most other. Pay first and you will see ! I was able to do a test and it went completely haywire.
                            Krass
                            • pixelcruncherP
                              Are these AI providers significantly better than SketchUp AI render? I.e., what's the added value of paying for an external tool when you already have it in SketchUp?
                              • KrassK
                                Krass
                                That’s a good question. I don’t hear much feedback about SketchUp’s AI rendering tools. I haven’t switched to the latest version myself, but the technology has likely improved since its initial release. To clarify how it works: sites like 3dvibes are undoubtedly very effective, but they require a different workflow within the modeling software. For SketchUp, using them makes sense if you can fully integrate the 3D geometry, furniture, vegetation, and textures directly into the SketchUp project. However, this results in very heavy projects with excessive polygon counts; rendering detailed fabric sofas, 3D figures, or trees can be a struggle. Yet, these rendering services are far more capable of maintaining consistency and precision across different scenes and viewpoints when all the necessary information is already present in the SketchUp workspace.
                                In professional practice today, however, the standard approach involves doing about two-thirds of the 3D preparation in SketchUp and handling the rest in a "real-time" rendering engine—such as Enscape, Twinmotion, Lumion, or D5 Render. These engines offer great fluidity by leveraging the graphics card, particularly when dealing with vegetation and high-poly models. The results are truly impressive.
                                For instance, you can integrate 3D objects created via AI-from-photo modeling; while they are incredibly useful, they are also very heavy—making it impossible to use them in large numbers within SketchUp.
                                As we speak, I believe some users are betting on moving away from traditional rendering engines altogether, and that approach works well in many situations.
                                It is certain that, in the medium term, AI will take over about half the workload of traditional rendering engines; indeed, exterior backgrounds and vegetation are already being generated using AI today.
                                Furthermore, many of these services are increasingly integrating directly into modeling software as extensions. D5 Render offers AI rendering with D5 Lite.
                                It would be interesting to get feedback from users of AI Render (diffusion).
                                Krass
                                • pixelcruncherP
                                  Thanks for the explanation, @krass - So there's real value in these AI rendering solutions; they are not a fad. I should go build my own.
                                  KrassK 1 Reply Last reply
                                  • KrassK
                                    Krass @pixelcruncher
                                    yes Pixelcruncher these solutions aren't a gimmick any more, I don't know if you're an expert in this field, but yes, absolutely. However, it's a real hassle to offer to clients—it requires massive servers...
                                    Free AI models are pretty good, but they don't compare to paid solutions. Zpix, by Samuel Tallet, is a free PC app that generates really decent images using open-source models. However, it's best suited for creating single views and involves a lot of randomness.
                                    I couldn't really use this image for my client, but I put it on my site...
                                    alt text
                                    Krass
                                      MikusZ Newcomers
                                      Disclosure first: I'm one of the founders of Vizbase, an AI rendering extension for SketchUp, so read this with that in mind.
                                      @miikka1978, your point about editing only certain materials or parts of the model is the problem we built around. Vizbase detects the elements in the captured view (walls, floor, ceiling, joinery, furniture) and you set a material for each one, typed, from a reference photo or from a material library, instead of one prompt for the whole image. After rendering, Refine lets you mask an area and change only that.
                                      It isn't flawless. On a renovation project last month the first pass dropped a plaster ceiling rose that was in the model, and it took a Refine pass with a reference image to bring it back. And as @Krass says, consistency across several viewpoints is still the hard part for every AI renderer, ours included.
                                      Since testing on your own models came up: the free plan has 5 credits a month (up to 10 renders, no card), and the SketchUp extension works on it, so you can try it on your own model without paying. If anyone wants more room for a proper test on a real project, message me and I'll set up free Studio access. Post the results here, good or bad.
