    2.3k Posts 517 Posters 3.0m Views 522 Watching
    • E
      Eikhine2712 Newcomers
      i purchased the license and trying to validate the file, but its returning this dialogue
      G 1 Reply Last reply
      • G
        Gábor @Eikhine2712
        @Eikhine2712 Could you please tell us what version of SketchUp you are using?
        The problem is probably caused by some NON-ASCII characters in your computer name. There are 2 possible solutions:
        1. you change your computer name and erase the signature file OR
        2. We are beta testing a new version of the licensing system currently which is addressing this issue. If you are willing to help us with beta testing, I can send you the beta version and give you the instructions on how to install it.
          songhwazee
          항상 루비를 개발 해주셔서 감사합니다 잘쓰고 있습니다
          • alexpacio2013A
            alexpacio2013
            Since yesterday, the Sketchauction licenses no longer work. What happened? I tried to update both the Sketchauction plugin and it asks me to activate the licenses. I try to activate them but this is the error that comes up. What can I do?
              Their was a glitch in the version of SketchUcation tools that was available briefly a few days ago.
              If you installed that you can get license error messages.
              It was reverted to to previous version v5.0.6 in the PluginStore, and you should try and install that to see if the error is resolved.
              After a restart, if the problem continues let us know.
              A correct and updated version will be published asap...
              • alexpacio2013A
                alexpacio2013
                The same problem also with version 5.06.
                Is there a limit to installing licenses or can I install unlimited licenses?
                With SketchUp 2025 I have the following error attached with the image. While with SketchUp 2026 I have no errors but it doesn't work. The cold plug-ins don't open.
                  Rich O Brien Moderator @alexpacio2013
                  You can have 3 seats activated before you see the exceeded message.
                  If you visit https://sketchucation.com/webshop/my-licences.php you can release seats or do at the devices.
                  alexpacio2013A 1 Reply Last reply
                  • alexpacio2013A
                    alexpacio2013 @Rich O Brien
                    @Rich-O-Brien I have 1 computer but on one I installed the SketchUp version 2024 2025 2026 and to do the tests I installed the licenses several times. The 2024 version is clean and has no other plugins specifically for testing. I had the same problems so it is not a conflict with other things.
                      That's still a single device.
                      What do you see at https://sketchucation.com/webshop/my-licences.php ?
                      Can you click the blue chevron and see occupied seats with a checkbox to release seats?
                      • alexpacio2013A
                        alexpacio2013
                        Can you remove some activations from me?
                          You can do it. Click checkbox and then release
                            Unless you others frozen you didn't show?
                            • alexpacio2013A
                              alexpacio2013
                              I have to release all the boxes with the square
                                Each is a device you activated on. So yes.
                                I can do it for you. Give me a few mins.
                                • alexpacio2013A
                                  alexpacio2013
                                  Grazie
                                    https://sketchucation.com/webshop/my-licences.php should be clear now.
                                    To activate and release in Sketchucation Tools you can open the Settings > Licenses and activate as needed
                                    • alexpacio2013A
                                      alexpacio2013
                                      You're great now everything works Thanks
                                        Enjoy the weekend Robo 🙂
                                        • alexpacio2013A
                                          alexpacio2013
                                          Thank you too
                                          • F
                                            fakhriaulia
                                            Hello,
                                            I've been installing the latest Sketchucation, and install Libfredo6, and FredoCorner. And I've put the license on it. After the installation, the toolbar shows up, but when I click on it, nothing happens. Can somebody help me
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 114 / 116
