    2.3k Posts 517 Posters 3.0m Views 522 Watching
      Rich O Brien Moderator @JanSteinman
      @JanSteinman said:
      For whatever reason, I cannot run SketchUp 2025 or 2026 as available on the SketchUp website
      Can you expand on this? SketchUp not running for 'whatever reason' is lacking detail.
      J 1 Reply Last reply
        JanSteinman Newcomers @Rich O Brien
        @Rich-O-Brien When I start (on MacOS 13.7.8) the available download of either SketchUp 2025 or 2026, it displays the menu bar for SketchUp, but then hangs infinitely† with just the Spinning Beach Ball of Death.
        The version of SketchUp 2025 that was in the /Applications folder on my automatic backups (version 25.0.659) works just fine, but displays the "missing Library file" notifier that I showed a few messages ago.
        I really need this! I have helpers for the build arriving, and materials being delivered next Friday.
        †Thinking it was just busy, I let it run overnight, and still had the SBBoD in the morning. All other applications (Mail, Firefox, etc.) continue working just fine. I have to force-quit SketchUp.
          Ah, I see your bug.
          I am on a case-sensitive file system — which is totally supported by Apple. The file present has "MAC" in it, and the dialogue has "Mac" in it.
          Don't feel bad… it took three years of continuous bug reports before Adobe made their case consistent within their applications!
          I suggest you should test on the most constrained case, in this case, on a case-sensitive file system. 🙂
          I think the other problem I'm having may be related to this, as well.
          But you won't even hear about this until Sketchucation takes this message out of moderation status… 😞
            Moderation is there to prevent spam. You should no longer be subject to moderation.
            • C
              cirocire
              I don't know what happened, however, although I can see the licenses online, when I try to upload the license file, this happens (pls see attached image)
                Did you try doing the Signature file deletion that the dialog suggested and try again ? Also check that the following extensions are up to date and installed and SketchUp restarted - SketchUcation toolset [for the licensing], the actual Extension[s] in question and if appropriate LibFredo6.
                If you have renamed your computer or copied files over from elsewhere, then this error can occur. If you Computer's name [and indeed your User-name] go against the recommended format of just ASCII letters + numbers and some limited punctuation - e.g. you've used accented letters or special-characters etc - then this can also cause errors like this - so try to rename your computer sensibly...
                  drautenkranz Newcomers
                  I downloaded FredoCorner to evaluate but the expiration date is listed as Sun 10 Mar 2024. How can that be resolved?
                    If you have exceeded the trial period you must buy a license...
                    • L
                      lydiarichardson95 @Gus R
                      @Gus-R said:
                      under "see this p
                      do you need a license for round coner now?
                        Rich O Brien Moderator @lydiarichardson95
                        Yes, for a few years it has been commercial.
                          mikeatnip
                          Hi, I cannot purchase Fredosection. I end up with this (Firefox Browser, Win 11):
                            Rich O Brien Moderator @mikeatnip
                            Can you update LibFredo and FredoSection to latest releases. FredoSection is not commercial yet so you are probably running outdated extensions.
                            M 1 Reply Last reply
                              mikeatnip @Rich O Brien
                              @Rich-O-Brien Thanks, that did the trick.
                              • E
                                Eikhine2712 Newcomers
                                i purchased the license and trying to validate the file, but its returning this dialogue
                                G 1 Reply Last reply
                                • G
                                  Gábor @Eikhine2712
                                  @Eikhine2712 Could you please tell us what version of SketchUp you are using?
                                  The problem is probably caused by some NON-ASCII characters in your computer name. There are 2 possible solutions:
                                  1. you change your computer name and erase the signature file OR
                                  2. We are beta testing a new version of the licensing system currently which is addressing this issue. If you are willing to help us with beta testing, I can send you the beta version and give you the instructions on how to install it.
                                    songhwazee
                                    항상 루비를 개발 해주셔서 감사합니다 잘쓰고 있습니다
                                    • alexpacio2013A
                                      alexpacio2013
                                      Since yesterday, the Sketchauction licenses no longer work. What happened? I tried to update both the Sketchauction plugin and it asks me to activate the licenses. I try to activate them but this is the error that comes up. What can I do?
                                        Their was a glitch in the version of SketchUcation tools that was available briefly a few days ago.
                                        If you installed that you can get license error messages.
                                        It was reverted to to previous version v5.0.6 in the PluginStore, and you should try and install that to see if the error is resolved.
                                        After a restart, if the problem continues let us know.
                                        A correct and updated version will be published asap...
                                        • alexpacio2013A
                                          alexpacio2013
                                          The same problem also with version 5.06.
                                          Is there a limit to installing licenses or can I install unlimited licenses?
                                          With SketchUp 2025 I have the following error attached with the image. While with SketchUp 2026 I have no errors but it doesn't work. The cold plug-ins don't open.
                                            Rich O Brien Moderator @alexpacio2013
                                            You can have 3 seats activated before you see the exceeded message.
                                            If you visit https://sketchucation.com/webshop/my-licences.php you can release seats or do at the devices.
                                            alexpacio2013A 1 Reply Last reply
                                            • 112
                                            • 113
                                            • 114
                                            • 115
                                            • 116
                                            • 114 / 116
