    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
    • ntxdaveN
      ntxdave
      OK, I think I have fixed the problems I had with the file I uploaded before. But now I have a new problem. I fixed things in the file (as I just said) however when I click on the button to generate a video, nothing happens. I am including a copy of the file that I hope someone can generate a video for me and maybe someone else can tell me what has happened. I have not had a problem generating a video before.
      3 Scene Animator.skp
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        I am continuing to have problems. It seems like some files will allow me to generate a movie and some will not.
        Hers is a file that "seems" to be OK and in Animator I can see everything, but when I try to generate the video, nothing happens.
        3 Scene Animator.skp (This is a version that I updated today)
        BTW: I tried both with clips for each section and without them and get the same result. Everything plays fine in Animator, but it will not let me generate a video.
        I am beginning to wonder if I should just give up.
        ntxdaveN 1 Reply Last reply
        • ntxdaveN
          ntxdave @ntxdave
          Top Part of Ruby Console:
          #<NoMethodError: undefined method custom_convert_id' for Traductor::ChromiumWdlg:Class> c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:159:in cid'
          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:44:in initialize__' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6weblist.rbe:33:in initialize'
          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in new' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in job_dialog_select_repair'
          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1641:in job_detect_repairing' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:2293:in movie_clip_generation'
          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorpalette.rbe:820:in block in palette_clip_name_duration_video' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:in execute_button'
          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:in onLButtonUp' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp'
          c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:1293:in `onLButtonUp'
          Nothing in the bottom part of the Ruby Console.
          I hope this helps.
          • fredo6F
            I found the issue. The error should happen if you open a model and go immediately to generate the video. If you open other dialogs of my plugins., it should work fine
            It should go better with LibFredo6 v15.8d, just released
            • ntxdaveN
              ntxdave @fredo6
              @fredo6 said in Scene animation with Animator:
              Thank you so much.
              I was about to give up but after updating to the LibFredo6 v15.8d I was able to generate the video. 👍 👍 👍
              In fact, I was also able to create a 2nd version of the model with everything done in clips. Again 👍 👍 👍
              So, here are some videos I was able to create with the 2 versions of the file (one without clips and the other with clips).
              Without clips:
              3 Scene Animator.mp4
              With Clips
              3 Scene Animation With Clips.mp4
              I hope this shows that you can have multiple animated scenes in a SU model and use Animator to "show them off".
              • ntxdaveN
                ntxdave
                @rich-o-brien Thanks for the upvote Rich.
                Updated on 02/03/2026
                My whole purpose here was to demonstrate that you can have multiple scenes with animations and information that can be displayed Animator. The one I displayed is not what I want as a final product was just something to show how you can use the features of Animator (like introduction, animation(s), and conclusion) without having to have an external video editor.
                Throughout this exercise I think I have learned a lot about Animator like:
                • How to combine items to create a “clip”
                • How to “explode” a clip to edit items within the clip
                • How to create and edit Layer visibility controls. As an example this can be used to I used this in the “Introduction” to control the display of line text one line at a time.
                • How to create/capture and edit (at least to some level) camera settings/positions.
                • I also figured how to take advantage of camera feature, along with the layer visibility controls, to “somewhat” control the transition between scenes.
                • I think I also learned some things about using the movement tools.
                Things I need to learn more about (IMO):
                • How to better control the transition from one scene or clip to another one. I think there are options for this but I do not know how/have not figured out. I would like to “fade” between them.
                • I have not experimented with the “translation” tool/feature I would like to be able to use something like section cuts to control the exposure of items or text.
                I hope all of this makes sense. The more I learn about Animator the better I like it and would like to help promote it’s use.
                • ntxdaveN
                  ntxdave
                  I am having some problems trying to control/set cameras when I have multiple scenes. In the attached file, I have a camera position for the Introduction scene, a second one for the Animation scene, and a third one for the Conclusion scene. I have tried capturing the camera setting for each of the scenes and adding them to the animation clip in the appropriate scene. What I am experiencing is that I set/capture the camera position in one of the scenes it gets carried over/applied to each of the other scenes. I hope someone can look at the file and tell me how to resolve the issue. I want the scene in the clip to match the scene if you click on the scene name. Hope that makes sense to anyone who looks at the file.
                  OK, file is too large to upload.
                  • ntxdaveN
                    ntxdave
                    After thinking about this some more, I think I understand what my problem is and will try to fix it (hopefully today). If the problem turns out to be what I think it might be, it is truly my fault.
                    • ntxdaveN ntxdave referenced this topic on
                    • ntxdaveN
                      ntxdave
                      OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated multi scene presentations
                      GIF version:
                      MP4 sersion
                      Jesus Plaque - Fancy.mp4
                      I am also posting this in the Scene animation with Animator thread.
                      • ntxdaveN
                        ntxdave
                        OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate multi scene animated presentations.
                        GIF version:
                        MP4 sersion
                        I also posted them in the Animator thread thread.
                        • ntxdaveN
                          ntxdave
                          OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated presentationsl
                          GIF version:
                          MP4 sersion
                          I am also posting this in the Scene animation with Animator thread. The main point of that thread was to discuss how Animator can be used in multiple scenes for presentation purpose.
                          • ntxdaveN
                            ntxdave
                            OK, I think I have finally generated a multi scene animated presentation with Animator. Here are 2 videos that I hope help you see this.
                            GIF Version
                            MP4 Version
                            Just to let everyone know, I also posted the same videos in the Animator Plugin thread
                            • ntxdaveN
                              ntxdave
                              OK guys (@rich-o-brien & @fredo6 ) after doing some more working on another project, I think you have convinced me that, while I have shown you can do it with Animator, that multi scene animations might be easier to create in another application. I would like to know what software you guys use/recommend for a project like that.
                              In my next project, I want to have several scenes that have a number of images, some text that might be added at different times and, of course, some animations (probably one of two short animations). I have downloaded the trial version of Movie Maker for Windows 11 but am having some issues (like a theme, editing some of the photos, and etc.) but I am currently working with the free version before deciding whether to purchase. I should also let you know that I am running Windows 11.
                              • ntxdaveN
                                ntxdave
                                Well, everyone, I finally took another approach. I recreated the plaque animation I presented before but this time I only used the animation of the plaque in a new video I created using the CapCut video editor (free version). So here is a link to the new version: Jesus Plaque Animation
                                  Mission Accomplished
                                  • 6 / 6
