    Scene animation with Animator
    107 Posts 3 Posters 25.5k Views 3 Watching
    • ntxdaveN
      ntxdave @fredo6
      @fredo6 said in Scene animation with Animator:
      There are videos and there is already a Tip and Trick thread for Animator.
      Yes, I know there are videos (and I have watched several) but as you can tell from this thread, there are times when I have problems finding answers about some tools. I did not find the Tip and Trick thread for Animator. Can you give me a link?
      My plan is to rewrite the UI of Animator, but only once the Mac version of Sketchup is migrated to Qt and share the same code as on Windows. I will lkely use HTML dialogs to have a better positioning of the UI elements in the workspace (especially if you have multiple screens) and a more guided interface.
      Looking forward to this. ๐Ÿ˜€
      Press F1...thank me later
        Rich O Brien Moderator @ntxdave
        @ntxdave said in Scene animation with Animator:
        It is pinned to this suforum.
        Animator Beta
        General discussion about Animator for SketchUp
        sketchucation (community.sketchucation.com)
        • ntxdaveN
          ntxdave
          I am suddenly getting a message that my license expired on 23 Jan 2026 and I do not know how to update/get it working again. Right now I cannot use Animator.
            Are your extensions up to date?
            • ntxdaveN
              ntxdave
              Yes. - according to the SketchUcation manager. ๐Ÿ˜
              I just sent @fredo6 my email address so he can send me some license information
              • ntxdaveN
                ntxdave
                OK guys, I think I have a model here that I think shows you can have something like I talked about before. Although there are some things I need to update (in particular the camera position/distance) on the Animation scene the model has 3 basic scenes. An Introduction scene (which is what I will use at the beginning of some future models), an Animation scene (which is the "main part of the model") where I will do the main features of presenting the model, and a Conclusion scene (which is where I will present some information like - in this case thank the donor of the plaques I modeled).
                I hope this might at least get people to think about the wide range that Animator has and how it can be used (IMO) to present models.
                Here is the "rough" model" 3 Scene Animator.skp
                Once again, I appreciate any comments you might have.
                ntxdaveN 1 Reply Last reply
                • ntxdaveN
                  ntxdave @ntxdave
                  OK - this was the wrong version of the file.
                    It's obviously a personal project. Well done persevering.
                    Now you get to polish and improve while adding to your knowledge.
                    • ntxdaveN
                      ntxdave
                      Somehow several updates did not get included in the file I posted before. I am going to try to update the file and post it again with the additional things I have been working on. What I am doing with this (at this point) is not the final version I have in mind but rather an example of where you can go with Animator. Hope to be able to include the updates within the next couple of days. I spent a good amount of time yesterday and do not know what happened to my updates.
                      I do appreciate your feedback though. I have leaned some "shortcuts" during the process yesterday that really came/come in handy.
                      • ntxdaveN
                        ntxdave
                        OK, I think I have fixed the problems I had with the file I uploaded before. But now I have a new problem. I fixed things in the file (as I just said) however when I click on the button to generate a video, nothing happens. I am including a copy of the file that I hope someone can generate a video for me and maybe someone else can tell me what has happened. I have not had a problem generating a video before.
                        • ntxdaveN
                          ntxdave
                          I am continuing to have problems. It seems like some files will allow me to generate a movie and some will not.
                          Hers is a file that "seems" to be OK and in Animator I can see everything, but when I try to generate the video, nothing happens.
                          3 Scene Animator.skp (This is a version that I updated today)
                          BTW: I tried both with clips for each section and without them and get the same result. Everything plays fine in Animator, but it will not let me generate a video.
                          I am beginning to wonder if I should just give up.
                          • ntxdaveN
                            ntxdave @ntxdave
                            Top Part of Ruby Console:
                            #<NoMethodError: undefined method custom_convert_id' for Traductor::ChromiumWdlg:Class> c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:159:in cid'
                            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:44:in initialize__' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6weblist.rbe:33:in initialize'
                            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in new' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:in job_dialog_select_repair'
                            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1641:in job_detect_repairing' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:2293:in movie_clip_generation'
                            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorpalette.rbe:820:in block in palette_clip_name_duration_video' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:in execute_button'
                            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:in onLButtonUp' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:in onLButtonUp'
                            c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:1293:in `onLButtonUp'
                            Nothing in the bottom part of the Ruby Console.
                            I hope this helps.
                            • fredo6F
                              I found the issue. The error should happen if you open a model and go immediately to generate the video. If you open other dialogs of my plugins., it should work fine
                              It should go better with LibFredo6 v15.8d, just released
                              • ntxdaveN
                                ntxdave @fredo6
                                Thank you so much.
                                I was about to give up but after updating to the LibFredo6 v15.8d I was able to generate the video. ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                In fact, I was also able to create a 2nd version of the model with everything done in clips. Again ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                So, here are some videos I was able to create with the 2 versions of the file (one without clips and the other with clips).
                                Without clips:
                                3 Scene Animator.mp4
                                With Clips
                                3 Scene Animation With Clips.mp4
                                I hope this shows that you can have multiple animated scenes in a SU model and use Animator to "show them off".
                                • ntxdaveN
                                  ntxdave
                                  @rich-o-brien Thanks for the upvote Rich.
                                  Updated on 02/03/2026
                                  My whole purpose here was to demonstrate that you can have multiple scenes with animations and information that can be displayed Animator. The one I displayed is not what I want as a final product was just something to show how you can use the features of Animator (like introduction, animation(s), and conclusion) without having to have an external video editor.
                                  Throughout this exercise I think I have learned a lot about Animator like:
                                  • How to combine items to create a โ€œclipโ€
                                  • How to โ€œexplodeโ€ a clip to edit items within the clip
                                  • How to create and edit Layer visibility controls. As an example this can be used to I used this in the โ€œIntroductionโ€ to control the display of line text one line at a time.
                                  • How to create/capture and edit (at least to some level) camera settings/positions.
                                  • I also figured how to take advantage of camera feature, along with the layer visibility controls, to โ€œsomewhatโ€ control the transition between scenes.
                                  • I think I also learned some things about using the movement tools.
                                  Things I need to learn more about (IMO):
                                  • How to better control the transition from one scene or clip to another one. I think there are options for this but I do not know how/have not figured out. I would like to โ€œfadeโ€ between them.
                                  • I have not experimented with the โ€œtranslationโ€ tool/feature I would like to be able to use something like section cuts to control the exposure of items or text.
                                  I hope all of this makes sense. The more I learn about Animator the better I like it and would like to help promote itโ€™s use.
                                  • ntxdaveN
                                    ntxdave
                                    I am having some problems trying to control/set cameras when I have multiple scenes. In the attached file, I have a camera position for the Introduction scene, a second one for the Animation scene, and a third one for the Conclusion scene. I have tried capturing the camera setting for each of the scenes and adding them to the animation clip in the appropriate scene. What I am experiencing is that I set/capture the camera position in one of the scenes it gets carried over/applied to each of the other scenes. I hope someone can look at the file and tell me how to resolve the issue. I want the scene in the clip to match the scene if you click on the scene name. Hope that makes sense to anyone who looks at the file.
                                    OK, file is too large to upload.
                                    • ntxdaveN
                                      ntxdave
                                      After thinking about this some more, I think I understand what my problem is and will try to fix it (hopefully today). If the problem turns out to be what I think it might be, it is truly my fault.
                                      • ntxdaveN ntxdave referenced this topic on
                                      • ntxdaveN
                                        ntxdave
                                        OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated multi scene presentations
                                        GIF version:
                                        MP4 sersion
                                        Jesus Plaque - Fancy.mp4
                                        I am also posting this in the Scene animation with Animator thread.
                                        • ntxdaveN
                                          ntxdave
                                          OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate multi scene animated presentations.
                                          GIF version:
                                          MP4 sersion
                                          I also posted them in the Animator thread thread.
                                          • ntxdaveN
                                            ntxdave
                                            OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated presentationsl
                                            GIF version:
                                            MP4 sersion
                                            I am also posting this in the Scene animation with Animator thread. The main point of that thread was to discuss how Animator can be used in multiple scenes for presentation purpose.
                                            • 5 / 6
