Scene animation with Animator
Top Part of Ruby Console:
#<NoMethodError: undefined method
custom_convert_id' for Traductor::ChromiumWdlg:Class> c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:159:incid'
c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6weblist.rbe:44:ininitialize__' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6weblist.rbe:33:ininitialize'
c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:innew' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1666:injob_dialog_select_repair'
c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorvideomanager.rbe:1641:injob_detect_repairing' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:2293:inmovie_clip_generation'
c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatorpalette.rbe:820:inblock in palette_clip_name_duration_video' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:4100:inexecute_button'
c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3854:inonLButtonUp' c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:103:inonLButtonUp'
c:/users/doppy/appdata/roaming/sketchup/sketchup 2026/sketchup/plugins/fredo6_animator/animatortool.rbe:1293:in `onLButtonUp'Nothing in the bottom part of the Ruby Console.
I hope this helps.
I found the issue. The error should happen if you open a model and go immediately to generate the video. If you open other dialogs of my plugins., it should work fine
It should go better with LibFredo6 v15.8d, just released
@fredo6 said in Scene animation with Animator:
Thank you so much.
I was about to give up but after updating to the LibFredo6 v15.8d I was able to generate the video.
In fact, I was also able to create a 2nd version of the model with everything done in clips. Again
So, here are some videos I was able to create with the 2 versions of the file (one without clips and the other with clips).
Without clips:
3 Scene Animator.mp4
With Clips
3 Scene Animation With Clips.mp4
I hope this shows that you can have multiple animated scenes in a SU model and use Animator to "show them off".
@rich-o-brien Thanks for the upvote Rich.
Updated on 02/03/2026
My whole purpose here was to demonstrate that you can have multiple scenes with animations and information that can be displayed Animator. The one I displayed is not what I want as a final product was just something to show how you can use the features of Animator (like introduction, animation(s), and conclusion) without having to have an external video editor.
Throughout this exercise I think I have learned a lot about Animator like:
How to combine items to create a “clip”
How to “explode” a clip to edit items within the clip
How to create and edit Layer visibility controls. As an example this can be used to I used this in the “Introduction” to control the display of line text one line at a time.
How to create/capture and edit (at least to some level) camera settings/positions.
I also figured how to take advantage of camera feature, along with the layer visibility controls, to “somewhat” control the transition between scenes.
I think I also learned some things about using the movement tools.
Things I need to learn more about (IMO):
How to better control the transition from one scene or clip to another one. I think there are options for this but I do not know how/have not figured out. I would like to “fade” between them.
I have not experimented with the “translation” tool/feature I would like to be able to use something like section cuts to control the exposure of items or text.
I hope all of this makes sense. The more I learn about Animator the better I like it and would like to help promote it’s use.
I am having some problems trying to control/set cameras when I have multiple scenes. In the attached file, I have a camera position for the Introduction scene, a second one for the Animation scene, and a third one for the Conclusion scene. I have tried capturing the camera setting for each of the scenes and adding them to the animation clip in the appropriate scene. What I am experiencing is that I set/capture the camera position in one of the scenes it gets carried over/applied to each of the other scenes. I hope someone can look at the file and tell me how to resolve the issue. I want the scene in the clip to match the scene if you click on the scene name. Hope that makes sense to anyone who looks at the file.
OK, file is too large to upload.
After thinking about this some more, I think I understand what my problem is and will try to fix it (hopefully today). If the problem turns out to be what I think it might be, it is truly my fault.
N ntxdave referenced this topic on
OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated multi scene presentations
GIF version:
MP4 sersion
Jesus Plaque - Fancy.mp4I am also posting this in the Scene animation with Animator thread.
OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate multi scene animated presentations.
GIF version:
MP4 sersion
Jesus Plaque - Fancy.mp4I also posted them in the Animator thread thread.
OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated presentationsl
GIF version:
MP4 sersion
Jesus Plaque - Fancy.mp4I am also posting this in the Scene animation with Animator thread. The main point of that thread was to discuss how Animator can be used in multiple scenes for presentation purpose.
OK, I think I have finally generated a multi scene animated presentation with Animator. Here are 2 videos that I hope help you see this.
GIF Version
MP4 Version
Jesus Plaque - Fancy.mp4Just to let everyone know, I also posted the same videos in the Animator Plugin thread
OK guys (@rich-o-brien & @fredo6 ) after doing some more working on another project, I think you have convinced me that, while I have shown you can do it with Animator, that multi scene animations might be easier to create in another application. I would like to know what software you guys use/recommend for a project like that.
In my next project, I want to have several scenes that have a number of images, some text that might be added at different times and, of course, some animations (probably one of two short animations). I have downloaded the trial version of Movie Maker for Windows 11 but am having some issues (like a theme, editing some of the photos, and etc.) but I am currently working with the free version before deciding whether to purchase. I should also let you know that I am running Windows 11.
Well, everyone, I finally took another approach. I recreated the plaque animation I presented before but this time I only used the animation of the plaque in a new video I created using the CapCut video editor (free version). So here is a link to the new version: Jesus Plaque Animation
Mission Accomplished
