    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    595 Posts 119 Posters 2.2m Views 119 Watching
    • fredo6F Offline
      Do you have a camera in Parallel Projection mode?
        The scenes called "Animation" and "Csonclusion" [sic] are set to Parallel Projection.
        • ntxdaveN Offline
          ntxdave
          Yes, I see that now and the Introduction scene is set to Perspective. I made sure all scenes were set to Parallel Projection and was now able to generate the video. So the camera setting turned out to be the issue. Hope others can learn from this.
          Yes, there are a couple of issue I need to clean up but as I said, I hope this will help others.
          Edited update
          OK, I am having a little problem. I have created a second version of the file that has all 3 scenes with the camera set to perspective. However, I cannot seem to get things so work correctly. Regardless of how I capture the camera the presentation of all 3 scenes winds up in the same perspective. I like for the plaque animation to be at an angle and the introduction and conclusion screens to be presented straight forward but I cannot get it to come out that way.
          Any advice/hints as to how to make that work and should we take this discussion to the Scene animation with Animator thread?
          Press F1...thank me later
          • fredo6F Offline
            I will look into the bug, which seems to concern camera interpolation when in parallel projection.
            I'll advise then.
            ntxdaveN 2 Replies Last reply Reply Quote 0
            • ntxdaveN Offline
              ntxdave @fredo6
              @fredo6 thanks a ton for the reply. As you saw in my “edit”, I an also having a problem with the “view” position when I have all scenes in perspective. In this particular situation, I would like to have the “introduction” and “conclusion” scenes in parallel and the “animation”scene in perspective. Maybe this is an odd situation but I look forward to your resolution. I have another project in mind but will wait for your response. Again, thanks a ton for your response. 👍👍
              I hope I am not being a PITA with this.
              • ntxdaveN Offline
                ntxdave
                Just to clarify (I hope) here is a video of the way I would like to present my model, but this one does not include the Animator animations I would like to include (as presented in my other post).Jesus Plaque Mixed.mp4
                This video was created by just showing the 3 scenes in the model and using SketchUp's animation creating tool.
                I hope this example contributes to the discussion about where I would like to see Animator go (only with the Animator features included).
                BTW: I do not know why it goes back to the starting scene at the end. That is not what I would want though.
                • ntxdaveN Offline
                  ntxdave @fredo6
                  @fredo6 said in [Plugin] Animator - v4.6a - 18 Dec 25:
                  I'll advise then.
                  Any update on this issue?
                  • fredo6F Offline
                    It's because you transition between a camera in perspective (Introduction) and a camera in parallel projection.
                    There is no simple way to interpolate between both, eacept than to switch at a given time (beginning, end or middle).
                    Considering your animation, I think all views should be in parallel projection.
                    • fredo6F Offline
                      Here is the video if you change the first Scene 'Introduction' to Parallel Projection.
                      Model Animation.mp4
                      • ntxdaveN Offline
                        ntxdave
                        OK, I need to go back and figure out which file you used because I change all of my scenes to parallel and everything worked fine. However, in the "version" I was working with I got it all to work but I need to make some adjustments (as you will see in my video). Model Animation.gif
                        So, bottom line for me, what I have learned ls:
                        • The camera setting "parallel" vs. "perspective" needs to be the same in every scene.
                        • The position of the camera needs to be the same in every scene. At least what I have seem is that if I turn on the axis, it needs to be in pretty much the same position for each scene or things will not present correctly. I guess what I was trying to say here is the Field Of View.
                        • Depending on the type of video/presentation you want to create, you need to evaluate very carefully what you want to achieve with each scene. As you can see in this presentation, I may have to give in and reevaluate if you should use Animator for the full project or do you do the animations with Animator and the other things, like my introduction and thank you scenes with another video generation tool.
                        However, let me say that I am still a big fan of Animator and want to keep working on the best way to achieve things. I do plan on going back and making some changes in this project and really appreciate the support and feedback I have gotten here.
                        • fredo6F Offline
                          I test with a model Jesus Palque.skp which had the Introduction Scene in Perspective and 2 other scenes in Parallel Projection.
                          The egenration of the video was showing the error you got too, which is due to the transition between camera in Perspective and camera in Parallel Projection
                          I will fix the problem, but if all scenes are in Parallel Projection, you can generate the video.
                          • ntxdaveN Offline
                            ntxdave
                            OK, I do not know if this is the thread where we should be discussing this rather than the Scene animation with Animator thread, but I changed the "introduction" scene to Parallel Project and things are working now the way I wanted (although I did make a couple more edits).
                            Now for a real DUH on my part. When I was discussing what I thought were FOV issues turned out to be a DUH by me. When I was looking at the clips, if I did not select the same scene as the clip I thought things were not being presented with the correct FOV. When I woke up, I realized that if I had different scene selected than the one I was viewing the clip for, it would show me thing in the FOV of the selected scene and not the one I was viewing the clip of. Again DUH 😖
                            Here is the latest version of my video (but I plan on maybe making some more "edits" to make some things a little fancier.
                            @fredo6 I apologize to you and hope I have not take this thread to far off topic.
                            • ntxdaveN Offline
                              ntxdave
                              OK, I think I finally figured some things out so here are my latest videos. I hope you enjoy them and they can be used to see how Animator can be used to generate animated presentationsl
                              GIF version:
                              MP4 sersion
                              Jesus Plaque - Fancy.mp4
                              I am also posting this in the Scene animation with Animator thread. The main point of that thread was to discuss how Animator can be used in multiple scenes for presentation purpose.
                              • ntxdaveN ntxdave referenced this topic on
                              • 26
                              • 27
                              • 28
                              • 29
                              • 30
                              • 30 / 30
