    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
    • KrassK
      Krass
      Thanks, everyone, and thanks Pixelcruncher. Now I should do a film school course and learn editing: you'll notice that the fruit (exotic, since they're the cheapest in 3D) appeared as if by magic. It's a perfect example of a jump cut.
      I'm also going to try the same edit with DaVinci Resolve, which has a free version, but I haven't installed it yet. To see if I can get a decent export. Pixelcruncher, I'll look into temporal denoising; I'm not familiar with it. Probably in Premiere, yes.
      Krass
      • KrassK
        Krass @pixelcruncher
        @pixelcruncher I will try that spatial temporal Denoiser ! Yes you can share this master piece !
        Krass
        1 Reply Last reply 👍
          Alattab @Krass
          @Krass You are one of those who are skilled at using things accurately.
            Alattab
            Water samples
              Alattab
              Could you please provide me with settings for clear water with a caustic sheen and caustic
              • KrassK
                Krass
                Hello, it seems you did not had any normal map for your water...below the fountain... You can find many on the web. You will get nice réflection. You could randomly resize the fountain flow for more réalism. There must be a way to produce fake caustics in rayscaper, let us take on this challenge !
                Krass
                • pixelcruncherP
                  pixelcruncher Extension Creator @Alattab
                  @Alattab I haven't found the time yet to do the water material. You will have to work around it by using a caustic pattern from the internet.
                  • pixelcruncherP
                    Hey, Rayscaper users!
                    Rayscaper 0.9.85 Beta is available. You can get it via:
                    • The SketchUcation store.
                    • Direct download: Rayscaper_Win_0.9.85_Beta.rbz.
                    I recommend upgrading to the latest version.
                    What Changed?
                    • Add anisotropy support for metal materials. You can now create brushed metal effects by controlling the direction and amount of anisotropy in metallic surfaces.
                    • Add sheen roughness control to PBR materials. This gives you finer control over fabric-like reflections on surfaces.
                    • Add 'Reload All Materials from SketchUp' option to the Tools menu. This makes it easy to refresh all materials after making changes in SketchUp without restarting Rayscaper.
                    • Add a Reset button to the material editor toolbar. Quickly restore a material to its default settings with a single click.
                    • Improve PBR material editor with better-organized advanced settings using subgroup headers for easier navigation.
                    • Fix normal maps not automatically enabling when loading a normal map image.
                    Help Me Build the Community 👍
                    If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                    Follow me on X.
                    Happy Rendering!
                    Thomas
                    • KrassK
                      Krass
                      C'est extra ! merci!
                      Dear Pixelcruncher,
                      if it's possible in a future version to change the number of pixels in height or width and have the other dimension update accordingly, that would be great. Image resolution scaling by homothety... I don't think that's the case; RS offers "double or half".
                      Krass
                      • KrassK
                        Krass
                        When I move a project, I end up with blue renders... probably an asset path issue? Or maybe it's version 9.85?
                        Krass
                        • KrassK
                          Krass
                          Yes, I was able to reduce the noise with a mask to which I applied a denoiser effect, but is that the denoiser you're thinking of? It's better anyway.
                          Krass
                          • pixelcruncherP
                            This post is deleted!
                            • pixelcruncherP
                              @Krass Yes, according to the docs, that should be the one.
                                Alattab
                                In the latest update, the icons disappeared.
                                • pixelcruncherP
                                  @Alattab That sucks, I'm sorry about that.
                                  As a first step, can you try reinstalling the plugin and restarting SketchUp afterwards?
                                  If that doesn't work, can you send me the log files? https://www.rayscaper.com/getting-help/report-a-bug/#1-export-the-log-files - You can send them to thomas at rayscaper.com.
                                  Thanks,
                                  Thomas
                                  A 3 Replies Last reply
                                  • KrassK
                                    Krass
                                    Hello Thomas
                                    Can you tell me why I get a blue display when I change the project folder?
                                    Krass
                                      Alattab @pixelcruncher
                                      @pixelcruncher Rayscaper_0.9.85_Beta_Windows_logs_2026-01-13_01-28-57.zip
                                        @pixelcruncher I followed your instructions, but the problem persists.
                                        KrassK 1 Reply Last reply
                                          • KrassK
                                            Krass
                                            Hi Thomas,
                                            I'm wondering if the animation export settings in the SketchUp project have an impact on the Rayscaper output: because the last animation I made at 30 frames per second in Rayscaper is set to 24 frames per second in SketchUp...
                                            Krass
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 26
                                            • 27
                                            • 19 / 27
