    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
      Alattab
      It is good thing to copy light properties to each each other
      • pixelcruncherP
        pixelcruncher Extension Creator @Alattab
        @Alattab For someone still being in the learning phase, I'm already seeing some pretty impressive results πŸ™‚
        And don't shy away from the feedback, love it! I take all the feedback seriously and try to add those as new features as I go.
        I'd like contrast control added to the post-processing section
        Noted.
        I'd like contrast control added to the post-processing section, and full PBR properties added
        πŸ‘
        additional materials like transparent liquids, bubbled, fizz, and airborne water.
        A new water material is coming soon. And I will iterate on that to give more options.
        • pixelcruncherP
          @Alattab Okay, that makes more sense. You want a backplate image to compose on? And the front would be to for example put your own logo and watermark on top of it?
          A 1 Reply Last reply
            Alattab @pixelcruncher
            @pixelcruncher Actually, I want to use clip art in the foreground, like grass and other elements, which usually add a sense of depth.
              Alattab
              @pixelcruncher Thank you for your valuable efforts. You are accomplishing something great, and I will share my experience with you regularly.
              1 Reply Last reply β™₯
              • pixelcruncherP
                @Alattab
                As an aside, to quickly edit multiple lights, you can select multiple ones with CTRL / SHIFT + click and edit their properties at the same time.
                Regards,
                Thomas
                1 Reply Last reply πŸ‘
                • pixelcruncherP
                  Hey, Rayscaper users!
                  Rayscaper 0.9.84 Beta is available. You can get it via:
                  • The SketchUcation store.
                  • Direct download: Rayscaper_Win_0.9.84_Beta.rbz.
                  I recommend upgrading to the latest version.
                  What Changed?
                  • Add animation completion dialog. When a scene animation finishes rendering, a dialog now displays render statistics including total time, samples rendered, and frames completed.
                  • Fix crash when minimizing the Rayscaper window via Windows "Show Desktop" (Win+D). The application now handles minimized states gracefully.
                  • Improve scene archiving by extracting SketchUp embedded textures when external files are not available. This ensures textures are always included in exported archives.
                  Help Me Build the Community πŸ‘
                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                  Follow me on X.
                  Happy Rendering!
                  Thomas
                  A 1 Reply Last reply πŸ˜‘ πŸ‘
                  • KrassK
                    Krass
                    That's great, thank you! It's excellent to be able to see the information at the end of the render. I've started the next part of my animation project. In HD mode.
                    Krass
                    • pixelcruncherP
                      @Krass Make sure to share those stunning result!
                        @pixelcruncher Is it now possible to display the materials of the sets if they are painted on the outside without the need to paint the surfaces on the inside?
                        Have liquids been added to the materials list and Specular maps? I would appreciate it if you could attach images of updated Apti elements.
                        • pixelcruncherP
                          @Alattab
                          I'm not sure which bug you are referring to here. Painting materials on containers was already supported in Rayscaper before.
                          No, the liquid material and specular maps are not part of this release. Maybe, if you provide some examples of materials that are hard to recreate, I can help you identify workarounds.
                          Regards,
                          Thomas
                          • KrassK
                            Krass
                            Hey everyone. This is my first animation with Rayscaper, but I'm having trouble getting the frame rate right in Premiere Pro for editing. Any tips? It's at 30 frames per second, though...
                            Krass
                            pixelcruncherP A 2 Replies Last reply πŸ‘
                            • pixelcruncherP
                              @Krass Wow, that's very impressive! Thanks for sharing, this made my weekend.
                              I can't help you with Premiere Pro, but does it have temporal denoise? I wonder if that would help with the flicker caused by the noise.
                              Do you mind if I share your video link around? This is great marketing for Rayscaper.
                              Regards,
                              Thomas
                              KrassK 1 Reply Last reply
                              • ntxdaveN
                                ntxdave
                                Very impressive video. πŸ‘πŸ‘
                                Wish I could afford Premiere Pro.
                                Press F1...thank me later
                                • KrassK
                                  Krass
                                  Thanks, everyone, and thanks Pixelcruncher. Now I should do a film school course and learn editing: you'll notice that the fruit (exotic, since they're the cheapest in 3D) appeared as if by magic. It's a perfect example of a jump cut.
                                  I'm also going to try the same edit with DaVinci Resolve, which has a free version, but I haven't installed it yet. To see if I can get a decent export. Pixelcruncher, I'll look into temporal denoising; I'm not familiar with it. Probably in Premiere, yes.
                                  Krass
                                  • KrassK
                                    Krass @pixelcruncher
                                    @pixelcruncher I will try that spatial temporal Denoiser ! Yes you can share this master piece !
                                    Krass
                                      Alattab @Krass
                                      @Krass You are one of those who are skilled at using things accurately.
                                        Alattab
                                        Water samples
                                          Alattab
                                          Could you please provide me with settings for clear water with a caustic sheen and caustic
                                          • KrassK
                                            Krass
                                            Hello, it seems you did not had any normal map for your water...below the fountain... You can find many on the web. You will get nice rΓ©flection. You could randomly resize the fountain flow for more rΓ©alism. There must be a way to produce fake caustics in rayscaper, let us take on this challenge !
                                            Krass
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 26
                                            • 27
                                            • 19 / 27
