    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • pixelcruncherP
      @Krass Wow, that's very impressive! Thanks for sharing, this made my weekend.
      I can't help you with Premiere Pro, but does it have temporal denoise? I wonder if that would help with the flicker caused by the noise.
      Do you mind if I share your video link around? This is great marketing for Rayscaper.
      Regards,
      Thomas
      KrassK 1 Reply Last reply
      • ntxdaveN
        ntxdave
        Very impressive video. 👍👍
        Wish I could afford Premiere Pro.
        Press F1...thank me later
        • KrassK
          Krass
          Thanks, everyone, and thanks Pixelcruncher. Now I should do a film school course and learn editing: you'll notice that the fruit (exotic, since they're the cheapest in 3D) appeared as if by magic. It's a perfect example of a jump cut.
          I'm also going to try the same edit with DaVinci Resolve, which has a free version, but I haven't installed it yet. To see if I can get a decent export. Pixelcruncher, I'll look into temporal denoising; I'm not familiar with it. Probably in Premiere, yes.
          Krass
          • KrassK
            Krass @pixelcruncher
            @pixelcruncher I will try that spatial temporal Denoiser ! Yes you can share this master piece !
            Krass
            1 Reply Last reply 👍
              Alattab @Krass
              @Krass You are one of those who are skilled at using things accurately.
                Alattab
                Water samples
                  Alattab
                  Could you please provide me with settings for clear water with a caustic sheen and caustic
                  • KrassK
                    Krass
                    Hello, it seems you did not had any normal map for your water...below the fountain... You can find many on the web. You will get nice réflection. You could randomly resize the fountain flow for more réalism. There must be a way to produce fake caustics in rayscaper, let us take on this challenge !
                    Krass
                    • pixelcruncherP
                      pixelcruncher Extension Creator @Alattab
                      @Alattab I haven't found the time yet to do the water material. You will have to work around it by using a caustic pattern from the internet.
                      • pixelcruncherP
                        Hey, Rayscaper users!
                        Rayscaper 0.9.85 Beta is available. You can get it via:
                        • The SketchUcation store.
                        • Direct download: Rayscaper_Win_0.9.85_Beta.rbz.
                        I recommend upgrading to the latest version.
                        What Changed?
                        • Add anisotropy support for metal materials. You can now create brushed metal effects by controlling the direction and amount of anisotropy in metallic surfaces.
                        • Add sheen roughness control to PBR materials. This gives you finer control over fabric-like reflections on surfaces.
                        • Add 'Reload All Materials from SketchUp' option to the Tools menu. This makes it easy to refresh all materials after making changes in SketchUp without restarting Rayscaper.
                        • Add a Reset button to the material editor toolbar. Quickly restore a material to its default settings with a single click.
                        • Improve PBR material editor with better-organized advanced settings using subgroup headers for easier navigation.
                        • Fix normal maps not automatically enabling when loading a normal map image.
                        Help Me Build the Community 👍
                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                        Follow me on X.
                        Happy Rendering!
                        Thomas
                        • KrassK
                          Krass
                          C'est extra ! merci!
                          Dear Pixelcruncher,
                          if it's possible in a future version to change the number of pixels in height or width and have the other dimension update accordingly, that would be great. Image resolution scaling by homothety... I don't think that's the case; RS offers "double or half".
                          Krass
                          • KrassK
                            Krass
                            When I move a project, I end up with blue renders... probably an asset path issue? Or maybe it's version 9.85?
                            Krass
                            • KrassK
                              Krass
                              Yes, I was able to reduce the noise with a mask to which I applied a denoiser effect, but is that the denoiser you're thinking of? It's better anyway.
                              Krass
                              • pixelcruncherP
                                This post is deleted!
                                • pixelcruncherP
                                  @Krass Yes, according to the docs, that should be the one.
                                    Alattab
                                    In the latest update, the icons disappeared.
                                    • pixelcruncherP
                                      @Alattab That sucks, I'm sorry about that.
                                      As a first step, can you try reinstalling the plugin and restarting SketchUp afterwards?
                                      If that doesn't work, can you send me the log files? https://www.rayscaper.com/getting-help/report-a-bug/#1-export-the-log-files - You can send them to thomas at rayscaper.com.
                                      Thanks,
                                      Thomas
                                      A 3 Replies Last reply
                                      • KrassK
                                        Krass
                                        Hello Thomas
                                        Can you tell me why I get a blue display when I change the project folder?
                                        Krass
                                          Alattab @pixelcruncher
                                          @pixelcruncher Rayscaper_0.9.85_Beta_Windows_logs_2026-01-13_01-28-57.zip
                                            @pixelcruncher I followed your instructions, but the problem persists.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 37
                                            • 38
                                            • 19 / 38
