    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • pixelcruncherP
      Hey, Rayscaper users!
      Rayscaper 0.9.84 Beta is available. You can get it via:
      • The SketchUcation store.
      • Direct download: Rayscaper_Win_0.9.84_Beta.rbz.
      I recommend upgrading to the latest version.
      What Changed?
      • Add animation completion dialog. When a scene animation finishes rendering, a dialog now displays render statistics including total time, samples rendered, and frames completed.
      • Fix crash when minimizing the Rayscaper window via Windows "Show Desktop" (Win+D). The application now handles minimized states gracefully.
      • Improve scene archiving by extracting SketchUp embedded textures when external files are not available. This ensures textures are always included in exported archives.
      Help Me Build the Community πŸ‘
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
      Follow me on X.
      Happy Rendering!
      Thomas
      A 1 Reply Last reply πŸ˜‘ πŸ‘
      • KrassK
        Krass
        That's great, thank you! It's excellent to be able to see the information at the end of the render. I've started the next part of my animation project. In HD mode.
        Krass
        • pixelcruncherP
          @Krass Make sure to share those stunning result!
            Alattab @pixelcruncher
            @pixelcruncher Is it now possible to display the materials of the sets if they are painted on the outside without the need to paint the surfaces on the inside?
            Have liquids been added to the materials list and Specular maps? I would appreciate it if you could attach images of updated Apti elements.
            • pixelcruncherP
              pixelcruncher Extension Creator @Alattab
              @Alattab
              I'm not sure which bug you are referring to here. Painting materials on containers was already supported in Rayscaper before.
              No, the liquid material and specular maps are not part of this release. Maybe, if you provide some examples of materials that are hard to recreate, I can help you identify workarounds.
              Regards,
              Thomas
              • KrassK
                Krass
                Hey everyone. This is my first animation with Rayscaper, but I'm having trouble getting the frame rate right in Premiere Pro for editing. Any tips? It's at 30 frames per second, though...
                Krass
                pixelcruncherP A 2 Replies Last reply πŸ‘
                • pixelcruncherP
                  @Krass Wow, that's very impressive! Thanks for sharing, this made my weekend.
                  I can't help you with Premiere Pro, but does it have temporal denoise? I wonder if that would help with the flicker caused by the noise.
                  Do you mind if I share your video link around? This is great marketing for Rayscaper.
                  Regards,
                  Thomas
                  KrassK 1 Reply Last reply
                  • ntxdaveN
                    ntxdave
                    Very impressive video. πŸ‘πŸ‘
                    Wish I could afford Premiere Pro.
                    Press F1...thank me later
                    • KrassK
                      Krass
                      Thanks, everyone, and thanks Pixelcruncher. Now I should do a film school course and learn editing: you'll notice that the fruit (exotic, since they're the cheapest in 3D) appeared as if by magic. It's a perfect example of a jump cut.
                      I'm also going to try the same edit with DaVinci Resolve, which has a free version, but I haven't installed it yet. To see if I can get a decent export. Pixelcruncher, I'll look into temporal denoising; I'm not familiar with it. Probably in Premiere, yes.
                      Krass
                      • KrassK
                        Krass @pixelcruncher
                        @pixelcruncher I will try that spatial temporal Denoiser ! Yes you can share this master piece !
                        Krass
                        1 Reply Last reply πŸ‘
                          Alattab @Krass
                          @Krass You are one of those who are skilled at using things accurately.
                            Alattab
                            Water samples
                              Alattab
                              Could you please provide me with settings for clear water with a caustic sheen and caustic
                              • KrassK
                                Krass
                                Hello, it seems you did not had any normal map for your water...below the fountain... You can find many on the web. You will get nice rΓ©flection. You could randomly resize the fountain flow for more rΓ©alism. There must be a way to produce fake caustics in rayscaper, let us take on this challenge !
                                Krass
                                • pixelcruncherP
                                  @Alattab I haven't found the time yet to do the water material. You will have to work around it by using a caustic pattern from the internet.
                                  • pixelcruncherP
                                    Rayscaper 0.9.85 Beta is available. You can get it via:
                                    • Direct download: Rayscaper_Win_0.9.85_Beta.rbz.
                                    What Changed?
                                    • Add anisotropy support for metal materials. You can now create brushed metal effects by controlling the direction and amount of anisotropy in metallic surfaces.
                                    • Add sheen roughness control to PBR materials. This gives you finer control over fabric-like reflections on surfaces.
                                    • Add 'Reload All Materials from SketchUp' option to the Tools menu. This makes it easy to refresh all materials after making changes in SketchUp without restarting Rayscaper.
                                    • Add a Reset button to the material editor toolbar. Quickly restore a material to its default settings with a single click.
                                    • Improve PBR material editor with better-organized advanced settings using subgroup headers for easier navigation.
                                    • Fix normal maps not automatically enabling when loading a normal map image.
                                    Follow me on X.
                                    Happy Rendering!
                                    Thomas
                                    • KrassK
                                      Krass
                                      C'est extra ! merci!
                                      Dear Pixelcruncher,
                                      if it's possible in a future version to change the number of pixels in height or width and have the other dimension update accordingly, that would be great. Image resolution scaling by homothety... I don't think that's the case; RS offers "double or half".
                                      Krass
                                      • KrassK
                                        Krass
                                        When I move a project, I end up with blue renders... probably an asset path issue? Or maybe it's version 9.85?
                                        Krass
                                        • KrassK
                                          Krass
                                          Yes, I was able to reduce the noise with a mask to which I applied a denoiser effect, but is that the denoiser you're thinking of? It's better anyway.
                                          Krass
                                          • pixelcruncherP
                                            This post is deleted!
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 37
                                            • 38
                                            • 19 / 38
